aerobiz1(at)gmail.com Guest
Posted: Tue Aug 02, 2011 12:35 pm Post subject: [jabiruengines] Speaking of TBO (was12-Point Crowsfoot Adap |
It sounds like you have a good, well maintained engine Clive. Re Pete's comment about Rotec and TBO, given that their radials don't have any of the issues afflicting Jabs generally, then I would imagine that they are much more likely to go to TBO. A reason why there may not be any that have gone that many hours as yet is more to do with the type of aircraft that they are fitted to. Check the website. The radials are fitted to an amazing variety of machines, including motorcycles !
Martin
On Wed, Aug 3, 2011 at 3:32 AM, James, Clive R <clive.james(at)uk.bp.com (clive.james(at)uk.bp.com)> wrote:
As I understand it the top end TBO is 1000 hrs and the 2000 overhaul involves the whole engine strip.
My 2200a #596 made 1000 hrs and had new heads (+valves and rockers) and is now approaching 1300 hrs. As most folk know the heads in the 596 era were made of poor Ally and bent, the seats dropped etc. valves were OK but prudence suggests chucking them away. I would hope that my new heads will be good to go another 1000 hrs when I get to 2000 hrs (if me and the old girl are still together).
I understand there are plenty of 2000+ engines that have passed that milestone as generally the bottom end is ‘rock solid’ notwithstanding flywheel bolts and… and …and of course through bolts (WTF?).
That is unless you drew a bad ticket in the Jabiru lottery, that also goes for not making 1000hrs of course…..and that’s the shame of it all. Once the head situation was sorted we should have been able to look forward to a trouble free engine with small improvements made in developments as they were tried and proven by Jabiru.
That wasn’t the strategy that Jabiru used unfortunately as any reader of the lists will testify, knee jerk changes that were untried was the way to go (is it still?). I live in hope that the tickets being handed out are going to eventually be consistently good ones as I have a soft spot for the engine, can’t imagine why………
As often said, we don’t hear much about long term success stories on the lists by the nature of the way they work, but it would be nice to hear lots of folk posting theirs.
Regards, Clive
Jabiru SP 2200
Esqual 3300
From: jabiruengines(at)yahoogroups.com (jabiruengines(at)yahoogroups.com) [mailto:jabiruengines(at)yahoogroups.com (jabiruengines(at)yahoogroups.com)] On Behalf Of j. davis
Sent: 02 August 2011 17:06
To: jabiruengines(at)yahoogroups.com (jabiruengines(at)yahoogroups.com)
Subject: [jabiruengines] Speaking of TBO (was12-Point Crowsfoot Adapter)
On 08/02/2011 10:44 AM, Pete Krotje wrote:
Consider also the experience and integrity behind them. The Rotec sign at
> OSH said "Will make TBO". However when asked how many examples had gone the
| Quote: | distance to back up that claim - there were none. One wonders about big
bright promises with not much behind them.
That reminds me of a question I've been wondering about recently:
How many Jabiru engines have 'made TBO', broken down by type?
What exactly does 'make TBO" mean?
Hopefully, Jabiru is not making "big bright promises with not much behind them" !
Thanks!
Regards, J.
- Sonex #325 C-FJNJ, Jab 3300a, Prince P-Tip, Aerocarb
- former C-IGGY CH701 owner/builder, CH750 in progress
- see both (and more!) at http://cleco.ca
J. Davis, M.Sc. (comp sci)
email: jd at lawsonimaging.ca
*NIX consulting, SysAdmin
http://cleco.ca
I went to a haunted house, looked under the kitchen table,
and found spirit gum.
--- Steven Wright
__._,_.___
Reply to sender ([email]jd(at)lawsonimaging.ca?subject=Re%3A%20Speaking%20of%20TBO%20%20%28was12-Point%20%20Crowsfoot%20Adapter%29[/email]) | Reply to group ([email]jabiruengines(at)yahoogroups.com?subject=Re%3A%20Speaking%20of%20TBO%20%20%28was12-Point%20%20Crowsfoot%20Adapter%29[/email]) | Reply via web post | Start a New Topic
Messages in this topic (19)
Recent Activity:
· New Members 3
Visit Your Group
[/url]
Switch to: Text-Only ([email]jabiruengines-traditional(at)yahoogroups.com?subject=Change%20Delivery%20Format:%20Traditional[/email]), Daily Digest ([email]jabiruengines-digest(at)yahoogroups.com?subject=Email%20Delivery:%20Digest[/email]) • Unsubscribe ([email]jabiruengines-unsubscribe(at)yahoogroups.com?subject=Unsubscribe[/email]) • [url=http://docs.yahoo.com/info/terms/]Terms of Use
__,_._,___
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
tp://forums.matronics.com
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
Clive J
Posted: Tue Aug 02, 2011 10:19 pm Post subject: [jabiruengines] Speaking of TBO (was12-Point Crowsfoot Adap |
I did get a second pair of heads after 600 hrs, they were second hand ones off the front of someone’s engine.
