Aluminium Pipe for Fuel Inlet
ward.t(at)xtra.co.nz
PostPosted: Sun Nov 27, 2011 11:01 am    Post subject: Aluminium Pipe for Fuel Inlet Reply with quote
Hi Europa Builders,
I have had a request for more Aluminium pipes for the fuel Inlet between the “cobra” and the fuel tank.
Are there any other builders interested in one?
See the attachment.
Cheers,
Mono Classic #292 ZK-TIM
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz
 Filesize:  19.94 KB
 Viewed:  983 Time(s)
Owner_Ward.vcf
Download
 Filename:  Owner_Ward.vcf
 Filesize:  183 Bytes
 Downloaded:  215 Time(s)
Europa_-_ALUMINUM_FUEL_FILLER_PIPE.doc
Download
 Filename:  Europa_-_ALUMINUM_FUEL_FILLER_PIPE.doc
 Filesize:  24.5 KB
 Downloaded:  207 Time(s)
