New Video...
Goto page 1, 2  Next
ces308
PostPosted: Thu Sep 01, 2011 9:04 pm    Post subject: New Video... Reply with quote
Hi all !
I took up a reporter from our local paper the other day and recorded the flight....if you have nothing else to do,take a look !
http://www.youtube.com/watch?v=5nEUAc6R_ic
chris ambrose
M3X/Jabiru 215.0 hrs
N327CS
Dennis Thate
PostPosted: Fri Sep 02, 2011 4:21 am    Post subject: Re: New Video... Reply with quote
Will she write a story about this flight ? ...if so, maybe you can post it here on the forum.
zeprep251(at)aol.com
PostPosted: Fri Sep 02, 2011 4:50 am    Post subject: New Video... Reply with quote
Chris,
Good for our sport and also a great way to meet cute reporters!
G.Aman MK3C Jabiru 2200A 638hrs
ces308
PostPosted: Fri Sep 02, 2011 7:36 am    Post subject: Re: New Video... Reply with quote
Gary -Dennis ..-all...
She saw another guys Firestar up here and started asking questions and he pointed her in my direction as he has never flown his yet.When she came into the hangar and saw the airplane,the first thing she said was ,"How does it feel when you are flying in this ?" Well,what else could I say but,lets go find out ! lol She loved the ride ! She is putting the story together and when it comes out I will post it...!
A side note...I have offered to take him up to get an idea of how these things fly,but we haven't hooked up yet....
chris ambrose
M3X/Jabiru A-2200
N327CS
Ralph B
PostPosted: Fri Sep 02, 2011 7:46 am    Post subject: Re: New Video... Reply with quote
Good video Chris. You might try that audio cord to plug into your camera to reduce noise when talking to your passenger. It worked well for me.
Here's the link again:
http://www.mypilotstore.com/MyPilotStore/sep/1978
Ralph B
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
pj.ladd(at)btinternet.com
PostPosted: Fri Sep 02, 2011 10:49 am    Post subject: New Video... Reply with quote
Nice flight.
Is that a check list I see before me? What is on it?
Pat
ces308
PostPosted: Fri Sep 02, 2011 11:31 am    Post subject: Re: New Video... Reply with quote
Hi Ralph....My camera does not have an audio in... Sad I wish it did...and you never know what YouTube will let you play on the videos...so I don't even try anymore....
Pat...Yes I do have a check list....I will try and post it for you...
This is the check list ...not the V speed reminder right in front of me...the check list is on a string off to the side for easy ref...Feel free any one to use this check list ..or adjust it to your plane....
chris ambrose
M3X/Jabiru
N327CS
Kolb Mark 3 Xtra check list.doc
 Filename:  Kolb Mark 3 Xtra check list.doc
 Filesize:  29 KB
 Downloaded:  584 Time(s)
ces308
PostPosted: Fri Sep 02, 2011 11:35 am    Post subject: Re: New Video... Reply with quote
Side note....Jabiru engines should be warmed to 80* F ...I think thats 59* c on the list....I have it changed on my list...
chris ambrose
PostPosted: Fri Sep 02, 2011 12:18 pm    Post subject: New Video... Reply with quote
This is the checklist>>
Thanks Chris .
I may adapt that.
I do not have a separate fuel pump for instance and with the trim right
forward I would struggle to get off the ground. I use about half. I trim
almost right forward for cruise.
Incidentally. what cruise speed do you get at 2800?
Pat
Thom Riddle
PostPosted: Fri Sep 02, 2011 12:31 pm    Post subject: New Video... Reply with quote
Pat, and Chris, and Gary (and any other Jabiru Kolbers).
What prop are you running? I suspect mine is longer than most Kolbers. Mine is Tennessee Wood Prop 64" diameter x 31" pitch, as stamped on the hub, but the pitch measures closer to 32". Not same airframe as you guys but is same/similar engine and probably similar cruise speeds.
Thom in Buffalo
On Fri, Sep 2, 2011 at 4:16 PM, Pat Ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
[quote]--> Kolb-List message posted by: "Pat Ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
Thanks Chris .
I may adapt that.
I do not have a separate fuel pump for instance and with the trim right forward I would struggle to get off the ground. I use about half. I trim almost right forward for cruise.
Pat
http://forums.matronics.com
le, List Admin.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
byoungplumbing(at)gmail.c
PostPosted: Fri Sep 02, 2011 12:37 pm    Post subject: New Video... Reply with quote
chris ambrose
just thinking out loud.. 59 c should be about 135 to 140 f
rotax wants the 912 to have 120 f oil temps before full power,,,, for a air
cool jab, 135 to 140 sounds bout right.\\
boyd young
mkiii utah
ces308
PostPosted: Fri Sep 02, 2011 12:58 pm    Post subject: Re: New Video... Reply with quote
ok.....
