MJKTuck(at)cs.com Guest
Posted: Wed Aug 24, 2011 4:14 pm Post subject: Electric winch or hand crank? |
Hi Folks,
I think I asked this question before but I couldn't have kept the responses.
Someone recommended a electric powered winch to pull my monowheel onto
its trailer. I've read some reviews on Amazon but there are
diametrically opposed views on how good a job they do. The main
complaint being how slow they are or not very well built.
Ideally I would want one with a remote but I can't seem to find one with
a wireless remote, some have a wired remote but the cable seems too
short as I want to hold onto the wingtip to keep it level while the
winch does it's thing.
Alternatively I could keep it simple and use a hand crank - but the
wings will need to be kept level. I have made some attachments which
help some but once the tipping momentum gets going on side or the other
my hinged spring legs give way. You guys that use a trailer all time
must be using something. It takes me a good 30 mins to get everything up
on the trailer and seemingly a lot of physical strength - not good when
temps are in the 80s and 90s.
Also, when cranking what is the best thing to attach the cable to? Cable
round the axle on the side opposite to the brake came to mind. Not sure
I would want to pull on the tailwheel although that seems an obvious choice.
Any thoughts would be appreciated.
Not much flying this summer - we have had 45 days of 100+ F temps in
Wichita so far this year. The record is 50 days. Today was 106 deg F. Phew!
Martin Tuck
N152MT
Wichita, Kansas
Rocketman
Posted: Thu Aug 25, 2011 7:04 am Post subject: Electric winch or hand crank? |
Martin,
I use the Harbor Freight electric. Works fine...
Jeff - Baby Blue
On 8/24/2011 7:10 PM, Martin Tuck wrote:
Hi Folks,
responses.
choice.
Martin Tuck
N152MT
Wichita, Kansas
Checked by AVG - www.avg.com
raimo.toivio(at)rwm.fi Guest
Posted: Tue Aug 30, 2011 8:27 am Post subject: Electric winch or hand crank? |
Hi Martin
Attached is my solution (how to pull my Mono to
the hanger which locates on the small hill).
As you can see, I trust to my tailwheel.
Max pull force which is needed when pulling it
into hanger is 40 kg which is not a problem for a
sturdy structure of Europa´s tail wheel.
The winch itself is actually an engine hoist which
should be mounted to the roof.
It is capable enough to pull/lift 150 kgs = 330
lbs.
I did an adapter and bolted the hoist via adapter
to the ground /asphalt.
Remote controller is wired (a long cable, 12
metres /36 feet so I can well check all the
clearances when pulling her).
There are two limit switches so it is safe to use.
It would be easy to make it wireless controlled
but that is not necessary in my case.
When using it I feel myself to be more an operator
than a labour-pull-man.
If I were you, I would watch ATV (All Terrain
Vehicle) winches. Some of them are very strong and
operates straight with 12 VDC.
So it is easy to install into to the trailer.
Cheers, Raimo Toivio
Europa XS Mono OH-XRT #417
Updated flight hours /landings:
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
toivio(at)fly.to
www.rwm.fi
-----Alkuperäinen viesti-----
Sent: Thursday, August 25, 2011 3:10 AM
To: Europa Builders Forum
Subject: Electric winch or hand
crank?
<MJKTuck(at)cs.com>
Hi Folks,
there are
do. The main
built.
the cable seems too
it level while the
attachments which
a trailer all time
of 100+ F temps in
Martin Tuck
N152MT
Wichita, Kansas
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
264.02 KB |
4878 Time(s) |
hansjd(at)online.no Guest
Posted: Tue Aug 30, 2011 11:40 am Post subject: Electric winch or hand crank? |
Hi Martin.
A little late, but here goes: I use a hand crank to pull the airplane onto
the trailer. The winch was pulled from an obsolete boat trailer and mounted
just in front of the tailwheel rail - close to the attach-handle. Made a
short piece of wire with an eye at both ends to fit around the protruding
ends of the tailwheel axle. I hook the winch wire on to this small loop and
simply crank the airplane home. Works a treat.
Cheers
Hans
Posted: Tue Aug 30, 2011 5:58 pm Post subject: Electric winch or hand crank? |
Hi Hans,
I couple of other e-mails also indicate that it is safe to pull on the
tail-wheel axle so I think that is how I will go. You mentioned you have
a hand crank - which has you at the 'working end'. How do you stabilize
the wings if no-one is there to help?
Martin
On 8/30/2011 2:38 PM, Hans J. Danielsen wrote:
Hi Martin.
onto the trailer. The winch was pulled from an obsolete boat trailer
and mounted just in front of the tailwheel rail - close to the
attach-handle. Made a short piece of wire with an eye at both ends to
fit around the protruding ends of the tailwheel axle. I hook the winch
wire on to this small loop and simply crank the airplane home. Works a
treat.
Cheers
Hans
Posted: Wed Aug 31, 2011 7:23 am Post subject: Electric winch or hand crank? |
Martin:
The few times I've pulled it onto the trailer I have had good assistance
from bystanders. You could make a couple of ramps to sturdy the
outriggers/wings during this prosess. To measure the hight lift the
tailwheel onto the rail, wings level, measure the distance between outrigger
wheel and ground, add the small hight up to the mainweel platform and you
have the ramp hight. These ramps are also great when removing the first
wing as it sturdies the rest of the assembly without too much rocking
sideways. (But you do need help to pull the wings and place them on the
trailer anyway!)
