lcottrell
Posted: Fri Jul 22, 2011 8:42 pm Post subject: axle Jack |
Thom, I wanted to thank you for your clever idea on how to lift your airplane. I managed to let my right tire get too low in pressure and tore the valve stem. At first I thought that it might be too much trouble to make one, so I talked the wife into putting a hydraulic jack under the axle after I lifted the plane up. Then I found that the problem wasn't going to be solved that quickly, so I made one of your jacks as best as I could remember out of some scrap wafer board that I had, and was able to lift the plane easily and safely without help.
Great job!
Larry
Note: If you forward this email, please delete the forwarding history, which includes my email address.
Thom Riddle
Posted: Sat Jul 23, 2011 3:10 am Post subject: axle Jack |
Larry,
I made mine from a piece of 2x8 laying around and it worked well and was so quick to make I thought others might find use for it. I'm glad you benefited from it.
Thom
On Sat, Jul 23, 2011 at 12:39 AM, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
[quote] Thom, I wanted to thank you for your clever idea on how to lift your airplane. I managed to let my right tire get too low in pressure and tore the valve stem. At first I thought that it might be too much trouble to make one, so I talked the wife into putting a hydraulic jack under the axle after I lifted the plane up. Then I found that the problem wasn't going to be solved that quickly, so I made one of your jacks as best as I could remember out of some scrap wafer board that I had, and was able to lift the plane easily and safely without help.
Great job!
Larry
tp://forums.matronics.com
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
simonnelson(at)vodamail.c Guest
Posted: Sat Jul 23, 2011 3:22 am Post subject: axle Jack |
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> Picture?Sy
Sent via my BlackBerry from Vodacom - let your email find you!From: Thom Riddle <riddletr(at)gmail.com>
Sender: owner-kolb-list-server(at)matronics.com
Date: Sat, 23 Jul 2011 07:08:01 -0400
To: <kolb-list(at)matronics.com>
ReplyTo: kolb-list(at)matronics.com
Subject: Re: Kolb-List: axle Jack
Larry,
=A0I made mine from a pie= ce of 2x8 laying around and it worked well and was so quick to make I thoug= ht others might find use for it. I'm glad you benefited from it.
Th= om
On Sat, Jul 23, 2011 at 12:39 AM, Lar= ry Cottrell <lcottrell1020(at)gmail.com ([email]lcottrell1020(at)gmail.com= [/email])> wrote:
[quote] Thom, I wanted to thank you for your clever idea = on how to=20 lift your airplane. I managed to let my right tire get too low in pressure = and=20 tore the valve stem. At first I thought that it might be too much trouble t= o=20 make one, so I talked the wife into putting a hydraulic jack under the axle= =20 after I lifted the plane up. Then I found that the problem wasn't going= to be=20 solved that quickly, so I made one of your jacks as best as I could remembe= r out=20 of some scrap wafer board that I had, and was able to lift the plane easily= and=20 safely without help.
Great job!
Larry
=A0
Note: If you forward this email, please delete th= e=20 forwarding history, which includes my email address.
get=3D"_blank">http://www.matronics.com/Navigator?Kolb-List
Thom Riddle
Posted: Sat Jul 23, 2011 3:32 am Post subject: axle Jack |
Search the archives for this thread and you will find the sketches and a link to a video of it in operation.
Thom
On Jul 23, 2011, at 7:24 AM, simonnelson(at)vodamail.co.za (simonnelson(at)vodamail.co.za) wrote:
[quote] Picture?
Sy
Sent via my BlackBerry from Vodacom - let your email find you!From: Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Sender: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)
To: <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
ReplyTo: [url=mailto:kolb-list(at)matronics.com]kolb-list(at)matronics.com (kolb-list(at)matronics.com)[/url]
Subject: Re: axle Jack
Larry,
Th= om
On Sat, Jul 23, 2011 at 12:39 AM, Lar= ry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
| Quote: | Thom, I wanted to thank you for your clever idea = on how to=20 lift your airplane. I managed to let my right tire get too low in pressure = and=20 tore the valve stem. At first I thought that it might be too much trouble t= o=20 make one, so I talked the wife into putting a hydraulic jack under the axle= =20 after I lifted the plane up. Then I found that the problem wasn't going= to be=20 solved that quickly, so I made one of your jacks as best as I could remembe= r out=20 of some scrap wafer board that I had, and was able to lift the plane easily= and=20 safely without help.
Great job!
