bifft(at)xmission.com Guest
Posted: Mon Sep 05, 2011 5:46 pm Post subject: Exhaust gasket fit. |
Hooking up the exhaust system, using a Vetterman exhaust on a O-360A1D.
The exhast flange seems to fit the engine just fine, but the gasket won't
go on. The slotted holes are just a hair too close together. Tried on
all three of the cylinders that have two studs (one is missing a stud,
didn't notice until I went to put stuff on tonight). The difference is
well under 1/16", is it Ok to file that slotted hole just a hair wider?
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 Engine stuff.
1/4 Starduster II N23UT flying
baremetl(at)gvtc.com Guest
Posted: Wed Sep 07, 2011 8:57 pm Post subject: Exhaust gasket fit. |
I don't know if it's okay, but it's what I have done numerous times with no
ill effects so far. Sure beats messing up the threads of the stud trying to
force the gasket on.
Ivan Haecker -4 1710 hrs. So. Cen. TX
Posted: Thu Sep 08, 2011 7:07 am Post subject: Exhaust gasket fit. |
On Wed, 7 Sep 2011, H. Ivan Haecker wrote:
Thanks, tried one last night just to see, had to remove about .025" from
each side, so call it .05" wider. Maybe a bit weaker, but probably not
enough to matter.
RV-8A 80091 Insalling exhaust.
