First Engine Start Problem
Goto page 1, 2  Next
dan(at)azshowersolutions.
PostPosted: Tue Dec 27, 2011 1:41 am    Post subject: First Engine Start Problem Reply with quote
Bob,
I have had the Kitfox wiring completed for about 8 months now and I used the new Z-16 schematic. I have most of my avionics on the E-Bus and they have been working well since day one when I first flipped the switch. A week ago the day came to do my first engine start. As it goes with the Rotax 912uls, we purged the oil system then began turning the prop looking for oil pressure. After turning it through several times by hand we decided to then let the starter do the work. The starter turned the engine over well, however, I was dismayed when my whole panel of avionics went dead. I of course quit cranking and began troubleshooting. It didn't take long to find that the fuseable link off the Batt Contactor (heading to the E-Bus) burned through. I went ahead and bypassed the link with 16 AWG and was able to complete a successful first engine start. The guys that were working with me asked me why that link was there...I did not have a good answer for them. I do have the diode in place, yet I assume a "spike" occurred when I turned the engine over. So...I am now reluctant to put another fuseable link in place but have a concern if there is still a problem that burned my link in the first place.
I am open to comments and suggestions.
Dan Billingsley
Mesa, AZ
PostPosted: Tue Dec 27, 2011 4:17 am    Post subject: First Engine Start Problem Reply with quote
At 03:37 AM 12/27/2011, you wrote:
Bob,
What is the total list of goodies on the e-bus?
Any and all sorts of fault protection (links,
fuses, breakers, etc) are there to protect wires.
The idea of an e-bus is to power up electro-whizzies
most useful for ALTERNATOR OUT EN ROUTE ENDURANCE
while operating battery only. This alternate feed
path goes around the battery contactor thus offering
an opportunity to (1) eliminate battery contactor loads
on the battery or (2) get a minimum list of useful goodies
powered if the contactor or its control circuit fails.
You didn't have a 'spike' . . . you had some level
of LOAD that was greater than what the 22AWG link
would carry. Having a list of goodies powered from the
e-bus will give us the first clues as to why such
a load existed.
mrspudandcompany(at)veriz
PostPosted: Tue Dec 27, 2011 6:14 am    Post subject: First Engine Start Problem Reply with quote
a load existed.
Since this is a new wiring installation, you may want to
check your wiring again. Especially look to make sure that you do not
somehow have starter current through your fusible link.
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.46 KB
 Downloaded:  695 Time(s)
PostPosted: Tue Dec 27, 2011 6:51 am    Post subject: First Engine Start Problem Reply with quote
Thanks for the quick reply. I will be going to the airport today and take inventory of the e-bus goodies. I understand and accept that this could be an over-Load problem so I may need to transfer a couple things to the main bus. What troubles me is I have had this E-bus circuit working many times with everything turned on sometimes for 5 to 10 minutes without a hitch. Will start with a current tally and get back.
Dan
[quote] From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Tuesday, December 27, 2011 5:14 AM
Subject: Re: AeroElectric-List: First Engine Start Problem
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Bob,
a load existe========================www.builders -Matt - The AeroElectric-List Email Forum -http://www.matronics.com/Navigator?Aersp; - MATRONICS WEB FORUMS -
sp; --> http://ww=======================
tperry(at)lvtofly.com
PostPosted: Tue Dec 27, 2011 7:19 am    Post subject: First Engine Start Problem Reply with quote
Sound like you have a loose connection. When you cranked the engine something that was not touching now was. There is often a lot of movement with the engine start you don't get with it just sitting there. And during your troubleshooting you might have moved the offending conbection where it no longer is making contact. I have had this type of problem before and it really sucks when it happens during flight, but best to have a good breaker or fuse blow than a fire....
Tim
On Dec 27, 2011, at 9:46 AM, Dan Billingsley <dan(at)azshowersolutions.com (dan(at)azshowersolutions.com)> wrote:
[quote]Thanks for the quick reply. I will be going to the airport today and take inventory of the e-bus goodies. I understand and accept that this could be an over-Load problem so I may need to transfer a couple things to the main bus. What troubles me is I have had this E-bus circuit working many times with everything turned on sometimes for 5 to 10 minutes without a hitch. Will start with a current tally and get back.
Dan
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Subject: Re: First Engine Start Problem
Bob,
" face="courier new,courier">www.aeroelectric.com
www.buildersbooks.com
uilthelp.com
matronics.com/contribution
st">http://www.matronics.com/Navigator?AeroElectric-List
cs.com
zodiac601
PostPosted: Tue Dec 27, 2011 7:35 am    Post subject: Re: First Engine Start Problem Reply with quote
My guess is an overloaded e bus. When you cranked, the voltage dropped and the amps of everything went up. watts = volts x amps.