Larry
=A0
-List"">http://www.matronics.com/Navigator?Kolb-List
ref="http://forums.matronics.com">http://forums.matronics.com
uot;">http://www.matronics.com/contribution
| )≠Êfl¢{lã7∂râhØM4”Mi«ú¢Í‚zπfi¡ .Æ'´Nä¢VÀäÀDô®•äÓôK∂åj⁄Ëû',.+-Ê≠∫∑¨5´‚Å´hÆ⁄Æå,zÿ^ô©Ú.+-∫ÿ•äÿû≤ÀúÖ´äÀTüÙÆn«+äõb¢p+rØy'ö≠»C£ °ß{ ¨ÅÆå,x(Z¥P>-¢»Z≠ÊßvkúÜkúÜj+y®ky¯m∂üˇ√&j⁄Ëû',râø5´‚Å´h¨™%l∏¨∂mߡ√ ö∂∫'âÀ¢oÕj¯†j⁄+*â[.+-˝£Mç $ñNECI©ûÇ∑öµ 'µÈÌj[(jˆ¢ï¶Âz¯ö∂ñy±hÆÈ¨jfi~mߡfl¢ª¶≤f≠Æâ‚r«(ömߡfl¢ª¶≤f≠Æâ‚r«(õˆãäÀB¢{kâª≠äâ÷y¥¢µ‰·jy2¢ÁËØ*.Æßz∫.≤À©¶äÌ1´m∂•ï‚‚≤–ö)⁄Ü∑üÜ€iˇ¸0¬f≠Æâ‚r«(õ˜(û⁄‚nÎb¢xm∂üˇ√&j⁄Ëû',râørâÌÆ&Ó∂*'˝Ø€˝˙'∑˙k{ˆËw/·∂i
Buffalo, NY (9G0)
- Anonymous |
Posted: Sat Jul 23, 2011 4:00 am Post subject: axle Jack |
Thanks for your helpSy
Date: Sat, 23 Jul 2011 07:30:33 -0400
To: kolb-list(at)matronics.com<kolb-list(at)matronics.com>
Search the archives for this thread an= d you will find the sketches and a link to a video of it in operation.
<= br>Thom
On Jul 23, 2011, at 7:24 AM, simonnelson(at)vodamail.co.za ([email]simonn= elson(at)vodamail.co.za[/email]) wrote:
[quote] Picture?<= br>
Sy
Sent via my BlackBerry from Vodacom - let your email find y= ou!From: Thom Riddle <riddletr(at)gmail.com ([email]riddletr(at)gm= ail.com[/email])>
Sender: owner-kolb-list-server(at)matronics.com ([email]owner-kolb-list-server(at)matroni= cs.com[/email])
To: </= b><kolb-list(at)matronics.com>
[b]ReplyTo: [url=mailto:kolb-list(at)matronics.com]kolb-list(at)matronics.com (kolb-list(at)matronics.com)[/url]=
Larry,
=3DA0I made mine from a pie=3D ce of 2x8 laying around and it worked well and was so quick to make I thoug= =3D ht others might find use for it. I'm glad you benefited from it.
Th= =3D om
On Sat, Jul 23, 2011 at= 12:39 AM, Lar=3D ry Cottrell <lcott= rell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
| Quote: | Thom, I wanted to thank you for you= r clever idea =3D on how to=3D20 lift your airplane. I managed to let my right tire get too low in pressure = =3D and=3D20 tore the valve stem. At first I thought that it might be too much trouble t= =3D o=3D20 make one, so I talked the wife into putting a hydraulic jack under the axle= =3D =3D20 after I lifted the plane up. Then I found that the problem wasn't going= =3D to be=3D20 solved that quickly, so I made one of your jacks as best as I could remembe= =3D r out=3D20 of some scrap wafer board that I had, and was able to lift the plane easily= =3D and=3D20 safely without help.
Great job!
Larry
=3DA0
Note: If you forward this email, pl= ease delete th=3D e=3D20 forwarding history, which includes my email address.
