chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Fri Oct 28, 2011 9:46 pm Post subject: Dynon OAT probe location |
Hi all
I was going to put the Dynon OAT probe in the LH cabin air intake .
Any issues with that location
Chris
psm(at)att.net Guest
Posted: Sat Oct 29, 2011 1:50 am Post subject: Dynon OAT probe location |
Hi Chris,
I didn't bother installing my temperature probe anywhere. I suppose it
might be nice as a conversation piece with your passenger, but for
navigation purposes the GPS seems to do just fine at "Computing" ground
speed.
You don't want the probe to be hit with direct sun light. In your case
I guess it depends on how far in the cabin air intake system you put
it. If it is far enough away from the air input to avoid sun light then
perhaps it would not work at all if you close off the cabin air flow -
as I have done for winter operations.
Good luck,
Paul
Camas, WA
jaybannist(at)cs.com Guest
Posted: Sat Oct 29, 2011 4:59 am Post subject: Dynon OAT probe location |
Chris,
That seems the ideal location to me. Here is a photo of mine.
Jay
138.74 KB |
6435 Time(s) |
jeffrey_davidson(at)earth Guest
Posted: Sat Oct 29, 2011 6:38 am Post subject: Dynon OAT probe location |
Chris,
That is a popular location and works well. Mine is under the fiberglass saddle on the tail. It is in the open air and still not in direct sunlight. That works well too but the wires are longer.
Jeff D
zman601xl(at)aol.com Guest
Posted: Sat Oct 29, 2011 6:39 pm Post subject: Dynon OAT probe location |
nickhelsper(at)gmail.com Guest
Posted: Sat Oct 29, 2011 6:49 pm Post subject: Dynon OAT probe location |
I installed one in a little aluminum tube that stuck out of the bottom of the wing stub. I filled the end of the tube with flox, and drilled a hole in the front of the tube, so that the free airstream could get to the probe. I think the cabin air vent would work nice too.
-nick
On Sat, Oct 29, 2011 at 9:36 PM, <zman601xl(at)aol.com (zman601xl(at)aol.com)> wrote:
