uvtreith(at)t-online.de Guest
Posted: Fri Oct 07, 2011 12:42 am Post subject: AW: CAD file of instrument panel |
Hi Jürgen,
Instrument panels you can get from Europa Aircraft for quite small money. They also have panel cuts with the Dynon D 100.
I have made my aluminium panels by myself. It needs some time but you can place your instruments where you want (see picture).
Good Luck,
Bruno
-----Ursprüngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von europapa
Gesendet: Donnerstag, 6. Oktober 2011 22:54
An: europa-list(at)matronics.com
Betreff: CAD file of instrument panel
--> Europa-List message posted by: "europapa" <jubu(at)onlinehome.de>
Hi,
I am about to make a new instrument panel and will replace all my vacuum driven avionics with an Dynon D-100.
I would like to use a laser cut service but the laser will only move with the right software.
I am absolutely unexperienced in this matter.
Has somebody got a file of the shape of the main panel?
Or can somebody help me with the whole project?
Where can I find the plate to close the whole where the vacuum pump has been mounted?
Thank you
Juergen
D-EBOA
http://forums.matronics.com/viewtopic.php?p=354215#354215
237.45 KB |
2895 Time(s) |
235.67 KB |
2895 Time(s) |
450.84 KB |
2895 Time(s) |
europapa
Posted: Fri Oct 07, 2011 7:15 am Post subject: Re: AW: CAD file of instrument panel |
Thank you Bruno!
I am convinced, think some work is better than trouble with incompatible files and wrong laser cuts.
Juergen
