Dennis Thate
Posted: Sun Oct 30, 2011 8:05 am Post subject: Fuel Tender Ideas please |
I found this cast metal rotary pump at a farm store for about $129. It's both a siphon and a pump. One hundred complete turns produces about ten gallons of gas. I plan to carry this in a small trailer with gas hose and use
this as my fuel shuttle.
Show me something better and I'll buy it !
3.94 KB |
12450 Time(s) |
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
rickofudall
Posted: Sun Oct 30, 2011 8:43 am Post subject: Fuel Tender Ideas please |
Dennis, you didn't add a link or anything about the pump. Do make sure it is rated for gasoline. Saving a few bucks is great until you balance them against the bills from the burn ward of a hospital.
Rick Girard
On Sun, Oct 30, 2011 at 11:05 AM, Dennis Thate <retroman(at)frontier.com (retroman(at)frontier.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Dennis Thate" <retroman(at)frontier.com (retroman(at)frontier.com)>
[Idea]
…”These flying machines are just a fad and will never catch on…” Unknown
http://forums.matronics.com/viewtopic.php?p=356329#356329
http://forums.matronics.com//files/rotary_hand_gas_pump_siphon_853.jpg
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
lcottrell
Posted: Sun Oct 30, 2011 8:58 am Post subject: Fuel Tender Ideas please |
I wasn't aware that mechanical pumps had to be rated for anything. He did send a picture.
Larry
Note: If you forward this email, please delete the forwarding history, which includes my email address.
Thom Riddle
Posted: Sun Oct 30, 2011 9:01 am Post subject: Fuel Tender Ideas please |
That looks a lot like the one I bought from Harbor Freight for way less than half that price. It worked for fuel for awhile but since the seals were not compatible with gasoline, they gave up after several months of use. I then replaced it with the following pump with seals rated for gasoline and other petroleum products. It has been working fine for over a year.
Oops. Could not find the one I bought online anymore. It is a lever type and easy to operate with 8 pumps per gallon, or one pint per pump.
Thom in Buffalo
On Sun, Oct 30, 2011 at 12:05 PM, Dennis Thate <retroman(at)frontier.com (retroman(at)frontier.com)> wrote:
[quote] --> Kolb-List message posted by: "Dennis Thate" <retroman(at)frontier.com (retroman(at)frontier.com)>
[Idea]
le, List Admin.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Dennis Thate
Posted: Sun Oct 30, 2011 9:20 am Post subject: Re: Fuel Tender Ideas please |
Here's the link
http://www.chdist.com/displayproductdetail.do?skuSearch=7434600&mr:referralID=5f5e1d01-fd8f-11e0-9866-001b2166becc&baseItemOID=94443&itemGroupOID=94443&sku=7434600&cid=cse_next
"For petroleum products like gasoline, diesel fuel, kerosene, and light oils."
ceengland(at)bellsouth.ne Guest
Posted: Sun Oct 30, 2011 9:33 am Post subject: Fuel Tender Ideas please |
In the aftermath of Katrina, we used
http://www.harborfreight.com/barrel-pump-45743.html
to pump avgas from our field's tank to run our generators.
Most pumps that are reasonably priced, both electric & mechanical, specify 'no gasoline', but I suspect that for the hand cranked pumps it is driven more by the legal department than any real danger.
Charlie
On 10/30/2011 11:53 AM, Thom Riddle wrote: [quote]That looks a lot like the one I bought from Harbor Freight for way less than half that price. It worked for fuel for awhile but since the seals were not compatible with gasoline, they gave up after several months of use. I then replaced it with the following pump with seals rated for gasoline and other petroleum products. It has been working fine for over a year.
Thom in Buffalo
lcottrell
Posted: Sun Oct 30, 2011 9:59 am Post subject: Fuel Tender Ideas please |
I would imagine that most of the seal problems are due to Ethanol, not necessarily gas itself.
Larry
Dana
Posted: Sun Oct 30, 2011 11:59 am Post subject: Fuel Tender Ideas please |
At 12:05 PM 10/30/2011, Dennis Thate wrote:
| Quote: | --> Kolb-List message posted by: "Dennis Thate" <retroman(at)frontier.com>
Show me something better and I'll buy it ! |
I added a hose and dip tube to my existing 5 gallon plastic can. A foot pump (made for filling air mattresses) puts a small amount of pressure (~5 psi, which is about the same pressure as when a gas can sits in the sunlight and bulges out) in the can which pushes fuel up the tube to my tank. A brass ball valve on the end lets me shut it off when it's full: <http://smg.photobucket.com/albums/v486/flyparafan/Kolb/fuel%20filler/?start=0>
A commercially available version of the system is at http://www.portablefuelsystems.com/ (not the expensive alcohol separator, their fueling system I think costs about the same as your pump
-Dana
What's brown and sticky? A stick!
zeprep251(at)aol.com Guest
Posted: Sun Oct 30, 2011 4:40 pm Post subject: Fuel Tender Ideas please |
20 gal drum with Carter electric fuel pump-12volt off the race car, with 20ft of 3/8 neoprene gas line with a phony plastic nozzle.Must pump about 2.5 gal per min.There is a good picture of the set up on oh2fly's trailer web page.The pump was about 80.00,can't remember what the line cost,but it beats cranking big time.
