It's the little things
slipstream(at)wavecable.c
PostPosted: Sat Aug 27, 2011 8:03 pm    Post subject: It's the little things Reply with quote
I had such a great time diagnosing a radio problem, I
figured I'd share it with the group. Here goes:
I installed a Z13/8 electrical system in my RV-7, pretty
much exactly as described in the current iteration. On
the radio side, I kept it fairly simple -- One GNS430W to
handle all my nav/comm needs, and an intercom. It
received GPS signals, vor/loc, and received comm. Good
sidetone on the intercom. I figured if it would receive,
it would send! It didn't. Pressing the PTT got me the
little "TX" indication on the GNS, but nobody could hear
me.
I looked through the list archives, and did some
trouble-shooting of my wiring. I removed the factory cork
gasket from my Comant antenna. I removed the aluminum
antenna screws I'd used and replaced 'em with steel
(desperation there). Checked my BNC crimps. Made sure I
didn't do anything really dumb like plug the nav coax into
the comm receptacle. I discovered after the fact that I
should have removed primer from under my antenna doubler,
but I was loathe to start drilling out rivets on another
goose chase.
I decided to let the "experts" give it a shot. I received
permission to fly the RV-7 nordo to the nearby towered
airport with a full-service avionics shop. They looked it
over, bench tested the GNS, took some readings off the
antenna and checked my amateur BNC crimping (not up to
their professional standards, it should be useable).
Finally got a bill for $100 and still no transmit.
I called Garmin factory support. In their opinion, my
Bose headset must be the problem. Thank you for calling.
I spent some time perusing the GNS installation manual.
Turns out there IS a "Comm won't transmit" item in the
toubleshooting pages. Answer: "Make sure it has power."
What kind of dopes do they think install these things?
It's like the home stereo instructions. "Make sure it's
plugged in."
I pulled the GNS out for the nth time and stared at the
back plate. The GNS-430 has three D-sub sockets
connecting it to the airplane -- "Main," "Comm," and
"Nav." The Main and Comm sockets both have power inputs
-- four power pins from two fuses or breakers. I knew
that transmitting drew more power by far than any other
function of the unit. Hmm.. My unspoken assumption had
been that if the unit received comm, it must have comm
power, right? Well, when nothing else pans out, you'll
try anything. I whipped out my little voltmeter and
tested the comm power pins. 3 volts?? Is that possible?
No idea, but when I touched the Main power pins, I got
the full 12 volts. I checked out the fuses and voila! My
comm power fuse had blown. As I was saying about dopes
and electronics...
I'm not sure how to explain the 3 volts I did get -- I
thought fuses were all-or-nothing affairs, but perhaps
not. Anyway, I popped in a new fuse and presto, I get
"loud and clear" reports from everybody I talk to. SO..
Maybe the "Comm" power pins need to be relabeled
"Transmit" power. And there you have it -- The $100 fuse.
Brooks
RV-7 N513BW Phase I ... Smile
aerobubba(at)earthlink.ne
PostPosted: Sun Aug 28, 2011 4:39 am    Post subject: It's the little things Reply with quote
Howdy-
Might I suggest you contact the shop owner, tell him what you found, and that a couple thousand people on this list all around the planet are waiting to see how he handles the situation? We all make mistakes, but hopefully we don't make others pay for them...
Glen Matejcek
PostPosted: Mon Aug 29, 2011 7:53 am    Post subject: It's the little things Reply with quote
My unspoken assumption had been that if the unit received comm, it must have comm power, right? Well, when nothing else pans out, you'll try anything. I whipped out my little voltmeter and tested the comm power pins. 3 volts?? Is that possible? No idea, but when I touched the Main power pins, I got the full 12 volts. I checked out the fuses and voila! My comm power fuse had blown. As I was saying about dopes and electronics...
I'm not sure how to explain the 3 volts I did get -- I thought fuses were all-or-nothing affairs, but perhaps not. Anyway, I popped in a new fuse and presto, I get "loud and clear" reports from everybody I talk to. SO.. Maybe the "Comm" power pins need to be relabeled "Transmit" power. And there you have it -- The $100 fuse.
The 3-volts you were seeing was probably coming OUT
of the radio as opposed to 'sneaking' across an
open fuse. Garmin has long been fond of the separate
input power for the transmitter of some models. On
some models, this input would like to have 28 volts
supplied even if the rest of the radio is running
on 14 volts.
Be sure and check for details on your particular
radio. You may want to add a 14/28v up-converter to
accommodate the transmitter. It will give you a lot
stronger output.
http://www.kenneke.com/avionics.html
[img]cid:7.1.0.9.0.20110829104338.01dd7d18(at)aeroelectric.com.0[/img]
 Filesize:  40.99 KB
 Viewed:  2887 Time(s)
