BobbyPaulk(at)comcast.net Guest
Posted: Mon Nov 14, 2011 3:37 pm Post subject: Rudder Alignment |
p { margin: 0; }List
After 128 hrs I found the following:
I made sure the nose wheel was straight with the V-notch.
Then set the rudder pedals exactly equal ( same distance off the back of the firewall )
Drop a plumb bob off the bottom of the rudder and rig it about 1/4" to the right. It may take a little more or less but this will keep the ball centered at whatever cruise you choose. This lets the V-notch hold the rudder offset just enough to keep the ball centered.
Most of my passengers are pilots or instructors so the skid ball being not centered is a no-no even momentarily : )
Bobby
N131BP
601 B
Jab 3300
128 hrs
n801bh(at)netzero.com Guest
Posted: Mon Nov 14, 2011 4:26 pm Post subject: Rudder Alignment |
I did the exact same thing on my 801... works great too... Altho I am defeating ALOT of extra horsepower....<GG>
Ben Haas
N801BH
www.haaspowerair.com
BARRY CHECK 6
Posted: Mon Nov 14, 2011 4:39 pm Post subject: Rudder Alignment |
Guys:
A question: If the plane is built square and the ball is not centered why does one have to go through the exercise of plumb-bob'ing the rudder instead of just putting a ground adjustable trim-tab on the rudder?
Barry
On Mon, Nov 14, 2011 at 6:31 PM, <BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)> wrote:
[quote] List
Bobby
N131BP
601 B
Jab 3300
128 hrs
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
arget="_blank">http://www.matronics.com/Navigator?Zenith-List
tp://forums.matronics.com
Afterfxllc(at)aol.com Guest
Posted: Mon Nov 14, 2011 7:33 pm Post subject: Rudder Alignment |
Answer: Just to make it as difficult as it can possibly be..... I have never used either a plumb bob or a trim tab on any of the planes I have built or rigged. A good eye can tell you all you need to know. Just follow the KISS system and it will fly just fine.
In a message dated 11/14/2011 7:40:27 P.M. Eastern Standard Time, flyadive(at)gmail.com writes:
| Quote: | Guys:
Barry
| Quote: | List
Bobby
N131BP
601 B
Jab 3300
128 hrs
tp://www.aeroelectric.com/">www.aeroelectric.com
/ href="http://www.buildersbooks.com/">www.buildersbooks.com
http://www.homebuilthelp.com/">www.homebuilthelp.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
ef="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
s.matronics.com/">http://forums.matronics.com
BARRY CHECK 6
Posted: Tue Nov 15, 2011 4:06 am Post subject: Rudder Alignment |
I tried the eye-balling method. But it is very difficult to run behind the plane and keep the head from bobbing.
Barry
On Mon, Nov 14, 2011 at 10:28 PM, <Afterfxllc(at)aol.com (Afterfxllc(at)aol.com)> wrote:
[quote] Answer: Just to make it as difficult as it can possibly be..... I have never used either a plumb bob or a trim tab on any of the planes I have built or rigged. A good eye can tell you all you need to know. Just follow the KISS system and it will fly just fine.
In a message dated 11/14/2011 7:40:27 P.M. Eastern Standard Time, flyadive(at)gmail.com (flyadive(at)gmail.com) writes:
| Quote: | Guys:
Barry
