frankm(at)clara.net Guest
Posted: Mon Oct 03, 2011 1:58 pm Post subject: Heavy in-flight vibration |
I suffered heavy in-flight vibration the other day. By the time I had checked t's and p's and voltage, and before I had time to switch on the fuel pump everything was back to normal. So I left everything as it was and returned to base with no further trouble. I checked engine mountings, propellor and fuel filter and carb float chambers and found quite severe felting of fine fibres round the filter, which I changed, and a minute amount of dirt in the bottom on one float chamber. The nature of the vibration felt as though the cylinders on one side of the engine had stopped firing; it did not feel like misfiring due to,eg, carb ice, and if it had been a blocked filter I think the engine would have stopped, and not started again until I changed tanks. If so that could only be a carburettor problem and I wondered if there had been a momentary vapour lock on one side, or possibly a sticking float valve stopping fuel flow to that side, perhaps cured by the vibration. Neither the OAT nor the engine were hot enough to make vapour a likely answer. I also wondered if I had picked up a child's helium balloon in the prop which blew off after a second or two. The next day I climbed straight up to 6,000' with no hint of trouble, so I have stopped worrying about it.
Frank Mycroft G-BWYD
