Ed Anderson
Posted: Wed Jan 11, 2006 6:39 pm Post subject: radio work needed |
> Please keep in mind about radio repair, only certified avionics shops can
| Quote: | return a TSO'd unit to service within tolerances that are now required.
Gary Wilson is NOT a certified repairman or shop. He cannot certify any
transponders or systems in an aircraft.
If you or any others need more info on this please give me a call at work
or
email me at work. You know where I am.
Hope this helps
Eddie
Edwin.G.Shields(at)FAA.GOV (mailto:Edwin.G.Shields(at)FAA.GOV) (don't forget
the dots between the name)
PS: Come on down for a visit at our strip in York, we always have drinks
in
the fridge. May be gone this Saturday picking up another project but will
be
home Sunday and Monday. Debbie and me are working very hard now on my
Swift.
We do have a complete sheetmetal shop here too.
Hi Eddie, we met once when you were inspecting Mike Bics RV-4 at GooseCreek.
Since I recommended Gary Wilson (and I understood that Gary was not a
certified shop/repairman - nor has he ever conveyed any different impression
to me). However, the question is does that preclude him from say installing
a radio in an aircraft panel of an experimental aircraft?
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
WVSWIFT(at)aol.com Guest
Posted: Thu Jan 12, 2006 2:28 am Post subject: radio work needed |
ED:
As I said before, anybody can work on an experimental. The radios are not
experimental that are used in ATC systems.But keep in mind, even if an antenna
of a transponder is removed, the entire certification of the transponder
system has to be recertified. Unfortunately that's the way the regs are stated.
Eddie
Ed Anderson
Posted: Thu Jan 12, 2006 6:05 am Post subject: radio work needed |
Ok, thanks for the clarification Eddie.
Ed
Matthews, NC
