gregoryf.flyboy(at)comcas Guest
Posted: Thu Sep 15, 2011 2:30 pm Post subject: can one use 'glass' micro for filler?? |
Hello wonderful list,
I just purchased 5 lbs of glass micro to be used for filling movable wing surfaces. Having made some ding resistance and sanding tests with differing resin amounts, and to prove it is sandable (at least half as sandable, timewise, as superfil...depending on amount of resin added) , I see that the manual suggests to use thermoplastic spheres instead of the glass ones. My favorite aircraft mail supply shop does not seem to carry them. So I ask...what is wrong with using standard Aeropoxy and glass micro? I have no experience in filling surfaces so far, so any help is appreciated.
Greg Fuchs
alanb(at)dpy01.co.uk Guest
Posted: Thu Sep 15, 2011 9:35 pm Post subject: can one use 'glass' micro for filler?? |
I think the answer may be weight.
The glass version being heavier than the thermoplastic.
Alan
#0303
Greg Fuchs
keithhickling(at)clear.ne Guest
Posted: Thu Sep 15, 2011 10:31 pm Post subject: can one use 'glass' micro for filler?? |
I seem to remember that Europa also said the thermoplastic filler is easier to sand than the glass microspheres (providing you get the mix right).
Keith Hickling,
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Alan Burrill
Sent: Friday, 16 September 2011 5:32 p.m.
Subject: Re: can one use 'glass' micro for filler??
Alan
#0303
<![if !supportLineBreakNewLine]> <![endif]>
Greg Fuchs
Posted: Fri Sep 16, 2011 12:34 am Post subject: can one use 'glass' micro for filler?? |
Both are true, Expancell is lighter and easier to sand, especially if you lubricate the resin with Cabosil (colloidal silica) and increase the micro to resin ratio. Check it out with a small sample. You'll be amazed how much more Expancell will mix into the same amount of resin. The silica seems to reduce the surface tension of the resin and makes it wet the balloons better.
Graham
From: keith hickling <keithhickling(at)clear.net.nz>
Sent: Friday, 16 September, 2011 7:28:33
Subject: can one use 'glass' micro for filler??
Keith Hickling,
Alan
#0303
Greg Fuchs
[quote]ank" href="http://www.matronics.com/Navigator?Europa-List">http://www.mat"nofollow" target="_blank" href="http://forums.matronics.com">http://fo==========
Posted: Sun Sep 18, 2011 3:37 am Post subject: can one use 'glass' micro for filler?? |
Thank you for all the responses. Graham, I will have to try the colloidal silica along with the thermoplastic filler. BTW, where in the states is the best way to get the thermoplastic stuff? I have not seen Expancell listed in the main supply houses. Is the SUP*R-FIL solution similar to Expancel? Can it be obtained in the 'micro' form for example, without the binder pre-mixed with it?
Greg Fuchs, A050 TRI [quote][b]
