Posted: Wed Aug 17, 2011 3:32 pm Post subject: [Probable Spam] tire and wheel |
Hi Bill,
I recommend you use a set of Michelin S-83 3.50 x 8.00 tires for the running gear. Image link below.
http://www.macsmachine.com/images/wheelfairings/full/fairingbrkts.gif
The tube and tire setup on the Matco wheel is a good fit and at 25.5 psi, rolls nicely.
These are good for HDS loading, mine at 1300 lbs max.
Obtained or ordered from motorcycle shops as a “motorscooter tire” for around $40.00 each.
Good value.
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Flick
Sent: Wednesday, August 17, 2011 2:56 PM
Subject: [Probable Spam] tire and wheel
what size nose wheel and tire on 601 hds? has 480x8 tire and wheel i have says italy-15x1.5 the tire seems a little tight in the nose fork. thanks ralph 601 hds corvair
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 01234567
