601 xl nose wheel fork dimension
mtherr(at)yahoo.com
PostPosted: Sun Oct 16, 2011 6:21 am    Post subject: 601 xl nose wheel fork dimension Reply with quote
Can anyone provide me the dimensions of the fork? (height, width) and fork doubler? Pls, specify if width is from inside or outside the fork. I would like to start fabrication of shafts and forks today for my new wheels.
Thanks!
sabrina
PostPosted: Sun Oct 16, 2011 10:39 am    Post subject: Re: 601 xl nose wheel fork dimension Reply with quote
bryanmmartin
PostPosted: Sun Oct 16, 2011 10:58 am    Post subject: Re: 601 xl nose wheel fork dimension Reply with quote
Thanks!
Here's the letter I downloaded.
601xl-nose-wheel-fork-letter.pdf
 Filename:  601xl-nose-wheel-fork-letter.pdf
 Filesize:  99.49 KB
 Downloaded:  505 Time(s)
Bryan Martin
do not archive.
bryanmmartin
PostPosted: Sun Oct 16, 2011 11:02 am    Post subject: 601 xl nose wheel fork dimension Reply with quote
That's got to be a typo. My original plans (04/01) did not include the doubler. A letter was sent out via the zenith website by Chris in December of 2004 recommending that a doubler be added. This PDF file included dimensioned drawings showing an inside dimension of 150mm for the doubler. There must have been a typo made when your version of the plans were updated. I would imagine that it has been corrected since.
I also notice that the drawing you uploaded shows a 3/4" hole for the axle. My axle is 5/8". I don't know if that is also a typo or if the axle diameter changed somewhere along the way.
On Oct 16, 2011, at 2:39 PM, Sabrina wrote:
The plans are misleading...
they show the outer dimension of the fork as 150 and the inner dimension of the doubler as 160.
my fork has an outside dimension of 160mm (nearly 170 counting the doubler) and an inner dimension 150+
requiring additional shims beyond the two 31mm spacers provided...
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
do not archive.
Bryan Martin
do not archive.
sabrina
PostPosted: Sun Oct 16, 2011 11:04 am    Post subject: Re: 601 xl nose wheel fork dimension Reply with quote
mtherr(at)yahoo.com
PostPosted: Sun Oct 16, 2011 12:24 pm    Post subject: 601 xl nose wheel fork dimension Reply with quote
Thanks all who responded on the list or private... I have the answer now.
Michel
Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601
http://pages.infinit.net/mthobby
Sent: Sunday, October 16, 2011 3:04:37 PM
Subject: Re: 601 xl nose wheel fork dimension
--> Zenith601-List message posted by: "Sabrina" <chicago2paris(at)msn.com (chicago2paris(at)msn.com)>
My plans are dated August of 2005, or 9 months after the CH letter...
I agree, the letter is less confusing than the plans...
http://forums.matronics.com/viewtopic.php?p=355216#355========================http://www.matronics.com/Navigat - MATRONICS WEB FORUMS -<= -->
malcolmhunt(at)mha1.fsbus
PostPosted: Sun Oct 16, 2011 12:47 pm    Post subject: 601 xl nose wheel fork dimension Reply with quote
Dear list can anyone from the CH750 community reading this list provide similar information for that aircraft as the plans I have the new radiused fork and I would like to build with the bent forks and doubler – thanks in advance.
Malcolm Hunt CH601XL builder and contemplating the STOL CH 750
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Michel Therrien
Sent: 16 October 2011 21:21
Subject: Re: Re: 601 xl nose wheel fork dimension
Michel
[/url][url=http://www.matronics.com/contribution][/url][url=http://www.matronics.com/contribution][/url][url=http://www.matronics.com/contribution][b][u]http://www.matronics.com/Navigator?Zenith601-List< - MATRONICS WEB FORUMS -
__________ Information from ESET Smart Security, version of virus signature database 6548 (20111016) __________
The message was checked by ESET Smart Security.
JohnDRead(at)aol.com
PostPosted: Sun Oct 16, 2011 2:58 pm    Post subject: 601 xl nose wheel fork dimension Reply with quote
If you have the axle that should give you the inside dimension for the inside doubler fork. One could always look on the drawings too!
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 10/16/2011 1:01:50 P.M. Mountain Daylight Time, bryanmmartin(at)comcast.net writes:
--> Zenith601-List message posted by: "bryanmmartin" <bryanmmartin(at)comcast.net>
Thanks!
Bryan Martin
do not archive.
http://forums.matronics.com/viewtopic.php?p=355215#355215
http://forums.matronics.com//files/601xl_nose_wheel_fork_letter_8 se the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
mtherr(at)yahoo.com
PostPosted: Sun Oct 16, 2011 4:48 pm    Post subject: 601 xl nose wheel fork dimension Reply with quote
I don't. I will fabricate the axle too.
Sent from my BlackBerry device on the Rogers Wireless NetworkFrom: JohnDRead(at)aol.com
Sender: owner-zenith601-list-server(at)matronics.com
Date: Sun, 16 Oct 2011 18:55:49 -0400 (EDT)
To: <zenith601-list(at)matronics.com>
ReplyTo: zenith601-list(at)matronics.com
Subject: Re: Zenith601-List: Re: 601 xl nose wheel fork dimension
If you have the axle that should give you the inside dimension for the= =20 inside doubler fork. One could always look on the drawings too!
Regards,=20 John
Cell: 719-494-4567
Hom= e:=20 303-648-3261=20
In a message dated 10/16/2011 1:01:50 P.M. Mountain Daylight Time,=20 bryanmmartin(at)comcast.net writes:
= -->=20 Zenith601-List message posted by: "bryanmmartin"=20 <bryanmmartin(at)comcast.net>
mtherr(at)yahoo.com wrote:>=20 Can anyone provide me the dimensions of the fork? (height, width) and for= k=20 doubler?   Pls, specify if width is from inside or outside the= =20 fork.  I would like to start fabrication of shafts and forks today f= or my=20 new wheels.
Thanks!
Here's the letter I= =20 downloaded.
Bryan Martin
N61BM, CH 601 XL,= =20 Stratus Subaru.
do not archive.
Read this topic onl= ine=20 here:
http://forums.matronics.com/viewtopic.php?p=3D355215#355215<= BR>
Attachments:=20
http://forums.matronics.com//files/601xl_nose_wheel_fork_letter_8= =20 se the=20 ies=20 ay=20              - MATRONICS WEB FORUMS=20            - List Contribution Web Site=20 p;  =20                     &nb= sp;=20
[/quote]
