Dynon Skyview Airspeed Calibration...
Site Admin
PostPosted: Mon Dec 26, 2011 7:43 pm    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
Dear Listers,
I've been flying the new 10" Dynon Skyview in the RV-6 for a few weeks now and it seems like the airspeed is reading maybe 10mph fast. The GS always reads 10mph or more slower than the True airspeed, no matter which way I fly with respect to the current wind. Looking through the configuration options on the Skyview, I'm not seeing parameters to calibrate the airspeed. If the airspeed were *slow* compared to the GS, I could envision making adjustments to the Pitot tube to get it in better alignment with slipstream. But *fast* is a head scratcher. If there's no electronic configuration parameters to adjust, what do you do? Are there Pitot line "attenuators" like for RF in coax? Wink
Matt
Matt "Red Dawg" Dralle
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 42+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
Site Admin
PostPosted: Tue Dec 27, 2011 9:16 pm    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
At 07:40 PM 12/26/2011 Monday, Matt Dralle wrote:
Dear Listers,
Matt
Listers,
Thank you for all the great suggestions on resolving this airspeed issue! I took a look at the static ports on the RV-6 today and found that they are done using a flush head screw with a hole drilled in the center on either side of the fuselage. They do *not* protrude from the side of the plane at all. They are totally flush (see attached picture). Just for fun, I whipped up a couple of quick test deals using a 3/16" washer and some electrical tape. I poked a 1/16" hole in the center of the tape and then put the washer centered over the static ports on both sides of the fuselage (see attached pictures). Then, I went flying on this beautiful December 27 day in California!
I didn't have time to do any real scientific multi-leg testing, but I was amazed that the True Airspeed is now falling in a much more believable range compared to the GPS-derived ground speed. On one cross-country leg, I had an exactly 90 degree crosswind component and the True Airspeed and GPS Ground Speed were tracking exactly the same. Yahoo!
Obviously I need to do some additional, more scientific measurements and probably come up with a slightly more "permanent" washer arrangement, but the early returns are very promising! Smile
Thanks again for all the great feedback!
Matt
 Filesize:  57.45 KB
 Viewed:  3937 Time(s)
 Filesize:  136.56 KB
 Filesize:  124.68 KB
 Filesize:  68.35 KB
Site Admin
PostPosted: Thu Dec 29, 2011 7:36 pm    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
At 07:39 PM 12/26/2011 Monday, you wrote:
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com>
Dear Listers,
Matt
Listers,
I went flying tonight in the RV-6 around sunset and took some airspeed numbers flying the four points of the compass. I let each direction normalize for about 2 minutes before taking the readings. I've still got my little black-tape washer deals on the static ports that I detailed in a previous email.
Do these numbers make any sense?
I set the altimeter to 30.15 (KLVK ATIS). I compared the Dynon altitude with the Garmin 696 GPS altitude. The Dynon was high by 100 ft. I used the Dynon altitude adjustment to set it to match the GPS (-100ft). The readings above were after this adjustment.
Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 48+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
 Filesize:  36.65 KB
 Viewed:  3933 Time(s)
m.l.marcotte(at)sympatico
PostPosted: Fri Dec 30, 2011 11:10 am    Post subject: Dynon Skyview Airspeed Calibration... Reply with quote
I think one can calculate from the GPS numbers that you had a 14 MPH (approx) wind from the WNW and you were doing 182 TAS. Your IAS would appear to be 12 MPH too high.
Sent: Thursday, December 29, 2011 10:33 PM
To: rv-list(at)matronics.com (rv-list(at)matronics.com) ; rv8-list(at)matronics.com (rv8-list(at)matronics.com) ; rv7-list(at)matronics.com (rv7-list(at)matronics.com) ; rv10-list(at)matronics.com (rv10-list(at)matronics.com)
Subject: Re: Dynon Skyview Airspeed Calibration...
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
Dear Listers,
Matt
Listers,
[img]cid:22D7DA0DB537424EAE369E728B14E060(at)MobilePC[/img]
