Engine mounted.
bifft(at)xmission.com
PostPosted: Mon Aug 01, 2011 8:24 pm    Post subject: Engine mounted. Reply with quote
Got the engine hung over the weekend:
http://www.xmission.com/~bifft/img_2323.jpg
Wasn't too hard to do solo, just a few times wanted some help. Most of
the time extra people would have just been in the way.
Did end up having to remove the oil line that ran from the prop govener
to the front of the engine. I'm going to go with fixed pitch, but I
assume I still need to hook up this line. What say yall?
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 Engine hung.
1/4 Starduster II N23UT flying
bicyclop(at)pacbell.net
PostPosted: Mon Aug 01, 2011 8:50 pm    Post subject: Engine mounted. Reply with quote
For fixed pitch, you don't need the external line. Put a plug in the case where it attaches. You need to make sure that the aft crankshaft plug is pierced and then install one in the front.
Ed Holyoke
On 8/1/2011 9:21 PM, Brian Huffaker wrote: [quote]
--> RV-List message posted by: Brian Huffaker <bifft(at)xmission.com> (bifft(at)xmission.com)
Brian Huffaker, DSWL (bifft(at)xmission.com (bifft(at)xmission.com))
chaskuss(at)yahoo.com
PostPosted: Tue Aug 02, 2011 2:59 am    Post subject: Engine mounted. Reply with quote
Brian,
I assume that you have a prop governor adapter mounted on the engine? If so, you need to keep that oil line connected. The adapter and line allows you to keep the plugs in the front of the crankshaft, which would allow you to change to a constant speed prop at a later date, without having to replace a punctured inner prop plug. That line and adapter will allow any excess oil a way out of the nose of the crankshaft.
Charlie Kuss
--- On Tue, 8/2/11, Brian Huffaker <bifft(at)xmission.com> wrote:
Subject: Engine mounted.
To: "rv-list" <rv-list(at)matronics.com>
Date: Tuesday, August 2, 2011, 12:21 AM
help.  Most of
fixed pitch, but I
yall?
Forum -
FAQ,
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
PostPosted: Tue Aug 02, 2011 7:17 am    Post subject: Engine mounted. Reply with quote
On Tue, 2 Aug 2011, Charles Kuss wrote:
Brian,
I think so. Don't really know engine stuff, but there is something
squarish that had this line attached.
I don't think I can get the old line back on, it interferes with the
engine mount. However, it would probably be easier to make a new line
than to do the crankshaft plug stuff. And, leave the the possibility of
adding a constant speed prop at some point if I come into a lot of money
or something.
RV-8A 80091 Thinking engine.
n223rv(at)wolflakeairport
PostPosted: Tue Aug 02, 2011 8:13 am    Post subject: Engine mounted. Reply with quote
Speaking from experience with my RV-4, the only thing I would have changed on it was to add a constant speed prop. I gave up a lot of top end speed and performance with the fixed pitch prop, and a lit of speed control on ascents and decents. I flew it for 8 years and kicked myself most the time for not going with constant speed. For me to change was a new engine (or at least crank shaft) new prop, and a new cowling, and paint for the cowl. That was just too much of a tear up for me. If I were to do it over again, I'd invest in a constant speed prop without question.
It is added money up front, but it is a LOT cheaper than doing it later!
YMMV
-Mike Kraus
> Brian,
or something.
carl.froehlich(at)verizon
PostPosted: Tue Aug 02, 2011 8:41 am    Post subject: Engine mounted. Reply with quote
Fully agree. I had a FP on my 8A for six years. Now have a Hartzell blended airfoil and have been amazed at the improvement in all flight aspects.
Carl
Sent from my phone.  Please read past the typos.
-----Original message-----
From: Michael Kraus <n223rv(at)wolflakeairport.net>
To: "rv-list(at)matronics.com" <rv-list(at)matronics.com>
Sent: Tue, Aug 2, 2011 16:09:48 GMT+00:00
Subject: Re: RV-List: Engine mounted.
YMMV
-Mike Kraus
> Brian,
or something.
PostPosted: Tue Aug 02, 2011 10:37 am    Post subject: Engine mounted. Reply with quote
Brian,
Perhaps you could email me a photo of the area where the mount and the oil line collide? Would a change of fitting at the governor adapter help ease this issue? Is the problematic line rigid stainless steel? Or is it a flex hose? I am enclosing an attachment which details a small modification you "might" have to make to the block off plate at the rear of the governor adapter.
Charlie Kuss
Subject: Re: Engine mounted.
To: rv-list(at)matronics.com
Date: Tuesday, August 2, 2011, 11:13 AM
> Brian,
adapter and line
date, without
crankshaft.
interferes with the
make a new line
lot of money
or something.
