email(at)jaredyates.com Guest
Posted: Fri Aug 05, 2011 7:40 am Post subject: VHF Nav/GS Duplexer |
I've been wondering lately about how I should provide glideslope input for my GNS430. I saw several duplexing modules at the aeromart, but many of them had a threaded connection instead of the usual BNC turn and lock. Are those threaded connectors available, or should I look for a unit with BNC all around?
The other option that I've considered is making or buying a dedicated antenna, though I'm not sure where I would put it. Would the elements need to be parallel to the wingspan?
kuffel(at)cyberport.net Guest
Posted: Fri Aug 05, 2011 10:52 am Post subject: VHF Nav/GS Duplexer |
Jared,
<< I've been wondering lately about how I should provide glideslope input
all around? >>
The threaded connectors are available (see Mouser.com) but come in several
different types. You really need to know exactly what you need to get the
right one. Much better is to just get the BNC type. Chief seems to offer
the lowest price for the Comant CI-507 at about $130.
<< The other option that I've considered is making or buying a dedicated
to be parallel to the wingspan? >>
I put mine at the center top of my windshield, forward of a cross tube.
Don't even notice it is there when seated. While certainly optimum to have
the dipole parallel to the wing, it shouldn't be critical. Even end-on
(parallel to the fuselage) where dipoles have a null there should be enough
signal bouncing around to be functional. Try it and see.
Or better yet, for $6.00 in parts plus a small box and short piece of
coaxial cable make your own diplexer. See the attached diagram.
Tom Kuffel
GSDiplex.pdf |
25.2 KB |
265 Time(s) |
Posted: Fri Aug 05, 2011 5:29 pm Post subject: VHF Nav/GS Duplexer |
At 10:00 AM 8/5/2011, you wrote:
| Quote: | --> AeroElectric-List message posted by: Jared Yates <email(at)jaredyates.com>
I've been wondering lately about how I should provide glideslope input for my GNS430. I saw several duplexing modules at the aeromart, but many of them had a threaded connection instead of the usual BNC turn and lock. Are those threaded connectors available, or should I look for a unit with BNC all around? |
The ones that are threaded but same size as BNC are
probably TNC connectors . . . there threaded cousin
to the bayonet lock BNC. The connectors are readily
available.
The diplexers are offered by several companies. Here's
one by RA Miller
[img]cid:.0[/img]
and offered by Aircraft Spruce for under $100
http://www.aircraftspruce.com/catalog/avpages/av570coup.php
The DIY splitter suggested by Jim Wier was posted by
Tom. This can be even simpler to make than what Jim
suggested. I've uses a BNC "T" adapter
[img]cid:.1[/img]
which feeds the VOR signal through the top
of the 'tee'. Then there's an RF game to be
played off the branch with the 10pF capacitor
and a couple of BNC chassis connectors
[img]cid:.2[/img]
and some long 4-40 screws. You end up with
a more compact and robust version of Jim's
coupler with a minimum of disruption of the
VOR feedline characteristics.
I've got a program working out at Hawker-Beech.
I'll see if I can get a prototype over to the
RF lab and optimize the dimesions of the
10 pF capacitor wiring.
Jim called out exactly 1" overall lead length
for the capacitor. That's because the capacitor
COMBINED with the inductance of the leads forms
a series resonant turned circuit that picks off
the glide slope signal for routing it to the
GS receiver.
Once those dimensions are developed, I can
publish a good DIY project. Or you can build
what Jim has already suggested. It works too.
| Quote: | | The other option that I've considered is making or buying a dedicated antenna, though I'm not sure where I would put it. Would the elements need to be parallel to the wingspan? |
Generally, yes. What kind of airplane are we
talking about?
GS signals on approach are VERY strong. The
antenna can suffer huge indignities of missed
optimization and still get you down the pipe
in good shape.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
15.14 KB |
3451 Time(s) |
14.05 KB |
3451 Time(s) |
23.88 KB |
3451 Time(s) |
Posted: Fri Aug 05, 2011 7:40 pm Post subject: VHF Nav/GS Duplexer |
At 08:50 PM 8/5/2011, you wrote:
| Quote: | Thanks everyone, I'm intrigued by the DIY duplex option, assuming
that I can find the parts. I especially like Bob's idea of a design
that minimizes losses to the VHF signal, since that was my only
motivation for a separate GS antenna. The airplane is a Bearhawk,
which is a tailwheel tube and fabric fuselage with a aluminum skin
from the instrument panel to the nose bowl.
