irampil(at)notes.cc.sunys Guest
Posted: Thu May 18, 2006 9:19 am Post subject: Trigear Caliper MSC269P |
Two things to note about the Nylaseal fittings:
First, may sure you have nylaseal not nyloflow fittings. I used the wrong
ones and they had a constant albeit slow leak. The correct ones were
obtained from MATCO. They have black inserts instead of the white inserts
supplied.
Second, use teflon (TFE) paste to seal the threads, never teflon tape.
Good Luck
Ira N224xs
non-leaking brakes at the moment
Dave Miller
Posted: Fri May 19, 2006 4:33 am Post subject: Trigear Caliper MSC269P |
Steve,
Look for Loctite PST, which I presume stands for pipe sealant teflon.
Fairly easy to find in farm/auto/garage supply stores.
Dave A061
"steve v." <s.vestuti(at)virgin.net>
Sent by: owner-europa-list-server(at)matronics.com
05/18/2006 04:07 PM
Please respond to europa-list
To:
cc:
Subject: RE: Trigear Caliper MSC269P
Thanks Ira, i`ve never heard of TEFLON PASTE , but ill make enquiries, my
seals are black, so ill assume they are OK... thanks again,
steve vestuti #573
Visit EuropaOwnersForum http://www.europaowners.org/
