klinefelter.kevin(at)gmai Guest
Posted: Mon Aug 22, 2011 4:42 am Post subject: Fuel smell on take off |
Paul,
Did you find anything wrong with your carb?
Kevin
On 8/1/11, Paul McAllister <l_luv2_fly(at)yahoo.com> wrote:
| Quote: | Hi All,
I have a Europa with a Rotax 914. I had the engine in at LEAF last year to
have them work on an oil leak due to crank case fretting. While the engine
was there I had them overhaul the carbs.
Ever since that time I have had a fuel smell which is a common issue with
Europa's. For quite a long time I assumed that it was new fuel hoses that I
installed and I was slowly going through the process of eliminating each
source with no success. Finally I resorted to putting in UV fuel dye and I
discovered that the starboard carb was covered with dye.
Pulling the carbs of a 914 is a bit of a pain and before I do so I'd like
some suggestions of what would cause a fuel leak at full power.
Thanks in advance, Paul
