m.tucciarone(at)hotmail.c Guest
Posted: Thu Nov 17, 2011 11:13 am Post subject: canopy leaks |
This my be a stupid question but here goes. I was thinking about taking my
newly bought RV-8 on a trip where it will have to be parked on a ramp for a
few days. I did not get a canopy cover with the plane and was wondering if
the -8's take in water when it rains? Also does anyone use the Light travel
canopy cover that Vans sells and does it keep out the rain?
Matt
craigtxtx(at)yahoo.com Guest
Posted: Thu Nov 17, 2011 12:09 pm Post subject: canopy leaks |
I used the Vans lightweight cover while parked during a frog strangler on my way to OSH in 2010. It worked well. I was concerned about leaks around the front baggage door, but that was not an issue.
Craig Gallenbach
RV8A N184CG 215hrs
On Nov 17, 2011, at 2:04 PM, "Matt Tucciarone" <m.tucciarone(at)hotmail.com> wrote:
This my be a stupid question but here goes. I was thinking about taking my newly bought RV-8 on a trip where it will have to be parked on a ramp for a few days. I did not get a canopy cover with the plane and was wondering if the -8's take in water when it rains? Also does anyone use the Light travel canopy cover that Vans sells and does it keep out the rain?
Matt
Larry Bowen
Posted: Thu Nov 17, 2011 12:13 pm Post subject: canopy leaks |
I used the light cover on my 8 and thought is was fine. I'd get it again. I don't think I had any canopy leaks. I did get some water through the NACA vent during a storm though. Plug it with a closed cell sponge or something.
I also put some of those plastic cling shades over each fuel cap to keep the rain out when parked outdoors. The same ones that can be slapped on the canopy for some sun relief.
Safe travels.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
On Thu, Nov 17, 2011 at 2:30 PM, Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)> wrote:
[quote] --> RV-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
On 11/17/2011 2:04 PM, Matt Tucciarone wrote:
| Quote: | --> RV-List message posted by: "Matt Tucciarone" <m.tucciarone(at)hotmail.com (m.tucciarone(at)hotmail.com)>
I have seen a -8 ... but have no clue if they leak. I may still help though.
| Quote: | Also does anyone use the Light travel canopy cover that Vans sells and does it keep out the rain?
Most of the light weight covers shed the rain by containing it in the cover so it's absorbed in the cloth and drains instead of impacting where the canopy meets the windshield. The heavier covers actually repel the water so the underside stays dry.
I'd recommend a good cover if you're going to leave the airplane out .... google 'canopy covers'.
However, you can use the lightweight cover and just use the blue painters tape to seal underneath the cover. BTDT.
Linn
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
get="_blank">http://www.matronics.com/Navigator?RV-List
http://forums.matronics.com
le, List Admin.
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Posted: Thu Nov 17, 2011 1:34 pm Post subject: canopy leaks |
Thanks everyone for your comments. I think I will buy the light cover from Vans.
Sent: Thursday, November 17, 2011 3:10 PM
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: Re: canopy leaks
Safe travels.
Larry Bowen
| Quote: | --> RV-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
Linn
le, List Admin.
le, List Admin.
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
vincefrazier(at)gmail.com Guest
Posted: Fri Nov 18, 2011 6:44 am Post subject: Canopy leaks |
A simple, cheap, and surefire way to keep water out is to simply carry
a roll of decent quality electrical tape. If it looks like rain,
simply place a piece of tape over the canopy joints and fuel caps.
Electrical tape will peel off cleanly and doesn't adhere aggressively
enough to lift paint. Unless your paint is crappy anyway.
Another benefit is that you won't have a canopy cover taking up space
when stored, nor will the tape cause any wear like a flapping, dirty
canopy cover can.
Vince Frazier
Flyboy Accessories
3963 Caborn Road North
Mount Vernon, IN 47620
812-464-1839
1-888-8FLYBOY
1-888-835-9269
www.flyboyaccessories.com
Matt
Deerlake(at)bresnan.net Guest
Posted: Fri Nov 18, 2011 7:06 am Post subject: Canopy leaks |
Years ago on my RV6, I used pieces of static cling sun shade cut into
squares, rectangles and strips to seal the leading edge of the tip up
canopy, cover the fuel caps and the NACA air vents on the side of the
fuselage. As long is the surface is dry when applied, the pieces stayed
on. I remember putting a piece across the gap between the hood and
fender on my Explorer and driving down a gravel road at 50 mph. The
piece stayed on. Even after buying a canopy cover, I still used the sun
shade pieces over the gas caps and vents and never had any of the pieces
come off.
