Posted: Mon Aug 15, 2011 3:20 pm Post subject: Paint air water separator |
For those of you doing your own painting, attached photo is a water separator that I find to work well. When painting I add a few blocks of ice to the water. In the photo the red hose is air in, the orange hose is air out. The drain valve is connected at the bottom of the vertical PVC pipe. The vertical pipe acts as a water collector.
Carl
122.09 KB |
3200 Time(s) |
whd721
Posted: Tue Aug 23, 2011 7:47 am Post subject: Paint air water separator |
Carl,
Thanks for posting good ideas both your water separator and the air box. Good ideas I will file away.
On Aug 15, 2011, at 4:18 PM, Carl Froehlich wrote:
| Quote: | For those of you doing your own painting, attached photo is a water separator that I find to work well. When painting I add a few blocks of ice to the water. In the photo the red hose is air in, the orange hose is air out. The drain valve is connected at the bottom of the vertical PVC pipe. The vertical pipe acts as a water collector.
Carl
<Water separator.jpg>
_________________ whd721
RV9A
Beaverton, OR |
Posted: Tue Aug 23, 2011 4:31 pm Post subject: Paint air water separator |
Thanks for the note. Did a marathon paint session last week and finished the fuselage.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William DeLacey
Sent: Tuesday, August 23, 2011 11:43 AM
Subject: Re: Paint air water separator
Carl,
Carl
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567
100.85 KB |
3141 Time(s) |
107.76 KB |
3141 Time(s) |
