Oil Cooler move to below the Spinner
ward.t(at)xtra.co.nz
PostPosted: Wed Sep 28, 2011 12:29 pm    Post subject: Oil Cooler move to below the Spinner Reply with quote
Hi Marcel,
Pictures, hopefully, of the Oil cooler move to below the spinner without the snout added.
Remember my cooler was the original cooler for the Monowheel Kit # 292.
It is smaller then the XS model cooler. Originally it was piggy backed behind the port water
radiator for the Rotax 912 80HP however when the Rotax 912S came to the
market it produced more heat requiring a different cooling setup.
Then came the XS model with bigger cowlings to allow more leg room for the US market and a complete
redesign of the cooling system under the engine.
Tim
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz
 Filesize:  1.41 MB
 Viewed:  2261 Time(s)
 Filesize:  1.66 MB
Owner_Ward.vcf
 Filename:  Owner_Ward.vcf
 Filesize:  183 Bytes
 Downloaded:  340 Time(s)
zwakie
PostPosted: Thu Sep 29, 2011 2:11 am    Post subject: Re: Oil Cooler move to below the Spinner Reply with quote
Thanks Tim for the pictures.
I like your setup without a snout, but that's a matter of personal taste of course...
Do you have any pictures from the arrangement inside the cowl?
Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR
