alan99gill(at)yahoo.co.uk Guest
Posted: Mon Sep 12, 2011 8:57 am Post subject: Electric flaps |
Hi all again
Have a person that has purchased a second hand Pulsar Series 1, 582 trigear. He wants to know if anyone has converted the flap control from hand operated to ELECTRIC flap.
Any photo, diagram and material used would be very useful.
Thanks again
Alan Gill
UK Pulsar Squadron Support.
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
otto(at)otamat.com Guest
Posted: Mon Sep 12, 2011 9:11 am Post subject: Electric flaps |
Hi Alan,
I have electric flaps on my Pulsar III. I am away from the plane now, but I can oblige with the build manual instructions, if OK.
Please advise.
regards
otto
On 12/09/2011 17:56, Alan Gill wrote: [quote] Hi all again
Thanks again
Alan Gill
w7ikt(at)fly-web.us Guest
Posted: Mon Sep 12, 2011 10:58 am Post subject: Electric flaps |
I converted to electric flaps with a linear actuator. Shortened the flap handle and put it between the seats. Actuator behind seats pules flap handle with a cable.
I'm in Ohio on a trip for September and plane is in TX to no pictures now.
God Bless
Bob Heiser
On 9/12/2011 11:56 AM, Alan Gill wrote: [quote] Hi all again
Thanks again
Alan Gill
briana(at)xtra.co.nz Guest
Posted: Mon Sep 12, 2011 11:53 am Post subject: Electric flaps |
Alan,
I built mine with electric flaps. Shortened the flap handle and installed it inside the centre console. It is operated by a linear actuator behind the seat, and a cable around a pulley mounted on the end of the flap handle. This arrangement sounds very similar to Bob Heiser. The pulley gives a 2:1 mechanical advantage, reducing the pull needed by the actuator.
I can sent some photos and a description, but can't include attachments on this list. If you email me privately I can respond.
Brian
jerry(at)craftworks.biz Guest
Posted: Mon Sep 12, 2011 2:52 pm Post subject: Electric flaps |
BRIAN AND ALL, I ALSO HAVE ELECTRIC FLAPS BUT I DID IT BACK IN THE DAYS
(1993) BEFORE THERE WAS A PULSAR GROUP, WHEN YOU HAD TO INVENT SOMETHING. I
WAS IN THE GARAGE LOOKING AT MY GARAGE DOOR OPENER AND DECIDED THAT WAS HOW
I COULD MAKE IT WORK, SO I TOOK A 12 VOLT DRILL AND CUT OFF THE BATTERY AND
WIRED IT INTO A SWITCH ON MY STICK AND USED LIMIT SWITCHES AND A PIECE OF
ALL THREAD AND LIKE YOU SHORTENED UP THE HANDLE SO IT WOULD FIT UNDER THE
CENTER CONSOLE. 14 YEARS AND 1,200 HOURS AND AT LEAST A THOUSAND LANDINGS
AND STILL WORKS GREAT. THE DRILL MOTOR IS MOUNTED BEHIND THE SEAT. I HAD
TO MAKE A MOUNT FOR THE MOTOR AND INSTALL A BEARING THAT WOULD TAKE THE LOAD
OF THE FLAPS SO WITH A LITTLE TINKERING I'VE NEVER HAD TO FOOL WITH IT. I
THINK THAT GRAND TOTAL OF MONEY SPENT ON MATERIALS...$100? JERRY
-----ORIGINAL MESSAGE-----
[MAILTO:OWNER-PULSAR-LIST-SERVER(at)MATRONICS.COM] ON BEHALF OF BRIAN ANDERSON
SENT: MONDAY, SEPTEMBER 12, 2011 3:52 PM
TO: PULSAR-LIST(at)MATRONICS.COM
SUBJECT: RE: PULSAR-LIST: ELECTRIC FLAPS
--> PULSAR-LIST MESSAGE POSTED BY: BRIAN ANDERSON <BRIANA(at)XTRA.CO.NZ>
ALAN,
I BUILT MINE WITH ELECTRIC FLAPS. SHORTENED THE FLAP HANDLE AND INSTALLED IT
INSIDE THE CENTRE CONSOLE. IT IS OPERATED BY A LINEAR ACTUATOR BEHIND THE
SEAT, AND A CABLE AROUND A PULLEY MOUNTED ON THE END OF THE FLAP HANDLE.