If the battery voltage dropped 20% during cranking, then the amperage of everything went up 20% as well.
PostPosted: Tue Dec 27, 2011 10:26 am    Post subject: First Engine Start Problem Reply with quote
For the vast majority of electro-whizzies, current
draw does not go up and input voltage goes down. Modern
avionics with switchmode power supplies are 'constant
power' systems but even then, the increase is not THAT
profound for the duration of a cranking cycle. It takes
a LOT more current to fuse a 22AWG wire than you might
suppose. See:
http://aeroelectric.com/Pictures/Wire/22AWG_20A.pdf
Current ratings for wire is bounded by INSULATION
performance, not COPPER performance. If he fused
a 22AWG link, something rather profound occurred.
PostPosted: Tue Dec 27, 2011 10:29 am    Post subject: First Engine Start Problem Reply with quote
In particular, do you have any loads that are not
generally described in the suggested list of
endurance goodies I've written about? Is your
starter system dependent upon e-bus supply of
energy in any way?
Bob . . . [quote][b]
PostPosted: Tue Dec 27, 2011 5:44 pm    Post subject: First Engine Start Problem Reply with quote
Sent: Tue, December 27, 2011 11:27:05 AM
energy in any way?
No, the starter system is drawn off the main buss. I was not able to take a tally on the goodies today but it is in the cards for tomorrow. I will get back the info to the list as soon as I round it up. I will say that there are quite a few things on the E-Bus as compared to the Main. Doing a tally on the amps drawn when all is on at the E-Bus is something I neglected to do, so I am quite interested in figuring it out. Thanks all for the comments and suggestions.
Dan
aerobubba(at)earthlink.ne
PostPosted: Wed Dec 28, 2011 1:11 am    Post subject: First Engine Start Problem Reply with quote
Howdy-
Re:
we decided to
I'm on the road at the moment (beautiful dowtown Bahrain...) and don't have the relevant docs with me, but if Z-16 has the E bus fed through a diode down stream from the battery contactor and / or through the E bus switch from upstream of the battery contactor, and the diode were installed reverse biased.....
Without other explicit details, this and the idea about engine flail bringing a grounded chunk of hardware into physical contact with an energized bit of the E bus architecture are all I can think of.
Glen Matejcek
PostPosted: Wed Dec 28, 2011 6:07 am    Post subject: First Engine Start Problem Reply with quote
Good call Glen. I did not pick up on the
fact that the fusible link in question was
in series with the ALTERNATE feed switch . . .
which should be OPEN for all but pre-flight
tests -OR- in-flight, alternator-out operations.
Combine this closed switch with a reversed
NORMAL feed path diode could account for the
severe overload of the link.
Dan, do your e-bus feed accessories work with
the alternate feed switch OFF? If not, check
the normal feed path diode for proper polarity.
PostPosted: Wed Dec 28, 2011 6:39 am    Post subject: First Engine Start Problem Reply with quote
Sent: Wednesday, December 28, 2011 7:03 AM
Subject: Re: AeroElectric-List: Re: First Engine Start Problem
No, the E-Bus switch must be ON in order for any of the accessories to operate. I will take another look at the diode polarity as well. One of the guys I am working with suggested I not turn on the E-Bus switch until After I start the engine. That could become a practice, yet it does go against the grain of how things "should" work. Will get back with the info soon.
www.aeroelectric.com</; * HomebuiltHELP http://www.matronics.com/Navigator?AeroElectution Web Site ; &nb="http://www.matronics.com/contribution" target="_blank">http://www.mat=====================
PostPosted: Wed Dec 28, 2011 7:25 am    Post subject: Re: First Engine Start Problem Reply with quote
The E-Bus should be energized with the E-Bus switch off and the master switch on. If not, the diode is backwards.
Although it will not hurt anything to fly with the E-Bus switch turned on, it is intended to be turned on only in the event that power is not available through the diode.
Joe
Joe Gores
PostPosted: Wed Dec 28, 2011 5:43 pm    Post subject: First Engine Start Problem Reply with quote
Bob and Joe, thank you for pointing out both over loading ( I went back and read note 12) and the fact that the E-bus should be working with the Alternate switch off. To tell the truth, I have not tried it that way (w/just the Master on). If it does not work I do see that would mean the diode between the two buses is in backwards. I did check the diode position on the Batt Contactor and it IS installed the right way. I now have at the very least, some changing of circuits over to the Main bus. Will report back on findings after tomorrow.
