E-Bus Circuit Protection
Uncle
PostPosted: Wed Nov 02, 2011 5:56 am    Post subject: E-Bus Circuit Protection Reply with quote
With an all electric panel (Cozy MkIV), my Essential Bus will pull ~22 amps with everthing on it running full blast. In real world ops with backup components powered off (ie Nav/Comm #2, etc.), it would be down to ~15 amps at night. Question 1: Is the B&C S8009 40A relay suitable to use for the alternate E-bus feed. Question 2: For circuit protection on the 10ga power feed from the Batt Bus to the E-Bus (via relay), can I splice into 2 of the 15amp fuse slots so as not to exceed the recommended load per slot or can I use a 14ga wire as a fuse-link coming off the main connection terminal of the Batt Bus fuse block?
William
William E. Buckley
PostPosted: Wed Nov 02, 2011 2:07 pm    Post subject: E-Bus Circuit Protection Reply with quote
At 08:53 AM 11/2/2011, you wrote:
<hoverandwire(at)yahoo.com>
Bus fuse block?
Sounds like your endurance bus has strayed from
the original design goals. What all do you have
attached to this bus? What size battery are you
flying? Did you configure based on any particular
Z-figure?
Uncle
PostPosted: Thu Nov 03, 2011 3:38 am    Post subject: E-Bus Circuit Protection Reply with quote
Bob,
The schematic is attached. Its mostly the Z-11 with Z-30 and Z-32 mixed in(dual battery and relay controlled E-bus). Two 16AH batteries. Not all the wire sizes and CB/fuse sizes have been filled in yet. Still a work in progress.
William
--- On Wed, 11/2/11, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com>
Subject: Re: E-Bus Circuit Protection
Date: Wednesday, November 2, 2011, 6:04 PM
--> AeroElectric-List message
posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
William <hoverandwire(at)yahoo.com>
  Z-figure?
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser.  Click on
out more about
Gifts provided
AeroElectric www.aeroelectric.com
www.buildersbooks.com
              -Matt
Dralle, List Admin.
AeroElectric-List Email Forum -
FAQ,
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
Electric_System_1-2_(11-02-11).pdf
 Filename:  Electric_System_1-2_(11-02-11).pdf
 Filesize:  34.51 KB
 Downloaded:  627 Time(s)
William E. Buckley
PostPosted: Thu Nov 03, 2011 8:48 am    Post subject: E-Bus Circuit Protection Reply with quote
At 06:35 AM 11/3/2011, you wrote:
Bob,
Understand. Okay, let's look at your numbers.
What are the load-analysis numbers for items
on the e-bus?
Uncle
PostPosted: Thu Nov 03, 2011 11:31 am    Post subject: E-Bus Circuit Protection Reply with quote
Most of these came from the components' docs, some from examples in the 'Connection', and a few are SWAG's. For the Nav/Comms I listed both at max load (ie transmitting). Its not realistic to transmit on both simultaneouly and in a battery only scenario one would be turned off anyway. However I want both to be available on the Ebus to allow for a really bad night if the alternator and one nav/comm quit. Perhaps it is overkill to list both nav/comms at max load for this exercise?? Also, the relays to power the Ebus are not listed. Here's the E-bus load list.
Trim: 0.3
Lft Fwd Kneeboard Lt: 0.1
L&R Fuel Probes: 0.04
Inst Panel Lts: 0.5
Panel Fld Lts: 0.25
Dynon D180: 1.6 (Can op on internal batt ~1hr)
Dynon D10A: 1.0 (Can op on internal batt ~1hr)
TruTrak T&B: 0.5
Audio Panel: 1.0
Nav/Comm 1: 5.0
Nav/Comm 2: 5.0
Xpndr: 1.6
Left Panel Cig Lighter: 0.75 (SWAG load for handheld backup GPS or other)
Fuel Boost/Prime: 1.5
Annunciator panel: 1.5 (8 LED's with controlling circuit module)
--- On Thu, 11/3/11, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Subject: Re: Fw: Re: E-Bus Circuit Protection
Date: Thursday, November 3, 2011, 12:46 PM
> Bob,
progress.
  on the e-bus?
Lists This Month --
Raiser.  Click on
out more about
Gifts provided
              -Matt
Dralle, List Admin.
FAQ,
              -Matt
Dralle, List Admin.
William E. Buckley
PostPosted: Fri Nov 04, 2011 6:08 am    Post subject: Re: E-Bus Circuit Protection Reply with quote
Question 1: Yes, the B&C S8009 40A relay is be suitable, IMHO.
Question 2: For circuit protection, it not advisable to parallel fuses.
One of the Dynons and one of the nav/coms can be moved to the main power bus.
The estimated current draw of some of the loads seems to be on the high side. The Garmin GTX-327 typically uses about 1.1 amps, a nav/com about 1 amp receive and 3 amps transmit, depending on the brand.
If some of the load is moved to the main bus, the load on the e-bus will drop to under 10 amps and can be protected with a 15 amp fuse fed with 14AWG.
The 4AWG feeding the main power bus could be downsized to #6 unless it is a long run. 8AWG could even be used for very short runs. Even though the alternator is rated for 60 amps, it will normally be putting out a fraction of that.
