rob(at)hyperion-ef.com Guest
Posted: Mon Aug 29, 2011 6:59 am Post subject: WAS Mod 71 - Nose gear leg bungee, replacement with springs |
Thanks again Ian.
I am about to install the Dynon servos but lacking your update to the Mod, I compared the Dynon SV32 to the TruTrak B servo and having concluded that they are almost identical I came up with the attached mounting scheme. I would appreciate your comments and a copy of the Mod 75 and Mod 76 revisions. I designed and fabricated all of the mounting hardware to suit the Dynon servo since the factory did not offer a Mod – if you’d like I will send you the detailed drawings.
Best regards,
Rob Housman
Irvine, California
Europa XS
Rotax 914
S/N A070
Airframe complete
Avionics soon
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of G-IANI
Sent: Sunday, August 28, 2011 1:47 PM
Subject: RE: Mod 71 - Nose gear leg bungee, replacement with springs
Rob
At this moment I am the only source of issue 3. At Europa’s request (David Goddard said he was too busy) I had it approved by the LAA. I have passed the factory the master copy but as yet they have not got round to putting it up. Mod 77 (Push rod rudder drive) and Mod 78 (Glider wing fix) have gone up recently but the revised versions of 75 and 76 (which include the Dynon servos) are not up yet.
The opening for the tube to pass into the spring hook is a bit tight. It is perfectly OK to take off the inside corner to allow the tube in as Jeff B suggested.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com (g-iani(at)ntlworld.com)
530 Bytes |
1485 Time(s) |
Servo_SV32_installation.DWG |
147.18 KB |
345 Time(s) |