Dan
[quote] From: user9253 <fran4sew(at)banyanol.com>
Sent: Wednesday, December 28, 2011 8:25 AM
Subject: AeroElectric-List: Re: First Engine Start Problem
--> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=361838#361838www.aeroelectric.com
PostPosted: Wed Dec 28, 2011 5:57 pm    Post subject: First Engine Start Problem Reply with quote
Blowing a fusible link is a rather non-trivial
event. 22AWG wire is capable of considerable
more current than the legacy rating in wire
bundles of 5A would suggest.
It would be interesting to get a real current
measurement of all your goodies before you
start moving things. Clip an ammeter across
the alternate feed switch while the master
switch is off.
PostPosted: Thu Dec 29, 2011 6:37 pm    Post subject: First Engine Start Problem Reply with quote
Just got back from the airport and found the following:
1.I took the ammeter reading across the Alternate switch (with the Master switch off). I was reading at 5.2 A with everything on and that was without keying the mic for transmission. I assume that would bump it up even more (didn't get a chance to try that).
2. The Diode between the two buses WAS backwards. I changed it and now my panel lights up when the Master switch is on. Would this have had any bearing on why my fuseable link burned or do you think I need to move some things to the Main bus? The components I have on the E-bus are as follows:
Dynon D100, Garmin 396, EIS (engine monitor), SL40 radio, Transponder, LED Becon and tail position light, Intercom, HZ Stab trim servo. I don't have wing tip position/Nav lights yet but can probably put them on the main bus along with the other lights when I get them. The other thing I was toying with is moving the D-100 and the 396 over as they both have back-up batteries Thoughts or suggestions welcome.
Dan
Sent: Wednesday, December 28, 2011 6:54 PM
Subject: Re: Re: First Engine Start Problem
switch is off.
<="_blank" href="http://www.aeroelectric.com">www.aeroelectric.comhttp://www.ma======================
PostPosted: Thu Dec 29, 2011 7:45 pm    Post subject: Re: First Engine Start Problem Reply with quote
The diode being backwards was the reason the fusible link burned open. Part of the starter current was going through the E-Bus circuit. There is a saying that electricity takes the path of least resistance. Even though there is a big fat wire going from the battery to the starter, that path is not the least resistance for ALL of the current. Some of the current will find it easier to take parallel paths. An analogy is highway traffic. Most cars will take the multi-lane expressway. But when traffic is very heavy and slows down, some cars will take side streets. For them it is the path of least resistance.
Your lighting circuit could be moved to the main bus. The E-Bus should handle 5 amps OK. The additional 2 amps while transmitting is of short duration and should not burn open the fusible link. I will not be offended if Bob or anyone corrects me.
Joe
Joe Gores
PostPosted: Fri Dec 30, 2011 6:34 am    Post subject: First Engine Start Problem Reply with quote
At 09:45 PM 12/29/2011, you wrote:
--> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com>
You are right on my friend. I will remind
readers that the e-bus (while once erroneously
called an "essential bus") was crafted
for the purpose of keeping an alternator-
out event from becoming an emergency. Hence,
it was re-named the Endurance Bus.
Successful and worry free application of
the e-bus is dependent upon TWO things.
(1) Knowing the minimum amount of energy
stored in the battery and (2) knowing how
many hours of flight are possible while
being a good student of Energy Economics.
One of my most cherished teachers, Thomas
Sowell told me that economics is the study
of scarce resources for which there are
multiple uses. In this case, the scarce
resource is watt-seconds of electrical
energy available to run JUST the electro-
whizzies most useful or en route operations.
Once you have the airport of intended destination
in sight, the scarcity of watt-seconds
disappears.
My personal design goal for sizing and
powering the e-bus is to have more hours
of en-route ops available from the electro-
whizzies than I have fuel aboard. Everybody
plans for there to be enough fuel for the
mission leg . . . it seems that having
a properly crafted e-bus is a good move
for making a dead alternator a maintenance
event as opposed to an emergency. Some
years ago at Oshkosh, I suggested in one
of my forums that system reliability is
achieved when you can deal with any single
failure without breaking a sweat.
Since the people who own the airplanes
I rent would not let me re-arrange their
bus structures, my personal e-bus is powered
by alkaline cells.
http://tinyurl.com/4xjhgly
Whether I'm flying a J-3 or an A-36, I
can confidently get where I want to go
on an exceedingly austere budget of
self contained watt-seconds.
