		rob10(at)tlb.sympatico.ca Guest
				 Posted: Sun Oct 16, 2011 7:43 am    Post subject: elevator assembly bolt |
				I read many messages about the elevator assembly bol at the end of the elevator rod. I was going to change for an hex bolt to make it easier to remove and install at annual inspection
 An aviation mechanic told me that the clevis slotted bolt is meant to work in a shear situation, like the assembly we got on our Kitfox, while the hex bolt is for tension load.
 So, I understand there is a difference between those bolts ane should keep using the recommended clevis shear bolt for that application.
 Am I wrong with this?
 Jack
 Model 4- 912 UL
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		57_kid
				 Posted: Sun Oct 16, 2011 8:01 am    Post subject: elevator assembly bolt |
				I would advise using the correct bolt but as it is an experimental you have the option of experimenting with this bolt….at your own peril
 Steve
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of rosane
 Sent: Sunday, October 16, 2011 10:41 AM
 Subject: elevator assembly bolt
 Jack
 Model 4- 912 UL 	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Kitfox-List  | 	  0123456789
 Checked by AVG - www.avg.com
 Version: 2012.0.1831 / 10/15/11
		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
				 Posted: Sun Oct 16, 2011 2:23 pm    Post subject: Re: elevator assembly bolt |
				Here's the AC43.13-1B description of the bolts.
 http://www.google.com/url?sa=t&source=web&cd=1&ved=0CCMQFjAA&url=http%3A%2F%2Frgl.faa.gov%2FRegulatory_and_Guidance_Library%2FrgAdvisoryCircular.nsf%2F0%2F99c827db9baac81b86256b4500596c4e%2F%24FILE%2FChapter%252007.pdf&rct=j&q=ac%2043.13-1b%20chapter%207&ei=P1WbToJ95piJAovWwKoN&usg=AFQjCNHY0R3h15PB4iLsDuKUnWf-YEtkKg&sig2=n9-WnC4eJEtyZu9Wcbpiiw&cad=rja
  	  | Quote: | 	 		  7-41. STANDARD AIRCRAFT HEX
 HEAD BOLTS (AN3 THROUGH AN20).
 These are all-purpose structural bolts used for
 general applications that require tension or
 shear loads. Steel bolts smaller than
 No. 10-32, and aluminum alloy bolts smaller
 than 1/4 inch diameter, should not be used in
 primary structures. Do not use aluminum bolts
 or nuts in applications requiring frequent removal
 for inspection or maintenance.
 7-50. CLEVIS BOLTS (AN21
 THROUGH AN36). These bolts are only
 used in applications subject to shear stress, and
 are often used as mechanical pins in control
 systems. |
 I'm not an A&P but my understanding is hex bolts are used in both shear and tension loads.  Clevis bolts are only used in applications subject to shear stress.
 Clevis bolts have the flat slotted head and short threads for a thin AN364 shear nut.  This is needed for the clearance from the fabric at the rear of the tube.
 You will note in your kitfox manual that the foreword end of the elevator control tube uses a hex bolt through the rod end connected to the control column.  In the control column a hex bolt on the right side where there is room and a clevis bolt on the left side where the clearance is needed.
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		occom
				 Posted: Sun Oct 16, 2011 3:54 pm    Post subject: elevator assembly bolt |
				Perhaps I am missing something. I never experienced a bit of angst about
 this bolt. I noticed a lack of room and quickly burned a hole in the fabric
 so I could hit it with a straight screwdriver. Then I used the hole to pass
 the wires for the trim servo out of the fuselage. To reverse the procedure,
 unplug the wires, pass 'em back inside and raise the elevator to line the
 bolt up with the hole.
 Dave G. KF IV 582 Warp
