R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Mon May 22, 2006 8:25 pm Post subject: Gentlemen, Check your tailwheels! |
I have had a very fortunate incident. A week ago Saturday my tailwheel assy broke. I had flown for 2.6hrs, done three off field landings and returned home without incident. I folded up as I always do, but as I slipped the hairpin clip into the wingfold tube on the second wing, both wingtips hit the ground. The down tube that the tail wheel is mounted on folded back.
Inspection shows that there had been a crack on the edge of the weld underneath the crossbar at the leading edge of the downtube for a while (no rust, but darkened metal.) After the days flying and 322hrs, the extra weight of the wings on the tailwheel spread the crack to the end of the tube and that was that.
I have since tigged up a new one with thicker 4130 tubing using ER80S-D2 filler rod and some pre-heat. The new one is painted a light color so that any cracks will show up easily.
Just a heads up to the list. Chances are there may be other cracks out there. I have included a couple of pictures below.
| This is a shot of the failure before anything was moved. |
293.53 KB |
521 Time(s) |
| Here's the split tube, bent back into position so I could measure the angle. |
182.46 KB |
506 Time(s) |
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
Possum
Posted: Mon May 22, 2006 9:02 pm Post subject: Gentlemen, Check your tailwheels! |
At 12:25 AM 5/23/2006, you wrote:
Yes Sir - Me too.
Modified tail wheel assembly. Took this picture in 1999 - before I went flying.
Second flight - and it fell-off in the air somewhere?
"You" might notice that the axle has already slipped half out of the
bracket (I didn't).
I was just taking pictures of my new plane for the "Kolb List".
Forgot the cotter pins. No harm done....grass strip.
There goes another $5 "grocery cart" wheel and a $20's worth of bearings.
http://www.mindspring.com/~possums/Tailwheel.jpg
ElleryWeld(at)aol.com Guest
Posted: Tue May 23, 2006 1:43 pm Post subject: Gentlemen, Check your tailwheels! |
You must have cought it on something I had the same problem 2 years ago but
it was because I cought it on some Crusty snow and Ice and it broke the same
way yours did but Now I have the full swivel tail wheel and that worry is gone
Ellery in Maine
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Tue May 23, 2006 1:55 pm Post subject: Gentlemen, Check your tailwheels! |
Ellery...
How about picture(s) of your full swivel tailwheel?...
David
On 5/23/06, ElleryWeld(at)aol.com <ElleryWeld(at)aol.com> wrote:
but
same
gone
Ellery in Maine
"Ultralight flying isn't about transportation; it's about the ma
gic of
pure, simple flight." - Scott Wilcox
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
Posted: Tue May 23, 2006 2:00 pm Post subject: Gentlemen, Check your tailwheels! |
I will get you a picture in a few minutes its sexy ...
Ellery
ElleryWeld(at)AOL.COM Guest
Posted: Tue May 23, 2006 4:07 pm Post subject: Gentlemen, Check your tailwheels! |
Do they Look as Sexy as mine? if not Call TNK and Order Yours today
Ellery in Maine
Posted: Tue May 23, 2006 4:16 pm Post subject: Gentlemen, Check your tailwheels! |
I dont think the pictures made it her so I sent them to the Photo share for
you to see
Ellery
David.Lehman
Posted: Tue May 23, 2006 4:17 pm Post subject: Gentlemen, Check your tailwheels! |
Ellery, I don't see any pictures...
DVD
Ellery in Maine
magic
| Quote: | of pure, simple flight." - Scott Wilcox
R. Hankins
Posted: Tue May 23, 2006 4:17 pm Post subject: Re: Gentlemen, Check your tailwheels! |
[quote="You must have caught it on something" [/quote]
Not that I know of. I have come home with a few weeds in the tailwheel, but not on this trip. The landings were off field, but not on rough ground or with tall weeds. The crack was no older than 2 or three weeks, as I washed the plane about that long ago, and there was no rust in the crack. In my area, bare metal rusts in a hurry. I still can't believe it waited till I was folded to give up. Good luck is hard to come by. I'll take it when I can get it.
Possum, What do you have for a wheel now? I was thinking of using one of those little scooter wheels that come in cool colors.
HShack(at)AOL.COM Guest
Posted: Tue May 23, 2006 5:23 pm Post subject: Gentlemen, Check your tailwheels! |
In a message dated 5/23/2006 8:18:34 PM Eastern Standard Time,
rphanks(at)grantspass.com writes:
That's what I use. There are 2 sizes; 100 mm & 120 mm [I think]. I used the
big one. They appear to have a good bearing in them. I believe the axle
needs to be an 8 mm bolt.
Howard Shackleford
FS II
SC
Possum
Posted: Tue May 23, 2006 5:37 pm Post subject: Gentlemen, Check your tailwheels! |
At 08:17 PM 5/23/2006, you wrote:
Not me .... I to, have the full swivel tail wheel now - $200. Got
tired of picking the tail up
every time I wanted to get it into tight spot - my back is worth the money.
Besides - It's kinda neat to just push it around from the back - by
the prop - and
steer it with your knees. Plus - I like doing the Cub maneuver -
Lock a brake
down and spin that bad boy around into your slot at the airshows. I
was worried
about the weight (that far back), but it didn't make a bit of
difference. You young guys
use the scooter wheels -
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Tue May 23, 2006 5:51 pm Post subject: Gentlemen, Check your tailwheels! |
| Quote: | Possum, What do you have for a wheel now? I was thinking of using one of
Roger in Oregon
1992 KXP 503
Roger,
I built a tailwheel assembly for my Mk-3 with two forks instead of one. I
also used a scooter wheel bought on sale at Walmart for $1.
The color matches my plane and I used an AN-5 bolt for the axle which is the
same as 8mm and a castle nut and cotter pin. Other than the extra fork leg
and the bolt for the axle, it looks just like the Kolb unit.
I purchased the 4130 tubing from Aircraft Spruce.
Denny Rowe
Dave Pelletier
Joined: 10 Jan 2006 Posts: 100 Location: Prescott, Arizona
Posted: Tue May 23, 2006 6:14 pm Post subject: Gentlemen, Check your tailwheels! |
| Quote: | . Got tired of picking the tail up every time I wanted to get it into tight
Lock a brake down and spin that bad boy around into your slot at the
airshows. I
was worried about the weight (that far back), but it didn't make a bit of
difference. You young guys use the scooter wheels -
Amen, brother, Amen!
AzDave
_________________ AzDave |
Possum
Posted: Tue May 23, 2006 6:29 pm Post subject: Gentlemen, Check your tailwheels! |
At 10:13 PM 5/23/2006, you wrote:
<pelletier(at)cableone.net>
>spot - You young guys use the scooter wheels -
AzDave
See there - use old guys stick together.
jindoguy(at)gmail.com Guest
Posted: Tue May 23, 2006 7:54 pm Post subject: Gentlemen, Check your tailwheels! |
I too rejected the full swivel tail wheel due to its weight, then flip
flopped and bought the 6" version so it would be proportiional to the 18"
nerf tires on the mains. Man, it's just slick. I can lock a brake and spin
around the locked wheel, and when I want to put the plane back into its
hangar, it just swivels around and makes for very easy manuevering.
On 5/23/06, possums <possums(at)mindspring.com> wrote:
tight
>AzDave
Rick Girard
"Pining for a home on the Range"