I recommend that the builder craft a
Plan-B for alternator out-ops that includes
periodic capacity checks to make sure that
their battery's current state will carry
e-bus loads for the duration of their
personal design goals. Whether that's 1 hour
or duration of fuel aboard is your decision.
But knowing WHAT it is an maintaining it
is essential to the no-sweat management
of an alternator-out event.
You can obviously have more than necessary
goodies on the e-bus . . . as long as they
have ON-OFF switches. The goal is to have
a plan for load-shedding in place that
re-configures energy consumption to meet
electrical endurance design goals.
Over the years I've studied many "Dark-n-
Stormy Night" stories and deduced that most
if not all would never have been written
had the pilot/author had (1) understanding
and (2) an artfully crafted and maintained
Plan-B.
PostPosted: Fri Dec 30, 2011 8:30 am    Post subject: First Engine Start Problem Reply with quote
Okay, how does 5.2A fit into your Plan-B?
See my earlier posting about Plan-B. You don't necessarily
need to move anything. But you SHOULD have a check-list
driven plan of action for responding to a low-voltage warning
light. 5.2A may not be the Plan-B number. The lower you
can make it, the more secure you are in dealing with an
alternator failure.
Bob McC
PostPosted: Fri Dec 30, 2011 10:55 am    Post subject: First Engine Start Problem Reply with quote
Dan;
While the reversed diode is definitely the cause of the fused fusible link (in combination with having the alternate feed switch on) and installing the diode correctly will prevent the link failing in the future, (your loads are well within what the link will handle) this might also be an indication that there is a higher than desirable resistance in the “fat wire” circuit. Normally the resistance of the large wires and their connections is very very low and they should present the most attractive path for the starter current. However if one of the connections in this circuit is displaying relatively high resistance due to being loose or dirty or???? Then the parallel path through the miswired e-buss circuit might become more attractive and draw an unusually larger percentage of the starter current aggravating the scenario explained by Joe. It might be worth a simple voltage drop test across the fat wire circuit components while cranking to see if there are any joints or portions of that circuit displaying higher than normal resistance. If wired precisely per Z-16 then the likely source for the high resistance, if it exists, would be one of the connections to the battery contactor or the contactor itself. The other possibility of course is that if you tried to crank the engine with the reversed diode, the alternate feed “on” and the master switch “off” then full cranking current was attempting to pass through your fusible link and “poof”. Correctly installing the diode absolutely cures this possibility as well.
Bob McC
> -----Original Message-----
> From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-
> server(at)matronics.com] On Behalf Of user9253
> Sent: Thursday, December 29, 2011 10:46 PM
> To: aeroelectric-list(at)matronics.com
> resistance.
> Joe
> Joe Gores
> http://forums.matronics.com/viewtopic.php?p=361963#361963
> _-
[b]> style='mso-spacerun:yes'> -- Please Support Your Lists This Month --
> style='mso-spacerun:yes'>   (And Get Some AWESOME FREE Gifts!)
[b]> style='mso-spacerun:yes'> November is the Annual List Fund Raiser. Click on
> style='mso-spacerun:yes'> the Contribution link below to find out more about
> style='mso-spacerun:yes'> this year's Terrific Free Incentive Gifts provided
> style='mso-spacerun:yes'> by:
[b]> style='mso-spacerun:yes'> * AeroElectric www.aeroelectric.com
> style='mso-spacerun:yes'> * The Builder's Bookstore www.buildersbooks.com
> style='mso-spacerun:yes'> * HomebuiltHELP www.homebuilthelp.com
[b]> style='mso-spacerun:yes'> List Contribution Web Site:
[b]> style='mso-spacerun:yes'> --> http://www.matronics.com/contribution
[b]> style='mso-spacerun:yes'> Thank you for your generous support!
[b]> style='mso-spacerun:yes'>     -Matt Dralle, List Admin.
[b]> _-
> style='mso-spacerun:yes'>   - The AeroElectric-List Email Forum -
[b]> style='mso-spacerun:yes'> --> http://www.matronics.com/Navigator?AeroElectric-List
[b]> _-
> style='mso-spacerun:yes'>   - MATRONICS WEB FORUMS -
[b]> style='mso-spacerun:yes'> --> http://forums.matronics.com
[b]> _-
> style='mso-spacerun:yes'>   - List Contribution Web Site -
> _-
Bob McC
Falco #908
(just starting)
Goto page 1, 2  Next
Page 1 of 2
