BobbyPaulk(at)comcast.net Guest
Posted: Tue Sep 13, 2011 6:15 am Post subject: JabiruEngine-List Digest: 8 Msgs - 09/12/11 |
List,
Thanks to all that responded to my Compression concerns.
I will run the engine and do it again hot. I did however pump the prop blade near TDC to help seat the rings which only added about one pound if that. Since it passed cold I have no problem flying it but I will do it again hot to see the results. I will post the results.
Thanks again
bobby
601 XL
Jab 3300
125 hrs
DO NOT ARCHIVE
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
norman.cowell(at)tiscali. Guest
Posted: Tue Sep 13, 2011 9:34 am Post subject: JabiruEngine-List Digest: 8 Msgs - 09/12/11 |
just to let you know Norman passed away 3.08.11. Would be much obliged if
you would cancell these messages.
Thank you
Mrs. P. Cowell
Posted: Thu Sep 15, 2011 12:48 pm Post subject: JabiruEngine-List Digest: 8 Msgs - 09/12/11 |
List,
I made it up to the hangar today and put the ram air ducts back on the engine and ran it up and down the taxi way until the oil was 120 deg. Brought it into the hangar and burned my fingers getting the plugs out. Guess what - Pete you were right. the compression came up into the mid 70's on all the cylinders that were down.
Thanks Pete
Bobby
Jab 3300
125 hrs.
