601 XL bearing bloc material
Goto page 1, 2  Next
mtherr(at)yahoo.com
PostPosted: Mon Oct 03, 2011 3:38 am    Post subject: 601 XL bearing bloc material Reply with quote
Hello group,
As part orf my 601 renovation project, I want to replace the lower nose wheel fork bearing with the newer style 601 XL plastic bloc. I would like to know what material is mandated (delrin, nylon, acetal, UHMWE?) and what is the thickness.
Thanks!
Michel
Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601
http://pages.infinit.net/mthobby
To: Zenith-List <zenith-list(at)matronics.com>
Sent: Wednesday, September 28, 2011 2:46:58 PM
Subject: access panel drawing
Hi guys,
I’ve had a few people ask about a drawing for the inspection panels I use on my 601HDS.
The link below will get you to the drawing on my site and clicking the drawing at the bottom
of the page will get you to a larger image that’s printable. The panels serve my plane well
and have never given any difficulty.  If you want to make a set of these, the drawing is
a good guide.
http://www.macsmachine.com/html/winginsppanels.htm
Fly safe guys,
el=nofollow target=_blank>http://www.matronics.com/Navigator?Zenith-List
psm(at)att.net
PostPosted: Mon Oct 03, 2011 4:09 am    Post subject: 601 XL bearing bloc material Reply with quote
Hi Michael,
I'm not sure whether mine is the old or new stuff, but I think it is Nyloil -- oil impregnated nylon.
Paul
XL in flight test
On 10/3/2011 4:35 AM, Michel Therrien wrote: [quote] Hello group,
Thanks!
Michel
From: Larry McFarland <larry(at)macsmachine.com> (larry(at)macsmachine.com)
To: Zenith-List <zenith-list(at)matronics.com> (zenith-list(at)matronics.com)
Hi guys,
a good guide.
Fly safe guys,
Larry McFarland  601HDS at www.macsmachine.com
Ron Lendon
PostPosted: Thu Oct 06, 2011 6:14 pm    Post subject: Re: 601 XL bearing bloc material Reply with quote
Nyoil 1.5" thick is what I used. I think that's what the print called for also.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
mtherr(at)yahoo.com
PostPosted: Fri Oct 07, 2011 5:52 am    Post subject: 601 XL bearing bloc material Reply with quote
Thanks all! I received a square foot of the expensive plastic yesterday and i plan on machining the bearing during the weekend.
Ron Lendon, Detroit, MI
Zodiac XL, ScrapBuilder Wink
http://www.zenith.aero/profile/RonLendon
http://forums.matronics.com/viewtopic.php?p=354236#354236
naumuk(at)windstream.net
PostPosted: Fri Oct 07, 2011 1:15 pm    Post subject: 601 XL bearing bloc material Reply with quote
> WW Corvair with Roy's Garage 5th bearing
> http://www.mykitlog.com/rlendon
All-
I just tuned in to the thread, and I hate to say this, but every
installation I've seen was .5" thick, not 1.5". No wonder the raw
material was so expensive, Mike.
Ron, if your prints call for 1.5", they're wrong. I have Larry
Mac's beefed up (reinforcement ridge on the outboard side) bearings and
I estimate they can be machined out of 3/4" material. I'd say the
factory bearings could be made using a 3x6" piece of 1/2" stock.
Bill
Bill Naumuk
Zen/Vair 601MG
sabrina
PostPosted: Fri Oct 07, 2011 1:33 pm    Post subject: Re: 601 XL bearing bloc material Reply with quote
mtherr(at)yahoo.com
PostPosted: Fri Oct 07, 2011 2:01 pm    Post subject: 601 XL bearing bloc material Reply with quote
Oh, ratz! I will mill it down 0.004" before i cut the V groove Wink
PostPosted: Fri Oct 07, 2011 2:02 pm    Post subject: 601 XL bearing bloc material Reply with quote
On 10/07/2011 05:33 PM, Sabrina wrote:
6-G-2 08/05
38mm which is 1.496 or so inches thick...
http://forums.matronics.com/viewtopic.php?p=354325#354325
How thick is your bearing?
Bill
Bill Naumuk
Zen/Vair 601MG
JohnDRead(at)aol.com
PostPosted: Fri Oct 07, 2011 2:09 pm    Post subject: 601 XL bearing bloc material Reply with quote
I bet the tolerance on the groove depth is greater than 0.004! Oh! just turn on the metric on your calipers and make it to the print.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 10/7/2011 4:02:18 P.M. Mountain Daylight Time, mtherr(at)yahoo.com writes:
[quote]--> Zenith-List message posted by: mtherr(at)yahoo.com
craig(at)craigandjean.com
PostPosted: Fri Oct 07, 2011 2:17 pm    Post subject: 601 XL bearing bloc material Reply with quote
The question is do you want to match the XL dimensions or the ones of the
aluminum parts on the 701. The geometry on the 601XL is definitely beefier.
