Small drip from pilot side fuel sampler.
ruruny(at)aol.com
PostPosted: Mon Aug 08, 2011 2:56 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
John,
Theres an O ring in there that probably is damaged, has dirt or a small flake of aluminum keeping it from sealing
properly. I had to remove one early on that was leaking and just cleaning it was all it needed. I have lexan windows
and the auto fuel(ethanol) from that drain gets into the rivets there and causes it to crack. This happens when someone
slams the door up to the wing to get it to attach. Anyway don't let it go and damage those nice bubble doors.
Brian
ruruny(at)aol.com
PostPosted: Mon Aug 08, 2011 3:45 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
I have the CAV 110 type.
Pic attached or go to link
http://www.mcfarlaneaviation.com/Products/?PartNumber=CAV-110
 Filesize:  30.06 KB
 Viewed:  11149 Time(s)
NYTerminat(at)aol.com
PostPosted: Mon Aug 08, 2011 5:43 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
John, I had the same thing. It is the O ring that seals the fuel sampler. I drained the tank and removed the fitting and replaced the O ring. Make sure that the O ring is compatable to the fuel that you use.
Bob Spudis
N701ZX/912S
In a message dated 8/8/2011 3:22:10 A.M. Eastern Daylight Time, john.marzulli(at)gmail.com writes:
Today I noticed a VERY slow leak\drip coming from the fuel sampler fitting in my wing.
After cleaning the area with a cloth and examining it, it looks like the drip is coming from the sampler's hole. I checked the tightness of the fitting and it is secure.
Furthermore I pulled on the fitting to make sure that it was fully down and not stuck slightly up/
Has anyone else had this problem? Is there a solution short of draining my fuel and replacing the fitting?
John Marzulli
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
List href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
jgswartout(at)gmail.com
PostPosted: Mon Aug 08, 2011 6:06 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
The "Hints for Homebuilders" guys (EAA website) Dick and Bob Koehler said at a workshop at Airventure that those sampler valve seals are not serviceable.   Cost to replace, around $10.
John
On Mon, Aug 8, 2011 at 3:18 AM, John Marzulli <john.marzulli(at)gmail.com (john.marzulli(at)gmail.com)> wrote:
[quote]Today I noticed a VERY slow leak\drip coming from the fuel sampler fitting in my wing.
John Marzulli
ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
Tommy Walker
PostPosted: Mon Aug 08, 2011 10:06 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
John,
You might want to lay in a supply of those o-rings.  Happened on both 701s I built.
Tommy Walker in Alabama
On Mon, Aug 8, 2011 at 8:40 AM, <NYTerminat(at)aol.com (NYTerminat(at)aol.com)> wrote:
[quote] John, I had the same thing. It is the O ring that seals the fuel sampler. I drained the tank and removed the fitting and replaced the O ring. Make sure that the O ring is compatable to the fuel that you use.
Bob Spudis
N701ZX/912S
In a message dated 8/8/2011 3:22:10 A.M. Eastern Daylight Time, john.marzulli(at)gmail.com (john.marzulli(at)gmail.com) writes:
John Marzulli
Tommy Walker
N25A - Anniston, AL
Dan Wilde
PostPosted: Mon Aug 08, 2011 6:34 pm    Post subject: Small drip from pilot side fuel sampler. Reply with quote
On 8/8/2011 11:11 AM, John Marzulli wrote:
Does anyone have the ACS part number for o-rings that fit the Zenith
supplied samplers?
John: I had to replace the first set of drains on my 701. They came
with a black "O"ring and did not last 6 months. I had to also replace a
side window cause I left the door up and fuel drained on the window and
caused crazing.
The ACS part # is 05-01865 and it is called Saf-Air Drain Valve
CAV-110. It should have a blue "O"ring. I have not had to replace any
of these valves once I installed the ones with the blue "O" ring.
Dan Wilde
N948DW
robert.eli(at)comcast.net
PostPosted: Tue Aug 09, 2011 3:31 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
Hey Guys
What is the thinking with regard to why the black O-ring fails, and the blue
one works? Is this possibly an issue with alcohol in the fuel that is
deteriorating the black O-rings?
Robert
JohnDRead(at)aol.com
PostPosted: Tue Aug 09, 2011 7:43 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
The black ones are probably neoprene which will be degraded by alcohol in the fuel and the blue ones are probably silicone which is impervious to the fuel.
Regards, John
CH701 - Colorado - Jabiru 3300
Cell: 719-494-4567
Home: 303-648-3261
In a message dated 8/9/2011 5:32:09 A.M. Mountain Daylight Time, robert.eli(at)comcast.net writes:
--> Zenith701801-List message posted by: "Robert N. Eli" <robert.eli(at)comcast.net>
Hey Guys
Robert
PostPosted: Tue Aug 09, 2011 8:03 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
yes
In a message dated 8/9/2011 7:32:09 A.M. Eastern Daylight Time, robert.eli(at)comcast.net writes:
[quote]--> Zenith701801-List message posted by: "Robert N. Eli" <robert.eli(at)comcast.net>
Hey Guys
Robert
PostPosted: Tue Aug 09, 2011 9:05 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
I need to buy some all-fuel compatible O-rings for my mechanical fuel pump and my primer.  Anybody got a good source for fluorosilicone (or similar) O-rings that sells in small quantities?
On Tue, Aug 9, 2011 at 12:01 PM, <NYTerminat(at)aol.com (NYTerminat(at)aol.com)> wrote:
[quote] yes
In a message dated 8/9/2011 7:32:09 A.M. Eastern Daylight Time, robert.eli(at)comcast.net (robert.eli(at)comcast.net) writes:
[quote] --> Zenith701801-List message posted by: "Robert N. Eli" <robert.eli(at)comcast.net (robert.eli(at)comcast.net)>
Hey Guys
Robert
PostPosted: Tue Aug 09, 2011 6:17 pm    Post subject: Small drip from pilot side fuel sampler. Reply with quote
http://www.mcmaster.com type in fluorosilicone o rings, they have packages of 5
In a message dated 8/9/2011 1:06:17 P.M. Eastern Daylight Time, jgswartout(at)gmail.com writes:
[quote]I need to buy some all-fuel compatible O-rings for my mechanical fuel pump and my primer. Anybody got a good source for fluorosilicone (or similar) O-rings that sells in small quantities?
[quote] yes
Hey Guys
Robert
cffd(at)pgrb.com
PostPosted: Wed Aug 10, 2011 6:11 am    Post subject: Small drip from pilot side fuel sampler. Reply with quote
What fuel sampler valve does Zenith supply these days?
My samplers, from back in a 2000 kit, are brass and the kind that you used to see on cars to drain the radiator. It has a handle with a hole in the center. When the handle is turned it screws out and the fuel comes through the hole. As best as I can see, the sealing is done with brass against brass, no O-rings of any kind. I have had one drip and now need to keep it really tight.
Chuck D.
N701TX
ggower_99(at)yahoo.com
PostPosted: Fri Aug 12, 2011 2:15 pm    Post subject: Small drip from pilot side fuel sampler. Reply with quote
What happened to my 701 at the beguining, during the first test hours was that,even that we cleanned the tank well after installing the gas gauge, there was a little piece of aluminum from the cutting that got betwen the valve and the seat, we just got the valve off, saw the tiny piece and cleaned, no problem since in several years...
Gary.
Sent: Wednesday, August 10, 2011 9:07 AM
Subject: Re: Small drip from pilot side fuel sampler.
Chuck D.
N701TX
[quote]http://www.matronics.com/Navi========================
" target="_blank" href="http://forums.matronics.com">http://forums.matr -->
