Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27563 Location: Livermore CA USA
Posted: Mon Dec 26, 2011 7:42 pm Post subject: Dynon Skyview Airspeed Calibration... |
Dear Listers,
I've been flying the new 10" Dynon Skyview in the RV-6 for a few weeks now and it seems like the airspeed is reading maybe 10mph fast. The GS always reads 10mph or more slower than the True airspeed, no matter which way I fly with respect to the current wind. Looking through the configuration options on the Skyview, I'm not seeing parameters to calibrate the airspeed. If the airspeed were *slow* compared to the GS, I could envision making adjustments to the Pitot tube to get it in better alignment with slipstream. But *fast* is a head scratcher. If there's no electronic configuration parameters to adjust, what do you do? Are there Pitot line "attenuators" like for RF in coax?
Matt
Matt "Red Dawg" Dralle
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 42+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
_________________ Matt Dralle
psm(at)att.net Guest
Posted: Mon Dec 26, 2011 8:35 pm Post subject: Dynon Skyview Airspeed Calibration... |
Hi Matt,
You might try fooling around with your static port. Dual static ports would be even better.
Airspeed indicators measure the pressure difference between pitot and static lines. If your static line is not correct then the airspeed will be wrong.
Paul
Camas, WA
On 12/26/2011 7:39 PM, Matt Dralle wrote: [quote] | Quote: | Dear Listers,
Matt
| [b]
frankroskind(at)HOTMAIL.C Guest
Posted: Tue Dec 27, 2011 8:13 am Post subject: Dynon Skyview Airspeed Calibration... |
The issue could also be your static port getting lower pressure somehow.
| Quote: | Date: Mon, 26 Dec 2011 19:39:50 -0800
To: rv7-list(at)matronics.com; zenith-list(at)matronics.com
Subject: Zenith-List: Dynon Skyview Airspeed Calibration...
--> Zenith-List message posted by: Matt Dralle <dralle(at)matronics.com>
Dear Listers,
Matt
Status: 42+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode<======================
Posted: Tue Dec 27, 2011 9:16 pm Post subject: Dynon Skyview Airspeed Calibration... |
Matt
Listers,
Thank you for all the great suggestions on resolving this airspeed issue! I took a look at the static ports on the RV-6 today and found that they are done using a flush head screw with a hole drilled in the center on either side of the fuselage. They do *not* protrude from the side of the plane at all. They are totally flush (see attached picture). Just for fun, I whipped up a couple of quick test deals using a 3/16" washer and some electrical tape. I poked a 1/16" hole in the center of the tape and then put the washer centered over the static ports on both sides of the fuselage (see attached pictures). Then, I went flying on this beautiful December 27 day in California!
I didn't have time to do any real scientific multi-leg testing, but I was amazed that the True Airspeed is now falling in a much more believable range compared to the GPS-derived ground speed. On one cross-country leg, I had an exactly 90 degree crosswind component and the True Airspeed and GPS Ground Speed were tracking exactly the same. Yahoo!
Obviously I need to do some additional, more scientific measurements and probably come up with a slightly more "permanent" washer arrangement, but the early returns are very promising!
Thanks again for all the great feedback!
Matt
57.45 KB |
3872 Time(s) |
136.56 KB |
3872 Time(s) |
124.68 KB |
3872 Time(s) |
68.35 KB |
3872 Time(s) |
