Scott
Posted: Sat May 20, 2006 11:27 am Post subject: SL-30 Nav Audio Connection... |
Is the Garmin SL-30 nav audio output (pins 20 and 23) only used if one has
an audio panel? If pins 20 and 23 are not used, is nav audio output on the
com side via pins 13 and 14? Or should the nav audio output (pins 20 and
23) be tied to the headphone circuit? Thanks for saving me the
experimentation.
-Scott Fifield
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Sat May 20, 2006 12:45 pm Post subject: SL-30 Nav Audio Connection... |
As part of the "setup" for the SL30, you are given the option of having the
NAV audio "mixed" with the COM audio. This will make the NAV audio also
appear on pins 13 and 14.
Scott
Posted: Sat May 20, 2006 2:48 pm Post subject: SL-30 Nav Audio Connection... |
Bill, and Aeroelectric Gang-
Thanks. That's exactly what I wanted to know.
Is it true that when the Nav is selected, the com side is disabled? If so,
the "mixing" of the com and nav on pins 13 and 14 would not be an issue. Is
there any advantage at all to using Nav Audio on pins 20 and 23 if I'm not
using an audio panel?
Thanks again-
Scott Fifield