G.Aman
Dennis Thate
Posted: Sun Oct 30, 2011 5:52 pm Post subject: Re: Fuel Tender Ideas please |
| zeprep251(at)aol.com wrote: | 20 gal drum with Carter electric fuel pump-12volt off the race car, with 20ft of 3/8 neoprene gas line with a phony plastic nozzle.Must pump about 2.5 gal per min.There is a good picture of the set up on oh2fly's trailer web page.The pump was about 80.00,can't remember what the line cost,but it beats cranking big time.
G.Aman
Maybe I'm being overly cautious, I want to stay away from any chance of sparks; battery / electric of any kind... I have a farm background and like simplicity.
http://bcove.me/4tryzjbk
pj.ladd(at)btinternet.com Guest
Posted: Mon Oct 31, 2011 2:56 am Post subject: Fuel Tender Ideas please |
| Quote: | 20 gal drum with Carter electric fuel pump-12volt off the race car, with
20ft of 3/8 neoprene>
Unless it is imperative that you keep a large amount of fuel on site this
seems like overkill.
I would never have fuel around any electrics it was possible to avoid it.
You are only talking about transferring 10 galls max and even then only if
your tank is completely empty.. How long can it take ?
If I need it I pick up a jerrycan (20 litres) of fuel at the garage on the
way to the strip. I have a cheap plastic pump with a stiff plastic hose of
about 1 inch dia. on the inlet side. This can be cut to length to suit your
container. There is a flexible plastic hose of similar bore on the output
side. This snaps into a Terry Clip fixed to one of the internal struts
behind the seats and leads the end of the hose into the strainer funnel and
into the tank.
The pumping action is provided by two cylinders which fit loosely inside
each other. One has a small handle attached and this is pulled and pushed
over a distance of about 2 inches.
If you sit on the jerrycan to hold it steady, as I do, it presents an
interesting picture as you are vibrating the pump somewhere in the region of
your groin.
Transfer 10 gall. takes around 5 minutes. The whole thing weighs only a few
ounces and travels easily on the cockpit floor. This enables me to transfer
fuel from the spare jerrycan I carry in the passengers seat if I land away
from any facilities.
For what its worth
Pat
Posted: Mon Oct 31, 2011 5:20 am Post subject: Fuel Tender Ideas please |
Dennis,
Absolutely.I'm sure the one horsepower model shown in that video will generate no sparks.I also enclosed the pump switch in an airtight plastic box.,can't be too careful! Never thought of a pump system that runs on hay. G.Aman
Posted: Mon Oct 31, 2011 5:39 am Post subject: Fuel Tender Ideas please |
Pat,
I burn 100LL av fuel so having a supply near the strip is handy,but I still have to transport it by truck from the airport in jerrycans,usually 30gal at a time once or twice a year.Spilling fuel in the cabin of the MK3 was always a concern.Auto fuel stinks and remains that way a long time if you spill it on upholstered areas.100LL does neither.I used to slip a 5ft long piece of 3/4 heater hose over the nozzle of the gas can ,stick it in the fuel tank and lift the can.
I considered an electric motor for the Kolb,but all those extension cords-----
G>A.
Posted: Mon Oct 31, 2011 5:43 am Post subject: Fuel Tender Ideas please |
For what its worth
Pat
Patrick L/Gang:
Depends on how much you fly and/or the fuel capacity of your tank. I can
knock out a 20 gal tank, then run back to the store and get another 5 gal to
finish topping off. I am not by myself, flying with more than 5 or 10 gal
capacity.
I fuel from 5 gal cans with a 6 foot section of 7/8" ID vinyl tubing stuck
on the end of the gas can spout. Takes a minute or two to transfer 5 gal,
and my fuel filler is located on the top of the center section. I do have
to hold the gas can over my head during the fueling process. One of these
days I probably will not be able to do that. At that time I will start
filling the 5 gal cans with 2.5 gal.
I usually carry this 6 foot piece of vinyl hose in aircraft on long cross
country flights. Occasionally, I'll have a chance to obtain mogas and
refuel from a gas can. Now that 100LL is averaging 5.50 a gal, I'll
probably be making a more concerted effort to burn mogas and use my Alabama
credit card (6' siphon hose).
If you think a 20 gal fuel tank is an overkill, you should see the refuel
set up at the Rock House. Larry has a couple two or three 55 gal drums with
high capacity electric fuel pump and nozzle, and a 15 or 20 gal mobile tank
with manual pump. He needs every bit of that capacity, especially when a
bunch of us show up and do a lot of flying.
I'm still gun shy about using fuel from gas cans at places I am not familiar
with. The two times I had engine failures with the 912 engine, both were
the result of contaminated fuel acquired from unreliable sources with
contaminated fuel cans.
Titus, Alabama - 33F this morning. ;-(
_________________ John Hauck
Titus, Alabama |
Posted: Mon Oct 31, 2011 12:03 pm Post subject: Fuel Tender Ideas please |
with manual pump. >>
If I was running an airfield miles from anywhere I would have something like
that too.
I am talking about 1 plane with a garage half a mile away. As for holding a
fuel can above my head. Forget it.
Cheers
Pat
Posted: Mon Oct 31, 2011 12:08 pm Post subject: Fuel Tender Ideas please |
Spilling fuel in the cabin of the MK3 >>
Gary,
I have a large hole with an insert to close it off, cut into the plastic side window of the Xtra just where the filler on the tank is. Careful not to spill fuel on the Lexan though.
Easier to refuel through the door which is what I usually do. It does stink though if you spill some.
Pat
