Question to Ivor on Texel video
zwakie
PostPosted: Mon Oct 10, 2011 4:25 am    Post subject: Question to Ivor on Texel video Reply with quote
Ivor,
I found your youtube video of your landing for the 3rd Dutch GA Flyin (http://youtu.be/iM1txjU7Mm4).
Nice demonstration of what SmartASS does! I was wondering, what are those "EGT" calls for, f.i. on short final and when parking your plane?
(if only I had known you were taping your landing... OMG, my calls at 2:10 and 4:50 are BLASTING through your cockpit Wink Laughing)
Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR
pete(at)lawless.info
PostPosted: Mon Oct 10, 2011 5:06 am    Post subject: Question to Ivor on Texel video Reply with quote
Marcel
Are you going to share the youtube link with the rest of us?
Pete
DO NOT ARCHIVE
zwakie
PostPosted: Mon Oct 10, 2011 6:10 am    Post subject: Re: Question to Ivor on Texel video Reply with quote
Pete,
Did the link not come through in the original posting? Well, here it is once more: http://youtu.be/iM1txjU7Mm4
Ivor: I watched a few more of your videos and I discovered you have the EGT's and CHT's called out, so I found the answer to my question.
Marcel
Marcel Zwakenberg
PostPosted: Mon Oct 10, 2011 6:58 am    Post subject: Question to Ivor on Texel video Reply with quote
Thanks I will enjoy!
DO NOT ARCHIVE
PostPosted: Mon Oct 10, 2011 9:20 am    Post subject: Question to Ivor on Texel video Reply with quote
Hey Marcel
It's just like flying with my wife in the right hand seat!
Pete
DO NOT ARCHIVE
Ivor Phillips
Hi Marcel
I have the EGT/CHT Parameters set a bit fine on the Dynon so when i close the throttle
the EGT's give a warning of low temps but they are still well from their minimum,
They are on my list of things to do this winter[img]cid:ntlworld_com.361(at)goomoji.gmail[/img] to reduce false warnings,
best wishes
Ivor
On 10 October 2011 13:25, zwakie <mz(at)cariama.nl (mz(at)cariama.nl)> wrote:
--> Europa-List message posted by: "zwakie" <mz(at)cariama.nl (mz(at)cariama.nl)>
Ivor,
I found your youtube video of your landing for the 3rd Dutch GA Flyin ().
(if only I had known you were taping your landing... OMG, my calls at 2:10 and 4:50 are BLASTING through your cockpit [Wink] [Laughing])
Marcel
(Europa Classic Tri-Gear PH-MZW)
http://forums.matronics.com/viewtopic.php?p=354498#354498
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
 Filesize:  226 Bytes
 Viewed:  6178 Time(s)
Trevpond(at)aol.com
PostPosted: Mon Oct 10, 2011 2:11 pm    Post subject: Question to Ivor on Texel video Reply with quote
Iver,
I thought mine was bad with the Garmin 695 telling me about terrain and that I should pull up, accompanied by the ZAON XRX telling me about traffic, usually just as I'm turning finals!!
regards
Trev
G-LINN
In a message dated 10/10/2011 18:21:03 GMT Daylight Time, pete(at)lawless.info writes:
[quote]--> Europa-List message posted by: "Pete Lawless" <pete(at)lawless.info>
Hey Marcel
Pete
DO NOT ARCHIVE
Ivor Phillips
PostPosted: Mon Oct 10, 2011 11:28 pm    Post subject: Question to Ivor on Texel video Reply with quote
Hi Trev
To be fair The Dynon  works very well and is normally quiet, But once the throttle's are closed then all  EGT/CHT's
drop and trigger a alarm, this winter i will reset the parameters to reduce them,
 On the upside once i forgot to switch the Turbo waist gate on (Pilot error) and had a high manifold pressure warning on take off that could have caused damaged to the 914 but was easily rectified by pulling off the power, and also i had a low fuel pressure warning when i did my initial testing due to a fuel filter blockage again easily sorted by changing to reserve, I am not saying i wouldn't have noticed it at some point but the Dynon gives you some vital seconds to use if needed,
So all in all more warnings in my book are better than blindly assuming every thing is OK, Additionally i like to keep my eyes out of the cockpit as much as possible and aural warnings are a good way to achieve this IMHO
Best wishes
Ivor
On 10 October 2011 23:06, <Trevpond(at)aol.com (Trevpond(at)aol.com)> wrote:
[quote] Iver,
regards
Trev
G-LINN
In a message dated 10/10/2011 18:21:03 GMT Daylight Time, pete(at)lawless.info (pete(at)lawless.info) writes:
--> Europa-List message posted by: "Pete Lawless" <pete(at)lawless.info (pete(at)lawless.info)>
Hey Marcel
Pete
DO NOT ARCHIVE
trevpond(at)aol.com
PostPosted: Tue Oct 11, 2011 1:32 am    Post subject: Question to Ivor on Texel video Reply with quote
Iver,
What Dynon are you using? Mine is a
10" Skyview.
Trev
On 11 Oct 2011, at 08:26, PHILLIPS I <ivor.phillips(at)ntlworld.com (ivor.phillips(at)ntlworld.com)> wrote:
[quote]Hi Trev
Best wishes
Ivor
On 10 October 2011 23:06, <[url=mailto:Trevpond(at)aol.com]Trevpond(at)aol.com (Trevpond(at)aol.com)[/url]> wrote:
[quote] Iver,
regards
Trev
G-LINN
In a message dated 10/10/2011 18:21:03 GMT Daylight Time, [url=mailto:pete(at)lawless.info]pete(at)lawless.info (pete(at)lawless.info)[/url] writes:
--> Europa-List message posted by: "Pete Lawless" <[url=mailto:pete(at)lawless.info]pete(at)lawless.info (pete(at)lawless.info)[/url]>
Hey Marcel
Pete
DO NOT ARCHIVE
