flyingphil2
Posted: Mon Oct 10, 2011 4:27 am Post subject: Toe vs Finger Brakes |
I've not used either on a Europa.
Anyone got any opinions on which is better / worse and why?
pete(at)lawless.info Guest
Posted: Mon Oct 10, 2011 5:09 am Post subject: Toe vs Finger Brakes |
Hi Phil
I have flown one with toe brakes and I could not get my feet on the brakes
and rudder at the same time. It was all too tight for space in the
footwell.
Pete
peter.rees01(at)tiscali.c Guest
Posted: Mon Oct 10, 2011 5:41 am Post subject: Toe vs Finger Brakes |
In contrast to the experience below - we have been using the finger
brakes for about 5 years or so - very easy to get to grips with and
never any issues with getting to them when needed as they are right by
the throttle.
Peter
----Original Message----
Date: 10/10/2011 14:06
Subj: RE: Toe vs Finger Brakes
Hi Phil
brakes
footwell.
Pete
max8992
Posted: Mon Oct 10, 2011 6:24 am Post subject: Toe vs Finger Brakes |
The builder of our XS moved the toe brakes "unusables by standard feet" to hand brakes before he sold me the plane. Using it for one year+, very easy and efficient.
Max Cointe
F-PMLH Kit #560
912ULS Airmaster
390+ hours
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de peter.rees01(at)tiscali.co.uk
Envoyé : lundi 10 octobre 2011 15:38
À : europa-list(at)matronics.com
Objet : RE: Toe vs Finger Brakes
the throttle.
Peter
Hi Phil
brakes
footwell.
Pete
_________________ Max8992
Europa XS #560 F-PMLH |
flyingphil2
Posted: Mon Oct 10, 2011 8:04 am Post subject: Re: Toe vs Finger Brakes |
Thanks for the replies - very conclusive.
Finger brakes it is then.
Phil
europapa
Posted: Tue Oct 18, 2011 11:39 am Post subject: Re: Toe vs Finger Brakes |
So, I am not so pleased with my finger brakes.
But I am not sure that I have the right braking cylinders.
My classic is a trigear conversion. I have seen in the builders manual there
are two types of cylinders used. Both have got an external brake fluid reservoir. My cylinders haven't got one. The right cylinder begins braking much earlier but I'm getting used to it. Even the brakes are very weak.
Maybe I should bleed them but have got no idea what kind of brake fluid the builders used.
I jealously looked at the breaking cylinders of an race kart, they seemed to have the same size.
Any suggestions?
Regards Juergen
max8992
Posted: Tue Oct 18, 2011 11:50 pm Post subject: Toe vs Finger Brakes |
Hi Jurgen,
We probably have the same configuration: our cylinders are the toe's one
moved up and arranged to be used by fingers (by the previous owner and
builder). They are the Matco ones described in the chapter CBM 33T of the
manual. The discrepancy between both are probably due to a lack of liquid in
one circuit. You must use MilH5606 liquid (the best way to get it is from a
JAR 145 maintenance workshop) to refuel but before you should verify first
that it is what you have into (the color red/pink is significant I think).
We've done that, not an easy task but we have now quite efficient breaking
equilibrated on both wheels.
To do it : remove the stopper of the cylinder visible on fig 1 of the CBM
33T of the manuals and replace it by a transparent pipe attached to a bleed
nipple and push the liquid from a syringe via the bleed nipple on the brake
caliper (visible on page 16 of the CBM 29T of the manuals). You're done when
you see the liquid run on the pipe without bubbles.
We also consider replacing the cylinders but there is a cost (in the Europa
catalog the conversion kit is 1000£+) and probably a bit a time to spend. So
far we will stay with the actual configuration.
Max Cointe
F-PMLH TriGear Kit #560
912ULS Airmaster 400 hours
[mailto:owner-europa-list-server(at)matronics.com] De la part de europapa
Envoyé : mardi 18 octobre 2011 21:39
Objet : Re: Toe vs Finger Brakes
builders used.
have the same size.
Any suggestions?
Regards Juergen
http://forums.matronics.com/viewtopic.php?p=355453#355453
g-iani(at)ntlworld.com Guest
Posted: Wed Oct 19, 2011 1:32 am Post subject: Toe vs Finger Brakes |
Jurgen
As far as I can tell the advise from Max is correct.
You almost certainly have a finger brake conversion which consists of moving
the original foot cylinders. So filling is as Max describes. This was an
early "fix" to get finger brakes and not supported by Europa. If filled and
bleed correctly they work but early versions had short levers (not enough
leverage) so breaking was limited. The simple solution (longer levers)
works better but puts the handles very high (and they look unsightly).
The Europa design improved the position and leverage but unfortunately the
first master cylinder (Jama) proved to be very poor quality. The final
redesign using Matco cylinders is much better.
A large part of the cost of the Europa kit is for the moulding etc used to
mount the master cylinder. The Matco cylinders are reasonably priced at
about $90 each from Matco (but make sure you get the correct cylinders). If
you are prepared to make you own mount and levers then you can convert at a
reasonable cost.
The documentation of Mod 65 shows the Jama setup and has not been updated.
The main manual CBM 33T (3) does give details of the Matco setup (but it
does contain some detailed error which have yet to be corrected).
I suggest you get your existing setup working properly before you decide on
an upgrade. If you decide to upgrade I will be happy to supply details of
what others have done and the corrections for the Matco setup.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
europapa
Posted: Thu Oct 20, 2011 11:40 am Post subject: Re: Toe vs Finger Brakes |
Hello Max and Ian,
thank you so much for your support.
So much specific know how in just two replies!
Today I inspected my brake setup and found it like Max expected.
The toe brakes have been converted. That means screwed together and fixed anyhow.
First I will try to adjust the fluid quantity. and perhaps will build longer levers.
But the first problem I have to solve is getting access to the lock screws as there is no opening in the cockpit.
All in all not a big peace of engineering.
Will come back to you.
Thank you again
Juergen
Kit 161
max8992
Posted: Fri Oct 21, 2011 9:19 am Post subject: Toe vs Finger Brakes |
Hi Juergen,
Our levers have been extended by almost 10cm. We don't have either access
via the cockpit, so access is almost acrobatic via underneath...
Good luck!
Max Cointe
Envoyé : jeudi 20 octobre 2011 21:40
Hello Max and Ian,
anyhow.
levers.
Thank you again
Juergen
Kit 161
http://forums.matronics.com/viewtopic.php?p=355589#355589