The ammeter shunt location will show battery charging current which is normally close to zero, pretty useless information. System voltage will indicate if the alternator is working or not. You might consider eliminating the shunt and using that Dynon D-180 screen space for displaying some other more useful parameter, perhaps temperature from a thermocouple.
Joe
Joe Gores
PostPosted: Fri Nov 04, 2011 8:18 am    Post subject: E-Bus Circuit Protection Reply with quote
Okay, Joe beat me to it with some astute observatation
cogent arguments. I'll expand on Joe's posting as follows:
Trim: 0.3 (This is an intermittant load not significant
to an energy study)
Inst Panel Lts: 0.5
Panel Fld Lts: 0.25 (Do you need BOTH lighting systems in a
endurance mode?)
Dynon D180: 1.6
Dynon D10A: 1.0
TruTrak T&B: 0.5 (Are all of these instruments part of your
Plan-B for alternator-out operations? It appears
that the D180 has the broadest range of features
and could be the e-bus favorite for alternator-out
ops)
Audio Panel: 1.0
Nav/Comm 1: 5.0
Nav/Comm 2: 5.0 (Surely one nav/com would suffice. Further, while
the peak load may be 5A during transmit, only
the receive mode is significant to the total
energy requirements)
Xpndr: 1.6
(Do you have a MAIN GPS?)
Fuel Boost/Prime: 1.5 (also intermittent duty)
(This is a LOT of of current for an LED annunciator)
I think if you consider the normal running loads
upon which you stack the occasional transient load
your total load figures will get much better.
Have you considered the SD-8 as an aux alternator
to support alternator out ops? What's your calculated
endurance, battery only?)
------------- Joe's Response with further food for thought
Joe
Joe Gores
Uncle
PostPosted: Fri Nov 04, 2011 11:21 am    Post subject: E-Bus Circuit Protection Reply with quote
Gents,
Feedback very much appreciate. A bit more work to do on my end. Circling back to one of the original questions: for circuit protect of the ebus supply line, any harm in doing it with a fusible-link (14ga for 10ga supply)?
William
--- On Fri, 11/4/11, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Subject: Re: Fw: Re: Fw: Re: E-Bus Circuit Protection
Date: Friday, November 4, 2011, 12:13 PM
significant
              to an
energy study)
Inst Panel Lts: 0.5
systems in a
      endurance mode?)
Dynon D180: 1.6
Dynon D10A: 1.0
It appears
features
alternator-out
      ops)
Audio Panel: 1.0
Nav/Comm 1: 5.0
transmit, only
total
Xpndr: 1.6
GPS or other)
module)
annunciator)
loads
load
alternator
your calculated
<fran4sew(at)banyanol.com>
suitable, IMHO.
parallel fuses.
the main power bus.
Joe
Joe Gores
Lists This Month --
Raiser.  Click on
out more about
Gifts provided
              -Matt
Dralle, List Admin.
FAQ,
              -Matt
Dralle, List Admin.
William E. Buckley
PostPosted: Fri Nov 04, 2011 3:26 pm    Post subject: Re: E-Bus Circuit Protection Reply with quote
Okay, Joe beat me to it with some astute observatation cogent arguments.
You deserve the credit, Bob, for being my mentor.
Joe
Joe Gores
PostPosted: Fri Nov 04, 2011 9:46 pm    Post subject: E-Bus Circuit Protection Reply with quote
Gents,
William
Not recommended. Fusible links (like current limiters)
are intended to protect HEAVY feeders subject to large,
short time transients (like downstream breaker trips).
There's no sin in fusing a wire for less than rated
capability. I've often used upsized wires to get a lower
voltage drop . . . without upsizing the protection.
If your goal is to embrace the original design goals
for the e-bus, then total loads need to be reduced to
some value that affords HOURS of endurance battery
only. What size batteries do you plan to carry?
Just as an example:
http://www.aeroelectric.com/Pictures/Curves/17AH_12V_Capacity_vs_Load.gif
This set of performance curves for an 18 a.h. battery
suggest that a NEW battery will carry a 5 amp e-bus
for 2 hours. If you need that 2 hour goal to be met
at an 80% end of service life, then you'd need to
downsize to about 4 amps e-bus load.
Your batteries need to be selected as a trade-off
between equipment really necessary for comfortable
en route operations and the amount of lead and
plastic you're willing to drag around. This study
in energy management illustrates the value in adding
the SD-8 standby alternator. It's good for 8A for
ANY number of hours thus saving limited energy
in SMALLER batteries for approach to landing
and arrival. That 3.5 pound alternator can replace
a whole lot more pounds of lead.
One battery and two alternators is a lot more
attractive than one alternator and any number/size
of batteries.
Uncle
PostPosted: Sat Nov 05, 2011 4:09 am    Post subject: E-Bus Circuit Protection Reply with quote
Good info. Thanks for the extra help.
William
--- On Sat, 11/5/11, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Date: Saturday, November 5, 2011, 1:42 AM
> Gents,
> William
limiters)
large,
trips).
lower
goals
to
  Just as an example:
battery
adding
  of batteries.
Lists This Month --
Raiser.  Click on
out more about
Gifts provided
              -Matt
Dralle, List Admin.
FAQ,
              -Matt
Dralle, List Admin.
William E. Buckley