get=3D3D"_blank">http://www.matronics.com/Navigator?Kolb-List
_blank">http://ww=
3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=
3D
-List"">http:=
3D
ref=3D"http://forums.matronics.com">http://forums.matronics.com
3D
uot;">http://www.matronic=
s.com/contribution
3D
font> | )=E2=89=A0=C3=8A=EF=AC=82=C2=A2{l=C3=A37=E2=88=82r=C3=A2h=C3=98M4=E2=80=9DM= =1Fi=C2=AB=C3=BA=C2=A2=C3=8D=E2=80=9Az=CF=80=EF=AC=81=C2=A1=C2=A0.=C3=86= 9;=C2=B4N=17=C3=A4=C2=A2V=C3=80=C3=A4=C3=80D=C3=B4=C2=AE=E2=80=A2=16=C3=A4= =C3=93=C3=B4K=1E=E2=88=82=17=C3=A5j=E2=81=84=C3=8B=C3=BB',.+-=15=C3=8A= =E2=89=A0=E2=88=AB=E2=88=91=C2=A85=C2=B4=E2=80=9A=C3=85=C2=B4h=C3=86=E2=81= =84=1B=C3=86=C3=A5,z=C3=BF^=C3=B4=C2=A9=C3=9A.+-=E2=88=AB=C3=BF=E2=80=A2=C3= =A4=C3=BF=C3=BB=E2=89=A4=C3=80=C3=BA=C3=96=C2=B4=0B=C3=A4=C3=80T=C3=BC=C3= =99=C3=86n=C2=AB+=C3=A4=C3=B5b=C2=A2p+r=18=C3=98y'=C3=B6=E2=89=A0=C2=BB= C=C2=A3 =C3=82=C2=B0=C3=9F{ =C2=A8=C3=85=C3=86=C3=A5,x(Z=C2=A5P=10>=1A-=C2=A2=C2=BBZ=E2=89=A0=C3=8A= =C3=9Fvk=C3=BA=C3=9Ck=C3=BA=C3=9Cj+y=C2=AEky=C2=AFm=E2=88=82=C3=BC=CB=87=E2= =88=9A=0C&j=E2=81=84=C3=8B=C3=BB',r=C3=A2=C3=B85=C2=B4=E2=80=9A=C3= =85=C2=B4h=C2=A8=E2=84=A2%l=E2=88=8F=C2=A8=E2=88=82=1Bm=C3=9F=CB=87=EF=A3= =BF=E2=88=9A =C3=B6=E2=88=82=E2=88=AB'=C3=A2=C3=80=1C=C2=A2o=C3=95j=C2= =AF=E2=80=A0j=E2=81=84+*=C3=A2[.+-=CB=9D=C2=A3M=13=C3=A7 $=C3=B1=10=11NEC= =12I=C2=A9=C3=BB=C3=87=E2=88=91=C3=B6=C2=B5=C2=A0'=C2=B5=C3=88=C3=8Cj[(= j=CB=86=C2=A2=C3=AF=C2=B6=C3=82z=C2=AF=C3=B6=E2=88=82=17=C3=B1y=C2=B1h=C3= =86=C3=88=C2=A8j=1A=EF=AC=81~=1Bm=C3=9F=CB=87=EF=AC=82=C2=A2=C2=AA=C2=B6=E2= =89=A4f=E2=89=A0=C3=86=C3=A2=E2=80=9Ar=C2=AB(=C3=B6=1Bm=C3=9F=CB=87=EF=AC= =82=C2=A2=C2=AA=C2=B6=E2=89=A4f=E2=89=A0=C3=86=C3=A2=E2=80=9Ar=C2=AB(=C3=B5= =CB=86=C3=A3=C3=A4=C3=80B=C2=A2{k=C3=A2=C2=AA=E2=89=A0=C3=A4=C3=A2=C3=B7y= =C2=A5=C2=A2=C2=B5=E2=80=B0=C2=B7jy2=C2=A2=C3=81=C3=8B=C3=98*.=C3=86=07=C3= =9Fz=E2=88=AB.=E2=89=A4=C3=80=C2=A9=C2=B6=C3=A4=C3=8C1=C2=B4m=0E=E2=88=82= =E2=80=A2=C3=AF=E2=80=9A=E2=80=9A=E2=89=A4=E2=80=93=1D=C3=B6)=E2=81=84=C3= =9C=E2=88=91=C3=BC=C3=9C=E2=82=ACi=CB=87=C2=B80=C2=ACf=E2=89=A0=C3=86=C3=A2= =E2=80=9Ar=C2=AB(=C3=B5=CB=9C(=C3=BB=E2=81=84=E2=80=9An=C3=8Eb=C2=A2xm=E2= =88=82=C3=BC=CB=87=E2=88=9A=0C&j=E2=81=84=C3=8B=C3=BB',r=C3=A2=C3= =B8r=C3=A2=C3=8C=C3=86&=C3=93=E2=88=82*'=CB=9D=C3=98=E2=82=AC=CB=9D= =CB=99'=E2=88=91=CB=99k{=CB=86=C3=8Bw/=C2=B7=E2=88=82i