THIS ARRANGEMENT SOUNDS VERY SIMILAR TO BOB HEISER. THE PULLEY GIVES A 2:1
MECHANICAL ADVANTAGE, REDUCING THE PULL NEEDED BY THE ACTUATOR.
I CAN SENT SOME PHOTOS AND A DESCRIPTION, BUT CAN'T INCLUDE ATTACHMENTS ON
THIS LIST. IF YOU EMAIL ME PRIVATELY I CAN RESPOND.
BRIAN
mortweaver(at)sbcglobal.n Guest
Posted: Tue Sep 13, 2011 12:31 pm Post subject: Electric flaps |
Alan - I have a Pulsar XP (similar cabin dimension specs to Rotax 582 powered Pulsar Series I). I found a way to very simply retrofit to electric flaps using Fergelli 2 In. linear actuator. The actuator mounts in control stick tunnel, no intermediate cables or pulleys and no need to tear up seat bottom during retrofit process. I can provide pictures and my telephone number for assistance.
Dave Weaver N912GR
--- On Mon, 9/12/11, otto souta <otto(at)otamat.com> wrote:
Subject: Re: Electric flaps
To: pulsar-list(at)matronics.com
Date: Monday, September 12, 2011, 12:10 PM
Hi Alan,
Please advise.
regards
otto
On 12/09/2011 17:56, Alan Gill wrote: | Quote: | Hi all again
Thanks again
Alan Gill
el=nofollow target=_blank>http://www.matronics.com/Navigator?Pulsar-List
| [quote][b]
fgilmer(at)twlt.net Guest
Posted: Tue Sep 13, 2011 1:46 pm Post subject: Electric flaps |
David could you post the pictures to the group. I have an XP and would like to see how you setup the electric flaps.
If you have something you can email then send it to my email address of fgilmer(at)twlt.net
thanks Fred Gilmer
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of David Weaver
Sent: Tuesday, September 13, 2011 3:30 PM
Dave Weaver N912GR
Hi Alan,
Please advise.
regards
otto
Hi all again
Thanks again
Alan Gill
| Quote: | | el=nofollow target=_blank>http://www.matronics.com/Navigator?Pulsar-Listet=_blank>http://forums.matronics.comllow target=_blank>http://www.matronics.com/contribution |
| 0123456789012345678
CYard52306(at)aol.com Guest
Posted: Tue Sep 13, 2011 11:32 pm Post subject: Electric flaps |
In a message dated 13/09/2011 21:32:00 GMT Daylight Time, mortweaver(at)sbcglobal.net writes:
| Quote: | | Fergelli 2 In. linear actuator. |
Dave
I am currently using a linear actuator but it is large heavy and cumbersome, do you have the model number and lb force rating, is the two inch stroke the best fit.I have enclosed a picture of miy fitting.
Regards Cy
G-PLSA 912
1.12 MB |
11183 Time(s) |
1.12 MB |
11183 Time(s) |
1.12 MB |
11183 Time(s) |
Posted: Wed Sep 14, 2011 9:35 am Post subject: Electric flaps |
Thank you otto. Your build manual instruction would assist me.
Regardfs ...> Alan
Sent: Monday, 12 September 2011, 18:10
Hi Alan,
Please advise.
regards
otto
Thanks again
Alan Gill
http://www.matronics.com/Navigator?Pulsar-Listhttp========================
Posted: Fri Sep 16, 2011 5:09 am Post subject: Electric flaps |
Hi Alan,
please give me a few days, I have to get the scanner going.
regards
otto
On 14/09/2011 18:31, Alan Gill wrote: [quote] Thank you otto. Your build manual instruction would assist me.
Regardfs ...> Alan
From: otto souta <otto(at)otamat.com> (otto(at)otamat.com)
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Hi Alan,
Please advise.
regards
otto
Thanks again
Alan Gill
| [b]
