Posted: Wed Oct 26, 2011 10:39 am Post subject: Portable Bench Test Battery |
As I was putting the morning's experiment tools away
it occurred to me that many of you might find value
in this tool.
If you're pulling a battery out of your airplane because
it no longer meets design goals for battery-only operations,
it may well have lots of life in a work-bench based role.
See:
http://aeroelectric.com/Pictures/Tools/Test_Equipment/Bench-Test_Battery.jpg
This particular battery was brand new about 10 years ago
and placed into service as an instrumentation battery
for stuff I was doing at Beech.
Haven't cap-checked it lately but it still load tests
at over 300 Amps for 15 seconds. Here you see how I bonded
a breaker-switch on the top along with a 3/4" spaced
banana jack set with JB-Weld. A handle was added by running
three strands of 2" wide glass-reenforced strapping tape
from side to side . . . bunching it up in the 'grip' area
and wrapping with tape.
This tool has seen service in many situations where I
needed some 12-Volt snort with considerable load handling
ability and/or capacity. Your choice of connectors and switch
are optional as well as size of protection. If you use a
generic switch, stick an in-line fuse holder in the wiring.
You can select a plug in fuse from 3 to 30 amps . . .
appropriate to the task at hand.
Posted: Wed Oct 26, 2011 10:43 am Post subject: Portable Bench Test Battery |
See:
Oh yeah, forgot to mention. This battery has been used
to start numerous cars given the exposed jumper-cable-
friendly posts.
When not in use, it sets on a Battery Tender.
