rickofudall
Posted: Sat Aug 20, 2011 6:24 am Post subject: Mk IIIC Weight and Balance Spreadsheet |
You'll have to change the location of the main gear for a steel (bent) gear legs, this if for aluminum legs.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
KolbMk3ClassicWAndB.xls |
23 KB |
212 Time(s) |
