jimpuglise(at)comcast.net Guest
Posted: Tue Oct 18, 2011 4:03 pm Post subject: Flap Actuator Tube |
The DAR was here to day and found several discrepancies. The one that should not have been is an incomplete weld on one of the brackets on the flap actuator tube. If you have not yet installed it, check the welds on it. It appears that some of them were delivered from the factory only tack welded. Much easier to fix before it goes into the plane.
Jim Puglise
A283