Okay, Cessna put tens of thousands of GS antennas just
above the compass centered on the windshield. A simple
dipole 17" long fed in the center with 50 ohm coax
will perform quite well.
We had a fancy, clear plastic molded housing that
contained a copper foil strip. A short length of RG174
(itty-bitty 50 ohm coax) fed the center and took the
feed-line under the windshield and upholstery trim. I think
it spliced onto RG58 to take the signal on to the
GS receiver.
If you can manage RG400's larger diameter, it would
be the material of choice for getting the GS signal
down to your panel mounted receiver.
I proposed a methodology for fabricating a GS antenna
in the chapter on antennas . . . but forget the toroid
cores . . . they add no observable value.
(o o)
Posted: Sat Aug 06, 2011 5:25 am Post subject: VHF Nav/GS Duplexer |
At 08:00 AM 8/6/2011, you wrote:
| Quote: | Would an antenna like that need a balun,
Technically, it is "best" . . . practically,
you wouldn't see any difference in performance
if it did not have one.
| Quote: | and what kind of gap would be acceptable between the two elements?
. . . minimum practical. Actually, you can fabricate
a nifty antenna just from coax cable.
In this case, you clean off the outer jacket of your
feedline about 11". If it's a double shielded coax,
strip of the outer layer of shield too.
Pull center conductor out of the remaining shield
as illustrated here:
http://www.aeroelectric.com/articles/shldwire/shldwire.html
Stretch the center conductor and remaining
braid out into a dipole and trim each to 9.5"
per side.
Glue to 1/4" wood or plastic dowel 17" long. Just
spot it in a few places to fixture it on the dowel.
Then put pieces of heat shrink over each
leg of the dipole to "dress it up".
This technique eliminates the process-sensitive
and never pretty junction between antenna elements
an the feedline. It's all one piece.
harley(at)AgelessWings.co Guest
Posted: Sat Aug 06, 2011 5:45 am Post subject: VHF Nav/GS Duplexer |
Bob...
A little inconsistency here...I think...the length of the antenna elements and the dowel don't match.
Did you mean to cut the shield and center conductor to 8.5 inches long each and use a 17 inch dowel, or to use a dowel 19 inches long for the 9.5" element length?
Or leave two inches of the center of the coax unattached and hanging at something like a "Y"? Or one inch of each element hanging over each end of the dowel?
Harley
[quote] . . . minimum practical. Actually, you can fabricate
per side.
Posted: Sat Aug 06, 2011 5:47 am Post subject: VHF Nav/GS Duplexer |
Awesome, that sounds like the best solution so far! I have some hefty spanwise steel structure up at the top of the windshield. In this application should I be worried about being close to those?
On Sat, Aug 6, 2011 at 9:20 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
per side.
http://forums.matronics.com
le, List Admin.
Posted: Sat Aug 06, 2011 7:55 am Post subject: VHF Nav/GS Duplexer |
At 08:41 AM 8/6/2011, you wrote:
| Quote: | Bob...
Or leave two inches of the center of the coax unattached and hanging at something like a "Y"? Or one inch of each element hanging over each end of the dowel? |
No, stretch the whole thing out on a dowel of appropriate
length . . . in this case the 9.5" was a typo, should
be 8.5" and 17" overall. Thanks for the heads-up!
(o o)
Posted: Sat Aug 06, 2011 7:59 am Post subject: VHF Nav/GS Duplexer |
At 08:43 AM 8/6/2011, you wrote:
| Quote: | Awesome, that sounds like the best solution so far! I have some
Technically, yes. Ignore them for now. Space away as far
as sensibilities and craftsmanship will allow and give
it a try. Close proximity of the conductive structure will
electrically lengthen the antenna . . . so after installation
the purist would trim to new resonance after installation.
In this case, I don't think it's going to make much operational
difference.
(o o)
