WAS Mod 71 - Nose gear leg bungee, replacement with springs
g-iani(at)ntlworld.com
PostPosted: Tue Aug 30, 2011 1:48 am    Post subject: WAS Mod 71 - Nose gear leg bungee, replacement with springs Reply with quote
Rob
Thanks for the drawing. The Dynon servo (as are a number of others) is mechanically identical to the TruTrak but has it’s own electrical interface. The revised mods makes only minor changes/corrections but do authorise the use of the Dynon in the UK.
As noted in the Mod, Dynon do not provide a bracket. You can use the TruTrak bracket or make you own.
Revised mod 75 attached. If you want 76 let me know.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Rob Housman
Sent: 29 August 2011 15:55
Subject: WAS Mod 71 - Nose gear leg bungee, replacement with springs NOW Dynon Autopilot
Thanks again Ian.
I am about to install the Dynon servos but lacking your update to the Mod, I compared the Dynon SV32 to the TruTrak B servo and having concluded that they are almost identical I came up with the attached mounting scheme. I would appreciate your comments and a copy of the Mod 75 and Mod 76 revisions. I designed and fabricated all of the mounting hardware to suit the Dynon servo since the factory did not offer a Mod – if you’d like I will send you the detailed drawings.
Best regards,
Rob Housman
Irvine, California
Europa XS
Rotax 914
S/N A070
Airframe complete
Avionics soon
 Filesize:  530 Bytes
 Viewed:  1684 Time(s)
Mod_75-4_AP.pdf
 Filename:  Mod_75-4_AP.pdf
 Filesize:  970.51 KB
 Downloaded:  542 Time(s)