This is wheree I got the 59* from....
4.3 Warming Up Period, Ground Test
 Start the warming up period with the engine running at 1200 RPM. Continue at 2000 RPM depending on ambient temperature, until oil temperature reaches 15°C (59°F).
I make sure it's at least 80* before I start heading out the runway..
And Thom...My prop is a Sensenich 58" x 44 pitch...
chris ambrose
Thom Riddle
PostPosted: Fri Sep 02, 2011 1:21 pm    Post subject: New Video... Reply with quote
Fellow Jabiru flyers. Following is what I found in the manual.
Check the two ignition circuits at 2000 RPM. Note: - RPM with only one ignition should not drop by more than 100 RPM.
DO NOT apply full power until CHT reaches 100°C (212°F)
SO.....Warm up at 1200 rpm until OIL temp is 15C or 59F.
..........Defer take-off power until CHT is 100C or 212
I hope this clears it up.
Thom
On Fri, Sep 2, 2011 at 4:34 PM, b young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
[quote]--> Kolb-List message posted by: "b young" <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)>
--> Kolb-List message posted by: "ces308" <ces308(at)ldaco.com (ces308(at)ldaco.com)>
chris ambrose
rotax wants the 912 to have 120 f oil temps before full power,,,, for a air cool jab,  135 to  140 sounds bout right.\\
boyd young
mkiii utah
le, List Admin.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Thom Riddle
PostPosted: Fri Sep 02, 2011 1:26 pm    Post subject: New Video... Reply with quote
Chris,
Thanks for the prop info. Based on your videos I'm sure yours is quieter than mine. At same rpm my tip speed is 10% higher than yours.
Thom
On Fri, Sep 2, 2011 at 4:58 PM, ces308 <ces308(at)ldaco.com (ces308(at)ldaco.com)> wrote:
[quote]--> Kolb-List message posted by: "ces308" <ces308(at)ldaco.com (ces308(at)ldaco.com)>
ok.....
chris ambrose
http://forums.matronics.com/viewtopic.php?p=351281#351281
" target="_blank">http://www.matronics.com/Navigator?Kolb-List
MS -
e -
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
ces308
PostPosted: Fri Sep 02, 2011 1:39 pm    Post subject: Re: New Video... Reply with quote
LOL....you'll never convince anyone up here that this thing is quieter than anything !!! I think it was FLYING or AOPA mag has a interview with Burt Rutan and he says the noise factor was the reason he stopped designing pusher aircraft....
chris ambrose
PostPosted: Fri Sep 02, 2011 3:59 pm    Post subject: New Video... Reply with quote
Chris,
We need to do that more often.See someone who has interest? take em' for a ride.
G.Aman
Thom Riddle
PostPosted: Fri Sep 02, 2011 4:01 pm    Post subject: New Video... Reply with quote
Can't argue with that. The Titan Tornado I used to own, was very noisy
too. The outstanding visibility we get with pushers has to cost
something, I guess.
Thom
chris ambrose
http://forums.matronics.com/viewtopic.php?p=351286#351286
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
slyck(at)frontiernet.net
PostPosted: Fri Sep 02, 2011 4:21 pm    Post subject: New Video... Reply with quote
Mine is pretty noisy too. although folks on the ground say it is quiet. Maybe just polite neighbors.
I wonder what the physics is behind the noise factor, tractor vs pusher?
BB, MkIII, suzuki
something, I guess.
Thom
> chris ambrose
Thom Riddle
PostPosted: Fri Sep 02, 2011 4:46 pm    Post subject: New Video... Reply with quote
This is pure speculation, but I suspect that the engine not being
cowled, the turbulent air hitting the prop, and the proximity of the
engine to our heads with little or no noise insulation/absorption
between them all contribute to the ambient perceived noise in the
cabin. Other than the Tornado and several Kolbs, the only other
pusher I've flown was a Challenger, which I have flown from front and
back seats. The Challenger was noisy, especially in the back seat, but
I don't think it was as bad as the others I've flown. The Challenger
engine is mostly behind the fuselage thus it present less area to
disrupt air flow and disturb the air entering the prop. I think this
may have something to do with the perceived lower noise level.
Thom
do not archive this speculative thought stream
BB, MkIII, suzuki
> something, I guess.
> Thom
> do not archive
>> chris ambrose
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
PostPosted: Fri Sep 02, 2011 5:27 pm    Post subject: New Video... Reply with quote
BB, MkIII, suzuki
Bob B/Folks:
Don't know what the physics is behind the noise, but the tractor runs in
clean, undisturbed air, and the pusher is trying to operate in very
disturbed air.
Difference between night and day between a 912S with a 72" Warp Drive on a
pusher or a tractor. The tractor seems to whisper along, while the Kolb is
raising Hell.
Blanding, UT
Goto page 1, 2  Next
Page 1 of 2
