sidsel.svein(at)oslo.onli Guest
Posted: Tue Dec 13, 2011 9:52 am Post subject: SV: Bottom cut-outs |
Gary,
Thank you very much for your good comments.
I will give it a try with the openings that I presently have, and will do as you suggest – move some parts (the T for fuel return and the T for sight tube) so that they become accessible in the wheel well, provided I manage to get out those parts and hoses (some surgical cutting of the old hoses could do the trick).
Without having performed any structural analysis, attached is a sketch of how area B (ref. my previous mail) could be cut out and the strength of the bottom retained when an aluminum cover of adequate thickness and quality is bolted in the cut-out’s place. WARNING: Not verified in any way!!
Good luck with completion of your build!
Svein
Bottom_cut-out_cover.pdf |
46.93 KB |
296 Time(s) |