Remember, the main landing gear frame is locked to sturdy the fuselage when
the ramp is pulled up and enclosing the wheel, but for transport I've always
used ropes to tie the fuselage sideways to the trailer structure. Otherwise,
the main landing gear frame will be subjected to a lot of strain from
sideways rocking of the fuselage.
Hope this helps.
Hans
Posted: Wed Aug 31, 2011 9:41 am Post subject: Electric winch or hand crank? |
Hans
is right. The sring in the main gear allows the fuselage to bounce around on the road so it really needs to be tied down at the front. I used a long luggage strap over the fuselage just in front of the windscreen which worked well and prevented the rocking that Hans noted.
Graham
Sent: Wednesday, 31 August, 2011 16:20:37
Subject: Re: Electric winch or hand crank?
--> Europa-List message posted by: "Hans J. Danielsen" <hansjd(at)online.no (hansjd(at)online.no)>
Martin:
The few times I've pulled it onto the trailer I have had good assistance from bystanders. You could make a couple of ramps to sturdy the outriggers/wings during this prosess. To measure the hight lift the tailwheel onto the rail, wings level, measure the distance between outrigger wheel and ground, add the small hight up to the mainweel platform and you have the ramp hight. These ramps are also great when removing the first wing as it sturdies the rest of the assembly without too much rocking sideways. (But you do need help to pull the wings and place them on the trailer anyway!)
Remember, the main landing gear frame is locked to sturdy the fuselage when the ramp is pulled up and enclosing the wheel, but for transport I've always used ropes to tie the fuselage sideways to the trailer structure. Otherwise, the main landing gear frame will be subjected to a lot of strain from sideways rocking of the fuselage.
Hope this helps.
Hans
budyerly(at)msn.com Guest
Posted: Wed Aug 31, 2011 10:57 am Post subject: Electric winch or hand crank? |
 DIV { MARGIN: 0px } <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> [img]cid:00c301cc680f$764abf30$00B69D56(at)goldfishbk2xxe[/img][img]cid:00c401cc680f$764abf30$00B69D56(at)goldfishbk2xxe[/img] Photo E-mail [url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=play&resid=2161856909618AA7!139&type=5&authkey=*AFq6nx20aM%24]View slideshow [/url]| [url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=downloadphotos&resid=2161856909618AA7!139&type=5&authkey=*AFq6nx20aM%24]Download images [/url] Just a thought on long range towing with the mono trailer.
My fabricator makes from 1/2 to 3/4 inch nylon a set of tapered spacers that drop in the carrier and hold the tire very snug to prevent side to side leaning. The wheel bearings and wheel are very strong so I expect it to hold the aircraft. A six ply sidewall on a 7 inch tire flexes very little. Only a small amount of taper is required to get the tire wedged in. Then the trailer ramp/arm is raised to hold the gear channel in position and if that is a bit loose, shims of phenolic were added to get a snug fit.
Here at Custom Flight we use ratchet straps to pull the gear leg into the trailer ramp hard and will modify the two adjustment arms if they do not bring the ramp up snug. Then we strap the wheel down hard to the trailer with crossed straps.
To prevent rocking back and forth if the tire loses pressure, we use bolts and a fake spar through the fuselage to hold the fuselage from leaning too far. Yes the wing will get in the way, so we run a strong strap from the trailers metal brace horizontally and hook down into those hooks. Miserable, tight and dirty to get between the fuselage and wing but doable. I have also seen folks use a strap over the fuselage, but I am not keen on that as the gear bounces so if you pull down tight, pad it well and check often.
Photo's attached of an aircraft that did not have the main wheel strapped:
[url=https://skydrive.live.com/redir.aspx?cid=2161856909618aa7&page=play&resid=2161856909618AA7!140&parid=2161856909618AA7!139&type=1&authkey=*AFq6nx20aM%24][img]cid:00c501cc680f$764abf30$00B69D56(at)goldfishbk2xxe[/img][/url]
Operator only strapped swing arm to trailer and aircraft bounced out.
Remember the gear takes the load, any fuselage strapping puts force on the fuselage or other attachments. So as soon as the fuselage begins to lean, stop and readdress. I pulled a mono kit with no engine from Utah without any difficulty except trailer tires and the foam wing cradles. If your trailer still has the foam inserts in the wing rack, replace them with strapping or fiberglass and pad them as they are notoriously bad about breaking down over time.
As for pulling the mono backwards, we have a tow bar set up similar to Raimo's.
For mono trailer loading and unloading, we just pick up the tail and move the plane. Lift the tail over the main wheel cradle and get it in the track and added a rope winch to the trailer to pull it aft. Easy to do with a young strong assistant. Be sure to strap the tailwheel down.
I have a 22 foot flat bed for my trigear and an electric winch that hooks to either the tow bar or around my nose gear pivot shaft housing. One guy can load the fuselage. Wings are still hoisted. Flip up wheel pants allow for a quick strapping using a cable over the brake disk and three ratchet straps (one for each cable and one for the nose gear leg, holds the plane marvelously secure.
Bud
842 Bytes |
4847 Time(s) |
1.11 KB |
4847 Time(s) |
72.23 KB |
4847 Time(s) |
