metuna(at)earthlink.net Guest
Posted: Wed Oct 19, 2011 11:20 am Post subject: High CHTS Cylnder Baffles for 3 & 4 |
Hi,
Gary Vogt mentions a mod to the wraparound metal baffling for Cylinders 3 & 4 , we are working on getting our High CHTS under control and attacking it step by step. Flexible baffling work is finished and has helped ~ 20 degrees.
Gary mentioned trimming of the wraparound cylinder baffling for # 3&4 that helps with the cooling of those cylinders? Anyone have details on that.
We have a O-320-E2G engine (77 Cheetah) with the 150 HP HC STC and short stack powerflow exhaust
Thanks in Advance
Bill Chambers
flyv35b(at)minetfiber.com Guest
Posted: Wed Oct 19, 2011 12:17 pm Post subject: High CHTS Cylnder Baffles for 3 & 4 |
On 10/19/2011 12:17 PM, Bill wrote:
Hi,
Gary Vogt mentions a mod to the wraparound metal baffling for Cylinders 3& 4 , we are working on getting our High CHTS under control and attacking it step by step. Flexible baffling work is finished and has helped ~ 20 degrees.
Thanks in Advance
Bill Chambers
What Gary is talking about is opening up the AREA on the bottom side of
the cylinder for less restriction and more air flow around and through
the fins on the back two cylinders. IOW, shortening the end of the
baffle that wraps around the back side of #3/#4. You will have to ask
him about how much, probably .75-1.0 in.
Cliff
teamgrumman(at)yahoo.com Guest
Posted: Thu Oct 20, 2011 9:48 am Post subject: High CHTS Cylnder Baffles for 3 & 4 |
Trim about 1 inch, maybe an inch and a quarter from each strap. Then cut off the corner (about 1/2 to 3/4 inch on a side) on a 45 degree angle, with the open end toward the CHT probe, then bend down the last 1/4 inch as a tab for the safety wire to tie the baffle together.
By-the-way, keeping the straps tight agains the cylinders is important. The #4 cylinder strap is compromised by the rivets on the baffle and the arrangement its riveted. It really needs a cover around the outside to close off the sides.
I think I have pics on my web site. Restorations page, look for baffles.
Gary
Sent: Wednesday, October 19, 2011 12:17 PM
Subject: High CHTS Cylnder Baffles for 3 & 4
--> TeamGrumman-List message posted by: Bill <metuna(at)earthlink.net (metuna(at)earthlink.net)>
Hi,
Thanks in Adv= the many List p; &n
