byoungplumbing(at)gmail.c Guest
Posted: Wed Nov 23, 2011 12:45 pm Post subject: testing |
just a test,,,, seemed I sent a plain text message to the digest list and it came back on the active list in plain text,,, this one is being sent to the active list, in html. and I will see if it comes back, and what format it is in when it does
boyd young
do not archive.
Posted: Wed Nov 23, 2011 3:38 pm Post subject: testing |
for those receiving post that scroll off the screen.... I am using vista, so your mileage may vary. here may be the fix, or info that may help.
after opening the mail program, I hit "tools" then "options" at the top of the screen there are tabs, look for the "read" and "send" tabs.
in the "read" tab, if you check the box " (X) read all messages in plain text" that may help, but you will loose the rich formatting of the text as supplied by the author. i.e. different fonts, color, sizes, etc.
in the "send" tab: you can set the "mail sending format" to "plain text or html" if you select plain text all messages will be sent plain text unless you have the box checked " (X)reply to messages in the format they were sent" in which case if you receive a html message and hit reply, it will reply in html. even if you have selected plane text for the sending format, it overrides. if you just create mail, it will go in plain text.
if anytime you want to over ride the default while composing an email, go to the menu bar and press "format" and choose which format you want, plain text or html.
it seems that matronics will forward the post in plain text or html, depending on which format the message was received in. even the digest mode which comes in plain text,,, has a link to a html version.
I hope this helps. if not sorry.
Boyd young
do not archive.
