Door hinge?
galinhdz(at)gmail.com
PostPosted: Mon Oct 10, 2011 11:07 am    Post subject: Door hinge? Reply with quote
Where can I get a set of door hinges for the KIS-4? The hinge pin on my copilot door sheared off. Since I will have to replace it, I might as well replace both of them. Were the original ones made up by Lyle Hendricks?
Galin [quote][b]
fredorosa(at)gmail.com
PostPosted: Mon Oct 10, 2011 1:45 pm    Post subject: Door hinge? Reply with quote
I could use a set too.  The passenger side door bumps the top when fully open so I need to drill the holes in the hinge in a different location.
Al
On Mon, Oct 10, 2011 at 3:06 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote]Where can I get a set of door hinges for the KIS-4? The hinge pin on my copilot door sheared off. Since I will have to replace it, I might as well replace both of them. Were the original ones made up by Lyle Hendricks?
Galin
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
PostPosted: Mon Oct 10, 2011 3:09 pm    Post subject: Door hinge? Reply with quote
Well that means we need at least 4 hinges. Maybe was can get some machine company (Like Hendricks) to make a batch of them. The more we have made up the better the price will be. Plus, it will provide us a place we can get more if we need them in the future.
Galin
On Mon, Oct 10, 2011 at 4:45 PM, ALFRED ROSA <fredorosa(at)gmail.com (fredorosa(at)gmail.com)> wrote:
[quote]I could use a set too.  The passenger side door bumps the top when fully open so I need to drill the holes in the hinge in a different location.
Al
Galin
PostPosted: Mon Oct 10, 2011 4:25 pm    Post subject: Door hinge? Reply with quote
I would guess Lyle made them.  Rich would know.
Al
On Mon, Oct 10, 2011 at 7:08 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote]Well that means we need at least 4 hinges. Maybe was can get some machine company (Like Hendricks) to make a batch of them. The more we have made up the better the price will be. Plus, it will provide us a place we can get more if we need them in the future.
Galin
Al
Galin
PostPosted: Thu Oct 13, 2011 3:00 pm    Post subject: Door hinge? Reply with quote
I contacted Lyle Hendricks to see if he made the original hinges. I sent him a detailed drawing with dimensions and photos of my broken hinge. He will check and see if he has the setup needed to make a production run. If not, he can still do it but at a higher cost. He also said that the bigger the production run the lower the individual cost will be and that the minimum run is 8 units. He estimates that for 8 units the cost will be about $40.00 for each hinge. He also said he can have them made up in about 2weeks.
If you want new hinges let me know so I can try to convince him to make a production run and maybe get a lower price per hinge.
Galin
On Mon, Oct 10, 2011 at 7:24 PM, ALFRED ROSA <fredorosa(at)gmail.com (fredorosa(at)gmail.com)> wrote:
[quote]I would guess Lyle made them.  Rich would know.
Al
Galin
Al
Galin
PostPosted: Fri Oct 14, 2011 4:09 am    Post subject: Door hinge? Reply with quote
Galin,
I solved my problem using the original hinges so I wont need new ones.  You might be able to bring a hinge to a local machine shop to make a pair at less cost.  Also, if you can get away with just one side of the hinge new it would further reduce costs.
Al
On Thu, Oct 13, 2011 at 6:59 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote] I contacted Lyle Hendricks to see if he made the original hinges. I sent him a detailed drawing with dimensions and photos of my broken hinge. He will check and see if he has the setup needed to make a production run. If not, he can still do it but at a higher cost. He also said that the bigger the production run the lower the individual cost will be and that the minimum run is 8 units. He estimates that for 8 units the cost will be about $40.00 for each hinge. He also said he can have them made up in about 2weeks.
Galin
Al
Galin
Al
Galin