Maintenance wise just changed the oil, filters etc, didn’t mess with heads or tappets too much as the heads were just bending, after a few flights you could always pull them up again a bit. Lapped the valves probably 4 times in 1000 hrs, Temps were Ok as it’s a Jab in a Jab with the old super sucking cowl.
The Fox Orange got a particularly bad ticket, since then he’s been printing his own….
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Martin Hone
Sent: 02 August 2011 21:32
To: jabiruengine-list(at)matronics.com
Subject: Re: JabiruEngine-List: RE: [jabiruengines] Speaking of TBO (was12-Point Crowsfoot Adapter)
Martin
On Wed, Aug 3, 2011 at 3:32 AM, James, Clive R <clive.james(at)uk.bp.com> wrote:
Regards, Clive
Jabiru SP 2200
Esqual 3300
From: jabiruengines(at)yahoogroups.com [mailto:jabiruengines(at)yahoogroups.com] On Behalf Of j. davis
Thanks!
Regards, J.
http://cleco.ca
--- Steven Wright
__._,_.___
Reply to sender <mailto:jd(at)lawsonimaging.ca?subject=Re%3A%20Speaking%20of%20TBO%20%20%28was12-Point%20%20Crowsfoot%20Adapter%29> | Reply to group <mailto:jabiruengines(at)yahoogroups.com?subject=Re%3A%20Speaking%20of%20TBO%20%20%28was12-Point%20%20Crowsfoot%20Adapter%29> | Reply via web post <http://groups.yahoo.com/group/jabiruengines/post;_ylc=X3oDMTJxZmx2YmV0BF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BG1zZ0lkAzM2NTgzBHNlYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTMxMjMwMTE3Mg--?act=reply&messageNum=36583> | Start a New Topic <http://groups.yahoo.com/group/jabiruengines/post;_ylc=X3oDMTJlN29kYjlvBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwNmdHIEc2xrA250cGMEc3RpbWUDMTMxMjMwMTE3Mg-->
Messages in this topic <http://groups.yahoo.com/group/jabiruengines/message/36515;_ylc=X3oDMTM2MHU1NHF0BF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BG1zZ0lkAzM2NTgzBHNlYwNmdHIEc2xrA3Z0cGMEc3RpbWUDMTMxMjMwMTE3MgR0cGNJZAMzNjUxNQ--> (19)
Recent Activity:
· New Members <http://groups.yahoo.com/group/jabiruengines/members;_ylc=X3oDMTJmcnZkZ2xlBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwN2dGwEc2xrA3ZtYnJzBHN0aW1lAzEzMTIzMDExNzI-?o=6> 3
Visit Your Group <http://groups.yahoo.com/group/jabiruengines;_ylc=X3oDMTJlYThrcmVmBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwN2dGwEc2xrA3ZnaHAEc3RpbWUDMTMxMjMwMTE3Mg-->
<http://groups.yahoo.com/;_ylc=X3oDMTJka3NhdmMwBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwNmdHIEc2xrA2dmcARzdGltZQMxMzEyMzAxMTcy>
Switch to: Text-Only, Daily Digest • Unsubscribe • Terms of Use <http://groups.yahoo.com/;_ylc=X3oDMTJka3NhdmMwBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwNmdHIEc2xrA2dmcARzdGltZQMxMzEyMzAxMTcy>
. <http://groups.yahoo.com/;_ylc=X3oDMTJka3NhdmMwBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwNmdHIEc2xrA2dmcARzdGltZQMxMzEyMzAxMTcy>
__,_._,___ <http://groups.yahoo.com/;_ylc=X3oDMTJka3NhdmMwBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwNmdHIEc2xrA2dmcARzdGltZQMxMzEyMzAxMTcy>
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List <http://groups.yahoo.com/;_ylc=X3oDMTJka3NhdmMwBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwNmdHIEc2xrA2dmcARzdGltZQMxMzEyMzAxMTcy>
tp://forums.matronics.com <http://groups.yahoo.com/;_ylc=X3oDMTJka3NhdmMwBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwNmdHIEc2xrA2dmcARzdGltZQMxMzEyMzAxMTcy>
_blank">http://www.matronics.com/contribution <http://groups.yahoo.com/;_ylc=X3oDMTJka3NhdmMwBF9TAzk3MzU5NzE0BGdycElkAzI3NzI3ODIEZ3Jwc3BJZAMxNzA1MDY1NjE4BHNlYwNmdHIEc2xrA2dmcARzdGltZQMxMzEyMzAxMTcy>
Lynn Matteson
Posted: Wed Aug 03, 2011 5:31 am Post subject: [jabiruengines] Speaking of TBO (was12-Point Crowsfoot Adap |
.....and next I'm gonna try printing $100 bills....: )
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with "Ramcharger" intake manifold...1152 hrs (since
3-27-2006)
On Aug 3, 2011, at 2:13 AM, James, Clive R wrote:
| Quote: | I did get a second pair of heads after 600 hrs, they were second
printing his own….
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
