pitot/static connectors
davidjoyce(at)doctors.org
PostPosted: Thu Dec 08, 2011 3:18 am    Post subject: pitot/static connectors Reply with quote
Since building my plane I have been very conscientious about replacing all
rubber hoses every 5 yrs, but sadly overlooked the 'O' rings on the quick
connectors for the pitot static lines at the wing root. These have gone rock
solid since last derigged and it looks as though I can only disconnect them
at the expense of destroying the connectors. I mention it for the benefit of
those whose connectors are nearly as old as mine and in the faint hope that
someone out there has found a solution to this problem.
Regards, David Joyce, G-XSDJ
brian.davies(at)clara.co.
PostPosted: Thu Dec 08, 2011 4:13 am    Post subject: pitot/static connectors Reply with quote
Hi David,
They might have gone "sticky" rather than hard. As you have nothing to
lose, I would be tempted to spray some WD40 or similar into the connector to
see if it frees the O rings.
brian
riddon(at)sent.com
PostPosted: Fri Dec 09, 2011 12:07 am    Post subject: pitot/static connectors Reply with quote
Hi David.
I don't have a solution for you but thanks for the heads up. Just checked mine and found that the O rings were perished.
Richard Iddon G-RIXS
On 8 Dec 2011, at 11:15, David Joyce wrote:
Since building my plane I have been very conscientious about replacing all rubber hoses every 5 yrs, but sadly overlooked the 'O' rings on the quick connectors for the pitot static lines at the wing root. These have gone rock solid since last derigged and it looks as though I can only disconnect them at the expense of destroying the connectors. I mention it for the benefit of those whose connectors are nearly as old as mine and in the faint hope that someone out there has found a solution to this problem.
h&jeuropa
PostPosted: Fri Dec 09, 2011 4:58 am    Post subject: Re: pitot/static connectors Reply with quote
Hi David,
We have found that you can purchase new o-rings in the plumbing section of a hardware store. And an application of silicon grease helps keep them supple.
Jim & Heather
N241BW
ptag.dev(at)tiscali.co.uk
PostPosted: Fri Dec 09, 2011 1:46 pm    Post subject: pitot/static connectors Reply with quote
Hi! All
Yes I had that issue about a couple of years ago
Bob Harrison G-PTAG
----Original Message----
Date: 09/12/2011 8:04
Subj: Re: pitot/static connectors
Hi David.
org.uk>
Bookstore www.buildersbooks.com
_-