  1/4 Starduster II N23UT =====================
Modifying_A_Governor_Adapter_Block_Off_Plate_to_Allow_Easy_Conversion_from_Constant_Speed_Propeller_to_Fixed_Pitch.pdf
 Filename:  Modifying_A_Governor_Adapter_Block_Off_Plate_to_Allow_Easy_Conversion_from_Constant_Speed_Propeller_to_Fixed_Pitch.pdf
 Filesize:  150.25 KB
 Downloaded:  2882 Time(s)
Kellym
PostPosted: Tue Aug 02, 2011 6:39 pm    Post subject: Engine mounted. Reply with quote
Keep in mind that aluminum fittings are banned by AD as is an aluminum
oil line. You have to have either aircraft hose or stainless line with
steel fittings. Yeah, I know all the arguments on ADs. This is one you
don't want to ignore, as you can lose all the engine oil in a flash if
it breaks.
> Brian,
> I look forward to seeing that photo. Please also take photos of the area
> on the rear of the engine where the SS line attaches, and your blanking
> plate.
http://www.xmission.com/~bifft/img_2329.jpg
this shows the line as close as I can get to where I took it off of. It
was attached to where the red plug now is. Looking at it, it may be an
aluminum line instead of stainless. The fittings are all Al.
http://www.xmission.com/~bifft/img_2326.jpg
shows the governor adaptor. No blocking plate, whoever pickled the engine
took off the accessories and then covered the holes with aluminum tape.
/font></pre>
Kelly McMullen
KCHD
PostPosted: Tue Aug 02, 2011 7:15 pm    Post subject: Engine mounted. Reply with quote
Kelly gives good advice here. Lycoming went to the SS tube because of failures of the old, aluminum tube.
Charlie
Date: Tuesday, August 2, 2011, 10:36 PM
an aluminum oil line. You have to have either aircraft hose
or stainless line with steel fittings. Yeah, I know all the
arguments on ADs. This is one you don't want to ignore, as
you can lose all the engine oil in a flash if it breaks.
>> Brian,
>> plate.
took it off of.  It
are all Al.
with aluminum tape.
> /font></pre>
Forum -
FAQ,
              -Matt
Dralle, List Admin.
PostPosted: Tue Aug 02, 2011 7:27 pm    Post subject: Engine mounted. Reply with quote
Brian,
Replace that aluminum fitting with the correct steel one. The fittings at both ends should be made of steel.
FYI, I may have given you a bum steer regarding the part numbers for the fittings. The AN816, AN822 & AN823 fittings are NPT to flare. Check the fitting in the governor adapter. It may well be straight thread, in which case, the numbers above are not correct. Best to go by the part numbers listed in the two Service Instructions I included in the earlier email. You will note that the drawing in one of the SIs I sent, shows a 45 degree fitting pointed up. That may well be what you need, with a modified SS tube.
FYI, it is VERY important to install the Adel clamps as shown in the SI to support the SS tube. Failure to install them could cause the tube to fail, from excessive vibration.
Charlie
To: "Charles Kuss" <chaskuss(at)yahoo.com>
Date: Tuesday, August 2, 2011, 9:58 PM
wrote:
> Brian,
photos of the area
and your blanking
>plate.
it off of.  It
it, it may be an
all Al.
aluminum tape.
> To ease the interference issue, you could simply omit
the governor
>adapter [and the shaft/gear inside it], install the
block off plate and
>gasket directly to the rear of the accessory housing.
You can simply
>drill and tap for a 45 or 90 degree fitting [whichever
works best for
>your application] anywhere on the new blanking plate.
FYI, you can make
>your own gasket, or simply buy one.
That would probably be best, why carry the weight if I'm
not going to use
it.  Could even T off of that line and hook it up to
the inverted oil
seperator like on the Starduster.  As for making a
gasket, I suppose the
auto form-a-gasket stuff would work?
>Check out the two photos in the link below. They show
the rear of a
>Lycoming engine with a prop governor [flaked off black
paint] installed.
>The governor adapter is the part [better view in the
bottom photo] which
>goes between the black governor and the accessory
housing. See
>http://www.vansairforce.com/community/showpost.php?p=389128&postcount=1
>The gray part with the steel AN816 [straight] fitting
pointing to the
>right, is where your SS tube is supposed to attach. If
you have
>interference issues, you could do any or any
combination of the following
>to cure the problem.
yep, except the fitting is Al instead of steel.
>#1  Replace the AN816 [straight] fitting with an AN82
[90 degree] or
>    AN823 [45 degree] fitting.
>#2  Obtain a new, longer piece of SS tube and bend it
as required to make
>    it work. This is experimental aviation,
after all.
  this would probably be the easiest, cheapest and
lightest way to go.  Be
a bit tricky to route around the mount, I know the engine
moves alot on
shutdown and startup.
>#3  Replace the SS tube with a fire sleeved flexible
oil hose. This is
>    even approved by Lycoming for certified
aircraft. See Lycoming SI
>    1435. [Brian, I've sent a copy of SI 1435
to you]
  Thanks for all the help, this is clearing up my
questions very well.
  RV-8A 80091
<pre><b><font size=2 color="#000000"
face="courier new,courier">
Forum -
FAQ,
              -Matt
Dralle, List Admin.
</b></font></pre>
PostPosted: Tue Aug 02, 2011 7:39 pm    Post subject: Engine mounted. Reply with quote
All the more reason to replace.
RV-8A 80091
