Re-enforced gear legs on John Hauck's Mark lll
nickc(at)mtaonline.net
PostPosted: Sun Oct 23, 2011 9:56 am    Post subject: Re-enforced gear legs on John Hauck's Mark lll Reply with quote
John,
Could you post a picture of the gear reinforcements you and Jim made when you built you Mark lll? I remember you saying that you repositioned the legs, but I have never seen a close up of the reinforcements you added to the base of your gear legs.
Thanks for sharing all you travels with us.
Nick Cassara
Kolbra #1
Palmer, Alaska
PostPosted: Sun Oct 23, 2011 2:17 pm    Post subject: Re-enforced gear legs on John Hauck's Mark lll Reply with quote
I'll see if I can find a photo. I am away from my PC and other files and DVDs.
The main gear was moved forward 8". A 3/4" 4130 square tube bridge was fabricated inside the fuselage under the seats.
This puts a lot of weight on the tail wheel, making the MKIII a true tail dragger. One has to stay ahead of the aircraft on the ground or she will ground loop in a heart beat. On the other hand, I have never had a problem of my MKIII trying to get the tail up and nose over.
Mobile, Alabama
Nick Cassara[quote] [b]
PostPosted: Sun Oct 23, 2011 2:50 pm    Post subject: Re-enforced gear legs on John Hauck's Mark lll Reply with quote
Nick Cassara
Nick C/Gang: This is the best I can do until I get home. johnhmkIII
 Filesize:  152.51 KB
 Viewed:  2341 Time(s)
 Filesize:  187.25 KB
 Filesize:  162.49 KB
