Detaching the Fuel Tank
Site Admin
PostPosted: Mon Nov 28, 2011 2:12 pm    Post subject: Detaching the Fuel Tank Reply with quote
At 01:34 PM 11/28/2011 Monday, you wrote:
Does anyone know how I can detach or remove the fuel tanks from the wings? I unscrewed the screws on the wing but the tank refuses to budge.
Due to a fuel leak I need to remove the starboard tank. Fuel was dripping from the trailing edge of the wing root.
Thanks.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherlands
Hi George,
I think there might be a hand full of AN3 bolts that you'll have to remove from the aft side of the spar before you can drop the fuel tank. On the RV-8, there were a lot of bolts. A lot. I can't remember if the -6/-4 have the same arrangement, but it would stand to reason.
Matt "Red Dawg" Dralle
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 18 Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
denis.walsh(at)comcast.ne
PostPosted: Mon Nov 28, 2011 2:33 pm    Post subject: Detaching the Fuel Tank Reply with quote
Denis Walsh
denis.walsh(at)comcast.net
I have had the honor to perform this task numerous times.
There are no rear-baffle-to-spar-bolts on the six wing tank, so you are almost done.
There is a bolt at the front and rear on the inboard side. These attach the inboard tank rib to the airplane. In the front it is a bracket, and in the rear it is a tongue fitting in to the fuselage carry through aft spar. You must remove the wing fairing to get to these.
Even when you get all those fasteners out there are still some traps.
there are a bunch of those screws which are dimpled these dimpled holes do not want to let go of the recessed holes they go in to. you sometimes have to persuade them with a sliding piece of shim material. I use a plastic putty knife to pry the skins up a little to clear the dimples.
Further traps include: forgetting to unscrew and disengage the fuel lines and vent lines, and lastly the fuel level sender wire.
Good luck. The fun is just beginning. wait til you drill holes in the aft baffle and start cleaning out the pro seal.
> Thanks.
> George Nielsen
> RV-6 PH-XGN
Hi George,
HCRV6(at)comcast.net
PostPosted: Mon Nov 28, 2011 5:42 pm    Post subject: Detaching the Fuel Tank Reply with quote
Sorry, but RV-6 and RV-7 tanks are attached differently.
Harry Crosby
RV-6 N16CX, 913 hours
To: rv-list(at)matronics.com
Sent: Monday, November 28, 2011 5:25:01 PM
Subject: Re: Re: Detaching the Fuel Tank
George:Once in a while a question comes up which I can actually answer.
Sorry about your fuel leak - I believe the RV-6 has the same fuel tank attachment arrangement as my RV-7A - in addition to removing the screws which attach the tank to the top and bottom of the wing - you must also remove a number of AN-3 bolts which fasten the tank to the main wing spar - the back of the fuel tank is attached to the front of the main wing spar by a series of "Z" brackets which are bolted to the rear of the tank in front of the bracket and to the front of the spar at the rear of the bracket - you can access the bolts at the rear of the brackets by opening the inspection panels on the bottom of the wing - access is not difficult once the inspection panels are removed - the bolt heads will be obvious on the back of the spar - the brackets will stay bolted to the tank as it is removed - Good luck with the leak.
Dan Bergeron
RV-7A - N307TB
277 hours since first
flight on Aug 6, 2009
On Mon, Nov 28, 2011 at 5:10 PM, Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)> wrote:
[quote]--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
>--> RV6-List message posted by: George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)>
>Thanks.
>George Nielsen
>RV-6 PH-XGN
Hi George,
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
get="_blank">http://www.matronics.com/Navigator?RV-List
http://forums.matronics.com
le, List Admin.
chris_hand(at)comcast.net
PostPosted: Mon Nov 28, 2011 11:28 pm    Post subject: Detaching the Fuel Tank Reply with quote
Close, but don't need to remove the rear spar bolt to pull just the tank. Just the screws, bolt at leading edge under wing root fairing, and the tank connections mentioned below.
Chris
On Nov 28, 2011, at 2:30 PM, Denis Walsh <denis.walsh(at)comcast.net> wrote:
Denis Walsh
>> Thanks.
>> George Nielsen
>> RV-6 PH-XGN
> Hi George,
> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel
PostPosted: Tue Nov 29, 2011 5:34 am    Post subject: Detaching the Fuel Tank Reply with quote
Well said. Two sentences covered it all.
The more I run on the greater the chance of error.
Thanks.
Chris
> Denis Walsh
>>> Thanks.
>>> George Nielsen
>>> RV-6 PH-XGN
>> Hi George,