You can't make it as wide on the 701 because the vertical U channel is
narrower. And the depth of the v-grove is set by the existing parts: nose
gear tube (and its cross tube), distance from the bottom support plate to
the top gear bearing, etc.
On my fourth-hand 701 kit I cut down the 601XL part to fit the specifics of
my plane.
-- Craig
PostPosted: Fri Oct 07, 2011 2:22 pm    Post subject: 601 XL bearing bloc material Reply with quote
 Filesize:  35.26 KB
 Viewed:  15175 Time(s)
 Filesize:  34.07 KB
PostPosted: Fri Oct 07, 2011 2:28 pm    Post subject: 601 XL bearing bloc material Reply with quote
I don't think that the 601 part will fit the 701. I looked at my hangar buddies 601 and it is quite a lot different than the 701 arrangement. I was just going to make narrow blocks that fit inside the 701 brackets but are about 0.030 higher than the angles on the 701 parts.
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 10/7/2011 4:17:49 P.M. Mountain Daylight Time, craig(at)craigandjean.com writes:
[quote]--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com>
my plane.
-- Craig
sabrina
PostPosted: Fri Oct 07, 2011 2:34 pm    Post subject: Re: 601 XL bearing bloc material Reply with quote
PostPosted: Fri Oct 07, 2011 2:48 pm    Post subject: 601 XL bearing bloc material Reply with quote
> I don't think that the 601 part will fit the 701. Well, that’s what I did and it works. -- Craig
mtherr(at)yahoo.com
PostPosted: Fri Oct 07, 2011 3:49 pm    Post subject: 601 XL bearing bloc material Reply with quote
Bill, presently, mine is pretty much like yours... but I am upgrading to the XL design.
Sent: Friday, October 7, 2011 6:19:31 PM
Subject: Re: Re: 601 XL bearing bloc material
Mike, you have an HD or HDS, don't you? Different set up from the XL,
unless you upgraded. Whatever, best of luck. Check out the pix.
Bill Naumuk
Zen/Vair 601MG
mtherr(at)yahoo.com
PostPosted: Fri Oct 07, 2011 3:51 pm    Post subject: 601 XL bearing bloc material Reply with quote
That was a joke... did not notice the Wink?
An inspector told me that a plane is a collection of twisted parts that if well made, can fly straight...
From: "JohnDRead(at)aol.com" <JohnDRead(at)aol.com>
Sent: Friday, October 7, 2011 6:07:11 PM
Subject: Re: Zenith-List: Re: 601 XL bearing bloc material
Regards, John
Cell: 719-494-4567
Home: 303-648-3261
sabrina
PostPosted: Fri Oct 07, 2011 4:13 pm    Post subject: Re: 601 XL bearing bloc material Reply with quote
mtherr(at)yahoo.com
PostPosted: Fri Oct 07, 2011 4:36 pm    Post subject: 601 XL bearing bloc material Reply with quote
Certainly not because the original specs mandate only the aluminum plate as a bearing.
One thing i foud in the datasheet for Nyloil is that we must include a clearance ("shaft allowance") to prevent what you mention. Since that bearing does not really "work", i plan for less allowance than mandated (.003 or .004 instead of .009). I m sure that with Nylon 6, the clearance would be even more critical.
klaus(at)utdallas.edu
PostPosted: Sat Oct 08, 2011 3:46 am    Post subject: 601 XL bearing bloc material Reply with quote
Hi,
When we built our 601HDS 15 years ago, the bearings for nose gear
and landing gear were specified to be aluminum. Instead, we made
bearings out of Delrin.
Even with that change, we noticed rather soon that the dirt and
sand collecting on the nose gear was wearing not only the Delrin
but also the gear tube. To prevent further damage and reduce
the drag produced by the tube, we made a rather simple nose gear fairing,
see
http://utdallas.edu/~klaus/Airplane/nose_gear_fairing.html
Each year, we remove the fairing during the annual
inspection, clean the tube, add grease, and reinstall
the fairing. That process has eliminated the wear of
the tube and the bearing.
BTW, the 912 Rotax engine has passed 1400 hours,
without any sign of wear except that we have used
four (!) fuel pumps. Let's hope that the new pump design works.
Happy flying,
Klaus
mtherr(at)yahoo.com
PostPosted: Sat Oct 08, 2011 4:28 am    Post subject: 601 XL bearing bloc material Reply with quote
How long have your 601 been flying?  It is good to read about good longevity for our aircraft...
On Oct 8, 2011, at 7:44, Klaus Truemper <klaus(at)utdallas.edu (klaus(at)utdallas.edu)> wrote:
[quote]Hi,
see
Happy flying,
Klaus
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
ums.matronics.com">http://forums.matronics.com
http://www.matronics.com/contribution">http://www.matronics.com/contribution
Goto page 1, 2  Next
Page 1 of 2
