Forward Bulkhead
stephen vestuti
PostPosted: Sun Dec 18, 2011 2:12 pm    Post subject: Forward Bulkhead Reply with quote
Ho, Ho, Ho to all builders and non builders !
If any one has the dimensions and position of
the forward centre tunnel bulkhead for the trigear
, could you post or email the details to me,
Steve.
g-iani(at)ntlworld.com
PostPosted: Mon Dec 19, 2011 1:53 am    Post subject: Forward Bulkhead Reply with quote
Steve
Factory Newsletter No 24, Page 11.
Copy attached
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
Tri-bulkhead.pdf
 Filename:  Tri-bulkhead.pdf
 Filesize:  15.4 KB
 Downloaded:  385 Time(s)
stephen vestuti
PostPosted: Mon Dec 19, 2011 11:37 am    Post subject: Re: Forward Bulkhead Reply with quote
Ian,
Thanks very much for taking the trouble to upload the drawing ,
it's spot on !
Steve.
frans(at)privatepilots.nl
PostPosted: Mon Dec 19, 2011 12:58 pm    Post subject: Forward Bulkhead Reply with quote
Hey, I think I missed this! I don't have it.
Does this bulkhead serve any structural purpose?
Should I retrofit this (or something similar)?
Frans
neveyre(at)aol.co.uk
PostPosted: Tue Dec 20, 2011 12:28 am    Post subject: Forward Bulkhead Reply with quote
The Bulkhead as drawn, Is how I did it in the first instance on G-KITS [ Trigear Prototype ] Andy, for some reason decided it was not needed [ structuraly anyway] so it was deleted from later Trigear Manuals.
It is a good idea to install one, I always do on ones I build, helps keep the noise/ heat / smell from the engine out of the cockpit, and somewhere to mount fuel pump[s] on the rear face.
Nev
PostPosted: Tue Dec 20, 2011 1:56 am    Post subject: Forward Bulkhead Reply with quote
As Nev has said the bulkhead is not structural. I discussed this with Barry Mellers when I redesigned the centre tunnel of G-IANI in 2002. My version consists of glass flanges onto the tunnel and bolting the bulkhead panels to them. This means the bulkhead can be removed for access.
Newsletter 24 is dated December 1999. All copies of the newsletter are on the Club wed site.
To add to the benefits others have listed it is also a secondary fire wall which would prevent Alasdair’s freezing draft becoming a flame thrower.
