redrocketrider
Joined: 13 May 2011 Posts: 67 Location: Nervino airport
Posted: Tue Oct 18, 2011 6:22 am Post subject: EGT question |
Hello KF Flyers, Food for thought? The EGT on our 80 HP Rotax goes up when you retard the throttle to 5000 rpm and it actually pegs the gauge.(west tach) If you run full power(at) 5350 rpm it stays at 1550 to 1575 degrees. It has a new probe, plugs are good, Carbs are stock jetting from the factory and needle jet I confirmed settings with Lockwood, and the BING manual, It really runs great except this issue. I do not want to cause a future problem. BTW the ship has done this from day one, I recently confirmed this with the builder. It has 310 Hrs. It has only one EGT probe and it is at the factory suggested location. Right rear exhaust. Anyone have any ideas. Thanks,
Toodie & Bob Marshall
Beckwourth, CA
KF/4/1200 flying
_________________ Keep the dirty side down/Blue skies. Bob |
Lynn Matteson
Posted: Tue Oct 18, 2011 8:56 am Post subject: EGT question |
Could the timing be retarded by any chance? A late timing setting
will allow fuel to be still burning as the exhaust valve.....oops! Is
this a two-stroke engine? Maybe the same laws apply? I have recently
discovered that my Jabiru engine will respond with much lower EGT's
when the timing is advanced, so a late timing should increase the
EGT's, I would think.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: down for repair....
On Oct 18, 2011, at 10:19 AM, rtmarshall wrote:
| Quote: | Hello KF Flyers, Food for thought? The EGT on our 80 HP Rotax
ideas. Thanks,
Beckwourth, CA
KF/4/1200 flying
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
clint_bazzill(at)hotmail. Guest
Posted: Tue Oct 18, 2011 9:11 am Post subject: EGT question |
Hi Bob,
It sounds to me like you may be over pitched on your prop. If you can only get 5350 with full power would indicate too much pitch. If you could check your MP, you would find it very high.
Clint
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: EGT question
Date: Tue, 18 Oct 2011 12:52:02 -0400
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Jabiru 2200, #2062
> ideas. Thanks,
> Beckwourth, CA
> KF/4/1200 flying
> === Archive Search & Download, 7-Day Browse, Chat, FAQ,
redrocketrider
Posted: Tue Oct 18, 2011 9:37 am Post subject: EGT question |
Hi Clint, I should have said the 5350 was in a climb configuration, the issue is not at full power but when I pull back on the throttle to go to cruise at 5000 RPM that the EGT goes up. It is a 80 HP four stroke Rotax. thanks for the help.
Beckwourth, CA
KF/4/1200 flying
Sent: Tuesday, October 18, 2011 10:09 AM
[quote] To: Kitfox list (kitfox-list(at)matronics.com)
Subject: RE: EGT question
Hi Bob,
Clint
> From: lynnmatt(at)jps.net (lynnmatt(at)jps.net)
| Quote: | Subject: Re: EGT question
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Lynn Matteson
Jabiru 2200, #2062
> ideas. Thanks,
> Beckwourth, CA
> KF/4/1200 flying
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
redrocketrider
Posted: Tue Oct 18, 2011 10:24 am Post subject: EGT question |
BTW Clint: enjoyed your trip up the coast to SF Golden Gate bridge.... looked like a really nice flight...........thanks for sharing because, I use to fly gliders at Hummingbird Haven just east of the Livermore airport long ago. Started flying at Warm Springs (now gone) then up to Centerville (now gone)/Fremont and then out to Livermore (now gone) The glider guys now fly from Bryon and the Sierra's in summer. Never got over to Half Moon Bay, but Bob did when he was instructing out of Concord/Buchannan Airport. Appreciate the soft air...........not so in the Sierra's! Get's wild up here.... Toodie
[quote] From: rtmarshall (rtav8or2(at)psln.com)
Sent: Tuesday, October 18, 2011 10:34 AM
Beckwourth, CA
KF/4/1200 flying
| Quote: | To: Kitfox list (kitfox-list(at)matronics.com)
Hi Bob,
Clint
Lynn Matteson
Jabiru 2200, #2062
> ideas. Thanks,
> Beckwourth, CA
> KF/4/1200 flying
| [b]
kerrjohna(at)comcast.net Guest
Posted: Tue Oct 18, 2011 11:05 am Post subject: EGT question |
Roger Lee
Posted: Tue Oct 18, 2011 4:05 pm Post subject: Re: EGT question |
Two things are going on. First re-pitch your prop to get between 5500-5600. This will unload the engine and let it run a little cooler and it is less stress on the engine. Everyone with a 912 should run at least 5500 rpm WOT. Second the Rotax 912 series engine runs hotter down at lower rpms (4600-4900) and cooler at the higher rpm (i.e. 5100-5300). The 912 carbs run richer at the higher rpms and leaner in the mid range rpms.
So if you reduce the pitch to get over 5500 WOT and run at 5100-5200 in cruise you should see lower temps.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Paul A. Franz, P.E.
Posted: Wed Oct 19, 2011 1:08 am Post subject: EGT question |
On Tue, October 18, 2011 10:34 am, rtmarshall wrote:
| Quote: | Hi Clint, I should have said the 5350 was in a climb configuration, the issue is not
Beckwourth, CA
KF/4/1200 flying
Bob - I think Clint meant you'd have the problem at full throttle too if you have too
much pitch angle.
To: Kitfox list
Hi Bob,
Clint
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Jabiru 2200, #2062
> Electroair direct-fire ignition system
> > ideas. Thanks,
> > Beckwourth, CA
> > KF/4/1200 flying
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
_________________ Paul A. Franz, P.E.
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Roger Lee
Posted: Wed Oct 19, 2011 5:56 am Post subject: Re: EGT question |
If you have too much pitch then all temps tend to be higher at take off and cruise. Many have resolved their temp issues with just a prop re-pitch.
Tucson, Az.
Cell 520-349-7056 |
redrocketrider
Posted: Wed Oct 19, 2011 6:24 am Post subject: EGT question |
Thanks to all for the suggestions, Will try them.
Beckwourth, CA
KF/4/1200 flying
Sent: Wednesday, October 19, 2011 6:56 AM
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center - Heavy Maint. Rated
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=355509#355509