Bob Skinner-former RV6 builder and owner 1995-2000
| Quote: | > This my be a stupid question but here goes. I was thinking about taking my
> Thanks,
> Matt
yenduc(at)me.com Guest
Posted: Fri Nov 18, 2011 7:35 am Post subject: canopy leaks |
I've used the light weight Van's cover on my RV fro the last three
years with no problem it is compact and easy to use and has kept
things dry.
dave RV 7A
On Nov 17, 2011, at 11:04 AM, Matt Tucciarone wrote:
Matt
Dale Ensing
Posted: Fri Nov 18, 2011 8:16 am Post subject: Canopy leaks |
Where did you purchase the static cling sheets?
Sent from my iPad
On Nov 18, 2011, at 10:03 AM, Bob <Deerlake(at)bresnan.net> wrote:
Years ago on my RV6, I used pieces of static cling sun shade cut into squares, rectangles and strips to seal the leading edge of the tip up canopy, cover the fuel caps and the NACA air vents on the side of the fuselage. As long is the surface is dry when applied, the pieces stayed on. I remember putting a piece across the gap between the hood and fender on my Explorer and driving down a gravel road at 50 mph. The piece stayed on. Even after buying a canopy cover, I still used the sun shade pieces over the gas caps and vents and never had any of the pieces come off.
>> Thanks,
>> Matt
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
rwstracy(at)gmail.com Guest
Posted: Fri Nov 18, 2011 8:47 am Post subject: Canopy leaks |
My RV-8 was parked 40 feet in front of those 3 Pietenpols That were rolled up in a ball during the torrential rain and tornado at Sun & Fun this year. Even without a cover the cockpit and fwd baggage area was bone dry afterwards. My -4 cockpit gets drenched in a light rain without a cover though.
Tracy Crook
On Nov 18, 2011, at 9:41 AM, Vince Frazier <vincefrazier(at)gmail.com (vincefrazier(at)gmail.com)> wrote:
[quote]--> RV-List message posted by: Vince Frazier <vincefrazier(at)gmail.com (vincefrazier(at)gmail.com)>
canopy cover can.
Vince Frazier
Flyboy Accessories
812-464-1839
1-888-8FLYBOY
1-888-835-9269
nbsp; November is the Annual List Fund Raiser. Click onwww.aeuilder's Bookstore www.homebuilthelp.comref="http://www.matronics.com/contribution">http://www.matronics.com/contribution
nbsp; -Ma====================================================; http://www.matronics.com/Navigator?RV-Li===================================================<.com">http://forums.matronics.comhttp://www.matronics.com/contribution
Posted: Fri Nov 18, 2011 9:31 am Post subject: Canopy leaks |
At Walmart if I remember correctly. I used the same stuff on the top of
my canopy to keep my bald head from getting burned & it worked well.
Bob Skinner
On 11/18/2011 9:12 AM, Dale Ensing wrote:
Sent from my iPad
>>> Thanks,
>>> Matt
dan.pat.b(at)gmail.com Guest
Posted: Fri Nov 18, 2011 10:51 am Post subject: Canopy leaks |
Matt:I've been flying my RV-7A for two years and two months since first flight on Aug 6, 2009. At home it sleeps in a hangar but on overnight cross countries it gets tied down on the ramp, where we use Vans' lightweight canopy cover. I recall one occasion where there was heavy rain overnight; the cockpit and behind the panel remained bone dry with the cover in place. On another occasion however the cover was dislodged to one side in a windstorm; no rain on that occasion so no issue with water. I've since run extra lines from each edge of the canopy cover and tie them off at the landing gear/fuselage intersection. So far - so good.
Dan Bergeron
RV-7A - N307TB
273 hours since 8/6/11
On Fri, Nov 18, 2011 at 12:28 PM, Bob <Deerlake(at)bresnan.net (Deerlake(at)bresnan.net)> wrote:
[quote]--> RV-List message posted by: Bob <Deerlake(at)bresnan.net (Deerlake(at)bresnan.net)>
At Walmart if I remember correctly. I used the same stuff on the top of my canopy to keep my bald head from getting burned & it worked well.
Bob Skinner
| Quote: | --> RV-List message posted by: Dale Ensing<densing(at)carolina.rr.com (densing(at)carolina.rr.com)>
Sent from my iPad
On Nov 18, 2011, at 10:03 AM, Bob<Deerlake(at)bresnan.net (Deerlake(at)bresnan.net)> wrote:
| Quote: | --> RV-List message posted by: Bob<Deerlake(at)bresnan.net (Deerlake(at)bresnan.net)>
| Quote: | | Quote: | This my be a stupid question but here goes. I was thinking about taking my
Matt
le, List Admin.
le, List Admin.
